Question about Dell OptiPlex 170L PC Desktop
Orange light on Dell GX270 power button
Can anyone tell me what the orange light on the power button means? I am using a Dell GX270 and the PC will not start. You can power it on but nothing happens.  Thanks in advance. Dell OptiPlex 170L PC DesktopPC Not working
  • 6 more comments
  • srees39 Jul 07, 2008
    Dell OptiPlex 170L Power Button shows orange light,and PC is not working
  • ivydredger Aug 25, 2008
    Dell Dimension 7400 steady orange light when switched on and cooling fan running very fast. System will not advance to boot. I found by tilting the Tower I have been able to boot up!
  • taisto1108 Sep 15, 2008
    Dell Desktop Dimension 5150 has blinking power light and solid Main Board indicator light but unit will not poweron.
  • abdus samad Oct 15, 2008
    i am using dell optiplex 170l , its showing orange light blinking on power button, and pc is not starting. can any one help me pls
  • Trevoryne Dec 08, 2008
    Dell optiplex GX270 orange led on the power button and nothing showing on the monitor. The hard drive is, dvd and the Flopy what the hell is wrong with it
  • Anonymous Apr 07, 2009
    help!!! we hebben een probleem stuur a.u.b.een makelaar om te kijken wat
    er loos is
  • ahussaini502 Mar 04, 2010
    but nothing happens
  • sharjeel
    sharjeel May 21, 2014
    for my desktop,there is a switch that make contact when we open or close casing i just cut the two wires of that switch and twisted them with each other,insulate them properly now it works for me.
I agree, the Optiplex GX270 is infamous for MoBos going bad. The capacitors have a manufacturing flaw, and up until February of 2008, Dell was replacing those boards for customers for free if it was found that the capacitors were the culprit. I just found a board yesterday with this problem. A sign that the capacitors are bad is either a buldge or they will be leaking an orange-rusted looking substance (primarily capacitors near the CPU). Symptoms of this problem include the PC rebooting itself randomly, and/or getting a BIOS error saying there was a thermal event.
Posted on Oct 14, 2008
A solid orange light, usually indicates an internal power problem but just in case try reseating the memory. Also its become a habit on a GX270 to check the capacitors to make sure they aren't bulging.
Posted on Jul 15, 2008
Orange light on D
Ha! We used to have loads of these - if I recall, it was a network adapter error - otherwise, check the motherboard for blown capacitors, they'll be bulging or even spewing yellow gunk out the top. This was a very common issue and Dell should replace the board free of charge.
For more info, see http://www.dell.com/support/Manuals/us/en/19/Product/optiplex-gx270
Oct 02, 2013 | Dell OptiPlex GX270 PC Desktop
My Dell Optiplex 745 Desktop PC Power light orange blinking how can i solved it..
The orange blinking on your desktop power button says that there's a problem with either the power supply or the motherboard itself.
Please refer to this link for the diagnostic lights on dell computers.
What you can do is: 1. unplug the power cord 2. press the power button, hold on it for more than 5 secs 3. re-plug the power cord on your CPU 4. test if it the system will work.
If this troubleshooting step does not help, that means it is more likely that the problem is with the motherboard.
Hope this helps!
Sep 14, 2011 | Dell OptiPlex GX270 PC Desktop
What does the blinking orange light mean on my dell CPU, I can't get it to power up
dell only knows 2 colors blue and orange... if you have no light on the mother board when power is plugged in. then your power supply is probably gone. considering you didn't mention beeps I would say thats it.
GL
hope this helps
Don't forget to vote for me
Thank You
Jammer
Aug 16, 2011 | Dell OptiPlex GX270 PC Desktop
According to dell there is an internal power problem.
http://support.dell.com/support/edocs/systems/opgx270/en/ug/specs.htm
http://support.dell.com/support/edocs/systems/opgx270/en/ug/solve.htm#1177038
Good luck
Apr 28, 2011 | Dell OptiPlex GX270 PC Desktop
My power butten is orage an if pressbthe moniter key it says power save mode on press any key or move the mouse. When I do nothing happens. I have a wireless mouse and the little recesepter thing that...
From my experience orange power button usually means 2 possible issues. One is motherboard especially if it is model gx270 or power supply issue. Unless you really know what you are doing it will kinda be hard to determine. You can open the case and look on the motherboard to see is there any capacitors that look cracked or bloated(not perfectly round) which would indicate motherboard issue. I would take it to a pc repair shop if it is worth it and have the test it. Good luck.
Nov 02, 2010 | Dell Computers & Internet
Optiplex light blinks, fan goes for a second but won't turn on
you may want to do a search on the dell website, i had that problem and never fixed it, you might find the information under service manuals search.
good luck.
Aug 11, 2009 | Dell Optiplex GX270
If you are getting an orange which we call in technical terms amber colored light it means that your PC required either the power supply to get replaced or the motherboard (Blinking amber or steady amber) both are guiding towards the same issue. It is better you first check it with the replaced power supply if not then motherboard is the sure shot solution
Jul 15, 2009 | Dell OptiPlex GX270 PC Desktop
Dell Optiplex GX270 will not start and power button is orange
I think that it is most likely that this is a power supply going bad. These can be purchased cheaply on eBay (make sure the picture matches). This replacement is moderately technical.
The other good possibility is a bad capacitor(s) on the motherboard. This is very common for the GX270s due to a manufacturer defect. Most of them failed in years 2-4, though. This would require a replacement motherboard (very technical). Pictures of bad capacitors: http://brianmorristech.com/?p=105
It could also be related to the power connector from the power supply to the motherboard (unlikely).
Another good option would be to buy a used GX270 from eBay and put your hard drive into it.
Jul 13, 2009 | Dell OptiPlex GX270 PC Desktop
When put power cable in orange light comes on power button and wont boot up
Sir,
Orange light usually comes only if your system stays in low power mode or sleeps, So u get orange light immediately when u switch on the system, try pressing the ESC Key on the top left corner of the Keyboard, and if not try pressing the power button again...
If not working,tell me Whether do u get any sounds in system?
Your system Operationg System?
And What u get on the screen, when u switch on?
Thanks, Regards
Vinod
Jun 29, 2009 | Dell GX270 P4-2.8 512/40/24X/XPP/NONE...
Dell optilex gx270 won't boot
when you say it doesnt boot? you mean it doesnt go to windows? or theres really nothing on the screen? whats the color of your power button on tower, it soldi orange, reseat all data and power cables from your hard drive and dvd drive, if no go, replace mobo and power supply.
Jan 14, 2009 | Computers & Internet
Dell OptiPlex 170L PC Desktop Logo
6,023 people viewed this question
Alun Cox
