I have a Konica Minolta c450 with a FS601 booklet maker attachment. I don't know what I did but now when I try and print booklets on 11 x 17 size paper the second sheet is offset (sticks out beyond the 1st page) after it folds and staples. It's as if I've programed it for different size originals but I did not. I don't know what happened because it use to fold and staple all my booklets perfectly. Please help.
  • Gail Williams Dec 30, 2010
    I actually pulled the booklet maker away from my copier then pushed it back in place and that seemed to fix the problem. Thanks for your assistance.
  • 4,924 Answers
Just reinstall the driver and remove the old one from the control panel ..add remove software ..first ..than just run the disk again ...after restating ..and this will make the driver and software free of any unwanted and odd settings ..Try it ..and if it still makes the same issue you should run an alignment for the printer ..from the maintenance feature of the menu ..cause it may have a physical issue ..
Mostly .. this kinda problems are solved after reinstalling the printer ..
Posted on Dec 30, 2010
I am trying to print a 2 sided booklet and it says my duplex is not installed. How can I install it?
Well you have to get that option kit from a Konica Minolta dealership if they still have them. Sure the duplexer is installed just not plugged in would be attached to the right side door. will require two or three screws and a connector or two.
Jun 18, 2014 | Konica Minolta bizhub C351 All-In-One...
Print a booklet with a cover
well would have to know the model the spec on the paper and do you have a finisher
Jan 30, 2014 | Konica Minolta bizhub Office Equipment &...
Installing a Konica Bizhub C450 fusing unit ... need installation booklet
My machine had an error  3752 which means high temprature and pressure on fusing I turned it off for about 2 days now that i turn it on still its showing 3752 error pleas help me what this mean and what should i do?
May 12, 2010 | Konica Minolta bizhub C250 All-In-One...
I am trying to print a booklet with eight pages front and back from publisher 2007 on a Konica Minolta Bizhub C550 and when I print one copy it folds and staples fine. When I print two or more copies the...
first change driver, second print to hdd in printer, and then call this job from hdd and change copy amount. if this is not helping, then maybe the firmware is faulty, fw update is good idea
Oct 15, 2009 | Konica Minolta bizhub C250 All-In-One...
Folding and Stapling a Booklet on Bizhub C250
1)The print driver has two collate buttons and you only need to uncheck the first one (which is the windows driver not the Konica Driver) or
2) Install a new driver
Oct 02, 2009 | Konica Minolta bizhub C250 All-In-One...
Can't fold and staple multiple booklets
when you click on file then print in the window that pops up look at the lower right corner and you will see a box that says collate uncheck that box and it will staple correctly
Mar 05, 2009 | Konica Minolta Office Equipment & Supplies
Print Booklets with Konica Minolta Biz Hub C650 Printer
Select Print, and then "Properties"
Layout Tab - select Print Type: Booklet
Basic Tab - Select original size and then size of PAPER to be printed. 11x17 is standard 8.5x11 book when folded.
Finish Tab - select saddle stitch.
Thats it, easy as pie.
Jan 22, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
77 people viewed this question
k24674
jasbo
jasbo
