Question about Maverick WM-01 Round Heart-Shaped Waffle Maker
I have a kalorik heart shaped waffle maker and on the first use, after the first waffle, the waffle iron stopped working. i was wondering if there was something i could do to reset it or if i should just return it.
  • 312 Answers
Check the outlet that it was plugged into. If you used it in a kitchen it may have been plugged into a GFI outlet (Ground Fault Interrupter). If the safety device in the outlet failed, or there was more than one heating type appliance used on the outlet or a standard wall outlet. Then you may have simply triggered the circuit breaker that addresses this device. For example, If you had the coffee maker on, or the toaster, or the microwave oven on. Using an additional appliance would pop the breaker.
Here are the possible solutions. TRY your waffle maker in another outlet. If it was plugged into a GFI wall outlet, then find the "reset button" on the outlet and push it. If it clicks, it means that it had tripped. NOW HERE IS AN IMPORTANT POINT TO FOLLOW. If you reset the GFI and plug in the Waffle Maker, then turn it on and the outlet pops off. there is a wiring defect in the waffle Iron.
If you don't have a GFI and you plug the waffle iron into a standard outlet and turn it on and it trips the breaker, then same thing. A defect in the Waffle Iron. Now if you plug the waffle iron into a good circuit and it works again. Then it was a matter of the outlet being overloaded by too many small appliances.
Very common problem. Not serious. Just reset the breaker. Or if it's a fuse, replace it.
Hope this helps,
Best, Mark
Posted on Dec 30, 2010
Once the waffle is cooked how do you open the iron?
You need to spray oil on the waffle iron top and bottom before you put the batter in so it doesn't stick.
When it's cooked (steam mostly stops coming out), just lift the top off, and use a fork to lift your waffle out.
Aug 27, 2015 | Kitchen Appliances - Others
How long do i keep the waffle batter in
Shortly after closing the waffle iron it will start to steam, Watch when the steam stops and open the iron. The waffle should be golden brown.
After you get the hang if it you can adjust the cooking time for lighter or darker waffles. There are videos on Youtube that may help too.
Jul 03, 2014 | Black & Decker WMB505 Waffle Maker
Need manual for villaware uno 2003 uno heart round waffle maker
http://kitchen.manualsonline.com/manuals/mfg/villaware/villaware_waffle_iron_product_list.html
Dec 05, 2013 | VillaWare Kitchen Appliances - Others
Have a US model Kalorik Rotisserie which I have plugged into GB socket and blown it!
1) Test the power cord for shor with A VOM or DVOM and repair or replace
2) Open and see the thermic fuse is open
3) tEST any wires touching the carcase
4) Test the main swtich for short and replace.
God bless you
Jun 25, 2012 | Kalorik Rotisserie DGR 31031
I don't have the manual. How do you clean after use?
I have the same waffle maker and I just basically take a damp wash cloth and wipe it out. It's non stick coating makes it easy to clean this way. Another way is I run it under the sink faucet with the cord hanging down the cupboard so it doesn't get wet and this works good also. Hope this helps.
Aug 09, 2009 | Chef's Choice 830 / 830B Chrome WafflePro...
Replacement Carafe
Go to Kalorik.com and search under 'parts and accessories'. You'll be able to to find it there for $16.99.
They have chocolate fountains, ice makers, and waffle makers too!
May 06, 2008 | Coffee Makers & Espresso Machines
Maverick WM-01 Round Heart-Shaped Waffle Maker Logo
128 people viewed this question
Top Maverick Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Maverick Kitchen Appliances - Other Expert? Answer questions, earn points and help others
