Question about Kenmore 43142 Front Load Washer
Washer stops and reads 5d on the estimated time remaining screen
  • 311 Answers
SOURCE: washer showing 5d
Sensing suds. There should not be any. Please contact me if you need further help and leave feedback. Thanks for letting me help you!
Posted on Dec 01, 2008
  • 530 Answers
SOURCE: F21 and 5d code
that is because there is a problem with your pump. you need to take the bottom panel off and untwist the pump filter if it has gone further you need to take the 3 screws out of the pump and clean the impeller. try cleaning the pump filter first though and let me know how it goes
Posted on Jun 24, 2009
SOURCE: My quietpak 4 washer is stopping mid cycle and it
I just fixed mine by following instruction already posted to this web site. The front bottom panel is held with two bolts ( I used a 7mm socket) remove this panel (not hard) Go get a pot or bucket to collect water. I have those drawers under my machines. I used a place mat to funnel the water into the pot. Right in the middle is a filter drain plug. Water will start comin out if you just barely open it. (easier to try to keep water from going under the washer). When the water slows unscrew the cap all the way and this wonder glob of stuff can be seen in the drain plug. Clean it out!!! Now I'm running with no stops or "sud" errors. Oh by the way people I had to investigate what all was in the glob, besides mulch, nails and other little goodies that escape my sons pockets....One of those (new) all in one detergent fabric softner sheets. Beware of these people. Come to think of it when I tried those things is when my problems started occurring. Good luck to you!
Posted on Feb 16, 2010
blueextc3221
  • 15935 Answers
SOURCE: the load stopped mid cycle and we can't start it
The timer is bad and should be replaced.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 10, 2010
blueextc3221
  • 15935 Answers
SOURCE: 5D shows up on Kenmore washer and stops
"F21" (AKA SD) is a Long (SLOW) Drain error (LD). If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be displayed. This may be an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1.First, attempt to unplug the washer for at LEAST 30 minutes to reset the Central Control Unit (CCU). Sometimes this is all that is required to correct momentary glitches with the unit. If the error code returns, proceed to step 2.
2.Check the drain hose to make sure it is not kinked or clogged.
3.Check the electrical connections to the pump and ensure the pump is running.
4.Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Sep 30, 2010
Where do I find the MCU on my Kenmore h2plus washer?
  • 1 Check for any error codes in the Estimated Time Remaining display. The code "F20" indicates a water inlet problem. Press the Stop button twice to end the cycle and check that the faucets are turned on fully. Take a look at the inlet hoses. Close the valves and unscrew them. Look for any clogging on the screen and clear it.
  • 2 "F21" indicates a draining problem. Again, press the Stop button twice and take a look at the drain hose. Make sure it's not kinked, frozen or clogged.
  • 3 "SD" on the display indicates the machine has gone into its Suds Routine. The Suds Routine removes excess suds so that the garments rinse properly. It's not a problem, but can be an indication you've used a non-high-efficiency powder. Just let the SD routine complete and the draining will continue.
  • 4 Make sure the washer is level if it gets noisy or vibrates too much. Use the leveling feet to adjust the level. They screw and unscrew for adjustment. Make sure the shipping bolts were removed from the back of the machine if the machine gets too noisy. See the "Removing Transport System" section in the instruction manual.
  • 5 Check that you are using HE detergent if you spot leaks. Check that the fill hoses are tight and that the drain hose is secured to the drain pipe. Check that the drain isn't clogged.
  • 6 Make sure the load is balanced if the washer won't drain or spin--or if water remains in the washer. Redistribute the load.
  • Buy Custom Car parts.
    Jun 02, 2012 | Kenmore HE2 Plus Front Load Washer
    5d code
    5d is suds warning. The motor is being overworked from too much suds caused by improper measurements or detergent or both.
    Cabrio service manual is on my service manual page
    Run your washer without detergent a few times. Remember this washer uses less water than a normal washer it has 2 pumps. one recirculates a small amount of water over them clothes. You go adding in a regular amount of clothes and that washer fancy electronics gonna have a cow.
    Dec 13, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
    I have cleaned out the washer and cleaned the filter for the f21 code .i tried to restart washer with nothing in it and it washed for a minute the stopped and flashed 5d again what can i do?
    Hi
    F21 error means that the drain time has exceeded 8 minutes; this will turn off the water valves. Press PAUSE/CANCEL two times to clear the display. If errors still remains then please check the drain hose and make sure it is not plugged or kinked. Disassemble the washer by removing the back from the washer and check the electrical connections at the pump and make sure the pump is draining. Also inspect the pump filter for foreign objects. Before disassembling remember to turn off the power and disconnect the washer. If it still doesn't help then there is an issue with the pump and you'll need to replace it. Hope this helps... Please post back if you need more information.
    Daniel
    Aug 25, 2011 | Whirlpool Duet GHW9150P Front Load Washer
    Water will not spin out. Code says 5d
    The troubleshooting page in the owner's manual says: 5d "Sd" Suds Detected - Did you use regular detergent? Regular or hand-washing detergents are not recommended for this washer. Use only High Efficiency (HE) detergent. Did you add too much detergent? Always measure detergent. Follow detergent manufacturer's directions. If excessive suds are detected, the washer will display this code while running a suds reduction correction routine at the end of the wash cycle.The susds reduction routine removes extra suds and asures proper rinsing of your garments. If te code remains and the wash cycle dial is flashing after the recovery routine has stopped, re-select your desired cycle using cold water. Press start. Do not add detergent.
    Dec 31, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
    My Cabrio washer is showing a 5d error and not spinning or draining well. What is the problem?
    Sep 03, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
    My washer stops in the middle of the cycle and displays F-1 and after I have to set it on the rinse / drain cycle to complete. Today for the first time it also displayed 5d at the end of the cycle.
    5d or Sd means too much detergent was used. Try the following
    Run the unit through a RINSE/SPIN cycle.
    Run a NORMAL cycle without adding any detergent.
    This should clear the unit of the excess detergent.
    Jun 29, 2010 | Kenmore HE2 Plus Front Load Washer
    F-20????
    May 17, 2010 | Kenmore HE2 Plus Front Load Washer
    My Dynax 5D will not release the shutter nor will it turn off unless the battery is removed. The access light and the display remain on when the camera is turned off at the switch. All menus and autofocus...
    Hello
    Thank you for using FixYa for your problem
    Always check the batteries first but if is it still giving the same fault, your camera is faulty.
    It should be taken to an authorized repair centre for a repair estimate. Very few digital cameras have any user-serviceable parts.
    Please rate our solutions and if you still have problems please call back for more ideas to help you
    Thanks
    Richard Scott
    Technical Support
    New Zealand
    Dec 12, 2009 | Konica Minolta Dynax 5D / Maxxum 5D Body...
    Kenmore 43142 Front Load Washer Logo
    135 people viewed this question
    Sal DeAngelo
    fordexpert
    Ed Mac
