Question about West Bend Kitchen Appliances - Others
I have put everything in machine and plugged in turned on and nothing happens. I turned it off made sure pan was in tight, still nothing.
  • Daryl Nash
    Daryl Nash Dec 30, 2010
    need to ask a couple of questions to solve this:
    1)which program did you choose?
    2)did you choose the program and then push the start button?
    3) did you turn it off or unplug after you got tired of waiting? If yes, how long did you wait before turning off or unplugging?
    Genius:
  • West Bend Master
  • 1,280 Answers
Email me with a suggested time for a chat and I will try to be on line then to discuss this with you.
I recommend 8 pm EST tomorrow.
Posted on Dec 31, 2010
Foot pedal will not active machine
make sure it's plugged in tightly to machine. Make sure light is on . OH, does the light come on? If the light comes on., it will indicate that you are getting power to the machine
Jun 30, 2015 | Sewing Machines
How do i do a oil change on my 1995 buick riviera
What you are referring to is the oil pan drain plug. They can be hard to remove because sometimes service people tighten them way too much so not a single drop can leak. Be sure you are turning the plug counterclockwise to remove it.
Dec 04, 2013 | 1995 Buick Riviera
2002 concorde oil drain plug rounding off, and wont loosen any help
A few things. One you can use an air hammer with a chisel adapter on it and hit the rim of the bolt (don't put it through your pan.) This is the way I get them out when nothing else will. You can try a pair of Vice Grips. They work well sometimes but if it is really really stuck then it will have to be tapped out with an air hammer. Another thing, when that plug finally does come out, there is a good chance that it will strip the threads on the pan a bit. The pan will need to be tapped so the new plug will go inside the pan.
Regards, Tony
Apr 10, 2011 | 2002 Chrysler Concorde
How to give it a oil change
Please read first, and make sure you have everything( did mine the other day, and forgot the filter. 2 trips) we can get you to do this in one easy trip. I do believe in safety first, and will tell you several times. This job takes no more than 30 minutes for a beginner. first the tools, a crescent wrench, or open-box wrench set( between 9/16th to 7/8th.)for the drain plug, a jack, jack stands(safety first), a couple of rags, an oil filter wrench, and an oil catch pan( can get both at the auto parts store). Now the bigger auto parts stores carry a returnable catch pan, to recycle the oil. From the store you will need the filter (store clerk will help you get the right size, just need model, year, and size of engine) and a large container of oil (comes in gallon sizes now. lets jack the truck up( put a brick behind the rear wheels, safety) and now lower to the jack stand on the frame. do both sides. with the catch pan under the oil pan, remove the bolt on the back of the pan (slowly, as you unscrew the bolt, oil will start to leak out, remove the bolt and let the pan drain. now, take the filter wrench, and unscrew the oil filter(careful, its FULL of oil) and set that in the catch pan to drain. Please check the old oil filter to make sure the rubber gasket is still on it. they sometimes stick to the engine block, and the new filter will leak. time to put it together now. taking the new filter, take some oil and rub it on the new gasket(will help with the seal) and screw into place tighten with your hands only(tight as you can(using the wrench might damage the filter). wipe off around the drain hole, and the plug. screw the plug back into place(only tight enough to get a good seal) do not over tighten, it will strip the pan hole. remove everything from under the truck, and take off the stands. refill the oil to the dip stick. and start the truck. Look underneath for any leaks. No leaks. great. let the truck sit for about 15 minutes, and check the oil level (you started the truck, and filled the oil filter). so add the oil you need, and your done. hope this helps you. very easy job to do
Jan 05, 2011 | 1996 GMC Sonoma
Will be changing engine oil and want to make sure i do it correctly
first off make sure u have some old rags or a roll of blue shop towels works best. u need to be sure u have enough oil probly five or six quarts. make sure u got ur filter. u may need a filter wrench, not alway but they can stick tight. also a drain pan and a wrench for the oil plug.
first take the key and put it in ur pocket, thats good to do no matter what ur working on because that way no one will start it if your not around or worse under it. ok warm up the engine. carfull not to burn your self but the hotter the better when draining oil. hot oil drains better hot, but hurts on skin.lol. but that how we do it in every shop. ok now take ur drain pan and plug wrench. also a rag. probly fourteen or fifteen mm crawl under the front and look for the plug in the bottom of the oil pan, the big pan right at the bottom of the engine lossen the plug.remember righty tighty, lefty loosy now put the pan under and unscrew the plug all the way and make sure ur oil is going in the pan. now u should still be holding the plug, thats where the rag is needed because its still hot and ur hand will start to burn after a few seconds. ok now if u can see the filter from down there go ahead and take it off. if not go up to the top and do it there. but put the pan under it before you do. ok now u have the filter and oil out give it ten or so to drip. clean the plug good and put it back in. tighten it down right away. never leave a plug not tight. its not a i will get it in a minute kinda thing. never put in an oil plug and not tighten it down. i have seen it happen before. not good. ok now with the new oil filter u need to take some new oil ,just a few drops will do, and coat the ruber ring. then carfully. carfully. carfully put it back in place and screw it tight. carfully i stress. if u miss pull it back out and clean the dirt off. its just like spark plugs. if u miss clean the dirt. u dont want that in ur engine. now tighten by hand and give it a little more with the wrench just to be sure it wont work its way loose. ok last step. new oil. if u have a owners manual it should say how much to use. once u put that much in u still need to check the dip stick because its not a garentee that how much u need. ok oil level says full , plug is tight filter is tight. fire it up and watch ur oil gauge. it should come up within a few seconds. ten seconds running dry and u will burn ur bearings so whatch it. if no oil pressure shut it off in real cold weather it can take up to twenty seconds to prim, at most. ok u got good oil pressure let it run about a minute. shut it off, wait about a minute and check the dipstick again. it it was right at full before u started it it may be a little low because of the filter ,so add a little if needed. thats it ur done. but its also a good time to check or replace ur air filter to. but dont let any dirt get in there ether.
Nov 17, 2010 | 2001 GMC Yukon
Rotating shaft will not rotate - during the kneading process nothing happens
1) Make sure bread pan is inserted in the machine correctly. 2) Take pan out of the machine and make sure the paddle spins freely on the shaft. ( If not, sealed bearing is frozen and pan needs to be replaced. 3) Keep pan out of machine and start a kneading cycle. Look through the lid window to see if the motor shaft is turning. If not the belt may have come off , snapped or there is something wrong with the motor or curcit board in the machine . Hank
Aug 24, 2010 | Zojirushi BBCC-X20 Home Bakery Supreme...
My machine will not knead. It does the clicking like normal but the paddle is not moving. It goes through the whole cycle without any movement.
There are three possible reasons why this is happening. 1) Make sure the pan is properly seated in the machine. 2) The paddle will not rotate because it is stuck. 3) The belt is broken or is loose. Make sure the pan is seated correctly will solve problem one. Take the pan and paddle out of the machine and see if turns freely by hand. If no, then the sealed bearing is broken or something is causing the paddle to stick (put water in pan and soak it for awhile). If everything is ok keep the pan out of the machine and start a kneading cycle. Look through the lid to see if the motor shaft is turning. If no then the belt fell off or is loose. Hank
Jun 13, 2010 | Breadman TR2500BC Bread Maker
Why did the kneading paddle on my 1148X bread machine quit working. This happened the third time it was used. It did the initial mixing and resting. When it started the kneading process again, the blade...
Hi, If this is the third time using it, it could be defective. Return it for service. If not under warranty, try a few things. 1) Make sure the pan is inserted in the machine correctly. 2) Make sure that the paddle is not sticking, or the sealed bearing on the bottom of the bread pan is not broken or frozen. (Take pan out and see if you can turn the paddle freely by hand). Or finally, the belt may be loose and slipping, especially when it takes more power to knead the dough the second time. Good luck...Hank
Jun 12, 2010 | Toastmaster 1148X FastBake Bread Maker
Machine on but nothing happening
It could be two things that has happened. The easy fix is that the belt has fallen off the pulley and not turning the paddle or the belt itself is snapped. Secondly, it could be that the sealed bearing in the bottom of the bread pan is frozen. See if you can spin the paddle by hand. If no..then it's frozen. (try putting hot water in the pan to see if it frees up. If after a few tries it does not then the bread pan needs to be replaced). The motor and pulley assembly is located inside the base of the machine.
Feb 01, 2010 | Breadman TR850 Plus Bread Maker
Replaced ignition switch, now car won't start I own a 1980 Camaro(Had to put 83 in product category cuz it wont go any lower but it's an 80), The Ign. Switch went out a few months ago, I replaced it back...
Dont panic, you can do this. First you must get a multimeter. Their cheap at harbor frieght 5 bucks. Then check the battery, car off, should be 12 volts. car on 13,14 volts. Possibly the ignition switch wires are touching. That of course would be a short. Also try to jump start the car, if it turns over you found your problem. If not you must start check the connections from the battery. follow the wires, negative to frame, make sure its tight, positive to starter make sure its tight to starter post. Use meter to check for power on the wires. Okay buddy good luck.
May 13, 2009 | 1983 Chevrolet Camaro
Kitchen Appliances - Others Logo
Top West Bend Kitchen Appliances - Others Experts
Jim Goldsmith
Jim Goldsmith
Irene Tulloch
Oloyede Monsuru
Are you a West Bend Kitchen Appliances - Other Expert? Answer questions, earn points and help others
