Question about Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water
Want to purchase door shelf bin for Amana frig model SXD520SL
  • Amana Master
  • 8,404 Answers
Visit any of the FixYa.com advertisers whose names will appear on the page when you get this answer.
Thanks for your visit today.
Posted on Dec 30, 2010
Why does my side by side amana frig (model ARSE66ZBW) freez anything near the back wall of frig ?
On your Amana model there are a couple things I want you to check. I think that you have already double checked your temperature settings but check the temperature again and set a little warmer if possible. Many times this is not the issue causing the colder than normal temps in the fresh food section. Your model ARSE66ZBW has something called an auto damper Click Here=> ARSE66ZBW Controls Then you will see item location number 8. That is your 12571701 Auto Damper I would like you to see if frost or ice is blocking the vent and causing it to remain open. Read over this service manual=> HERE This manual is not the same as your model but has all the instructions needed to test the components I am discussing. Test the Auto Damper, check all vents inside fresh food compartment, thermostat (if Running Continious) and if damper is stuck in the open position without ice causing the problem the manual and I will be here to help you test the thermostat embedded into the damper to see if the damper itself will need replaced, Looking to here from you, Thanks, Sea Breeze
Mar 10, 2012 | Amana Refrigerators
Items in frig freeze
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Here's a diagram of your fridge controls and parts.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5177055&diagram_id=1347585#d1347585
Oct 20, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
Door does not close tightly. If I lift door it
If the hinges aren't too worn, you can sometimes loosen the screws (just loose, don't remove) that hold the hinges to the case of the frig, have someone lift the door by the handle.
Have them lift it firmly while you retighten the screws for the door. Your door may fit better and it's a quick fix.
If the hinge is getting worn, you can purchase replacement parts. Check at repairclinic.com ...they have a huge selection and the parts can be matched to their photos... great help when making sure they're correct.
Best of success on this.
K
Aug 29, 2009 | Amana Refrigerators
Ice cream and bread don't freeze, food in frig DOES freeze
Not fixed but I do not want to spend MORE money to find out what's wrong with this AMANA piece of ****. Apparently, from research on the net, the compressor or motor is not strong enough in this unit to actually do the job...but if anyone has any suggestions, I'm happy to hear them...
May 16, 2009 | Amana ATB1832AR Top Freezer Refrigerator
All the shelves have become brittle.
The bottom door bin for your Samsung is part number DA63-01263C. The next shelf up, called the middle guard, is part number DA63-01262A. The "facings" for the bottom two freezer drawers (also called freezer tray covers) are parts DA63-01653A and DA63-01652A. You may order these parts online at http://www.partstore.com/
Mar 05, 2009 | Samsung RB2155 Bottom Freezer Refrigerator
We have an Amana side by side that is only cold on the bottom in both the freezer and fridge. Also the top shelf of the fridge is hot from the light, which does not seem to go off when the door is shut....
amana runs power to the fan thru the defrost sensor that is mounted on the evaporator coil. these sensors will get moisture inside of them and short out causing intermittent fan operation. replace then sensor and your frig will return to normal. thanks for using FixYa peyton
Feb 17, 2009 | Amana ASD 2624 Side by Side Refrigerator
Jenn Air model JCB2388AR, about 11 years old
We got heavy duty velcro and put it on the back of the bins. Works like a charm
Aug 08, 2008 | Jenn-Air 25.6 cu. ft. Side-By-Side...
Too cold in vegetable bins
Air flow ports adjusted correctly? Air flow fan running? I once had a bad temp sensor on the freezer coil that would not let the fan run.
May 29, 2008 | Amana ABB2227DE Bottom Freezer...
Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water Logo
Top Amana Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
