Question about Samsung LN26B360 26 in. LCD TV
Hi i have the samesung ln26b360 lcd tv and for some reason when i went off to college like the 3rd day i had my new tv i had to unplus it to move it to the other side of the room well i moved it plugged it back in and it wont turn on left it unplugged for 3-5 days and randomly tried it again and boom it turned on it does it everytime it gets unplugged and now it happend and its been 6 days and nothing what could be wrong
    Master:
  • 691 Answers
There are probably bulging caps in the power supply, youtube are getting better at showing how to repair tv's, you can look and search how to repair samsung tv, it will give you the best result possible if you are a DIY.
Posted on Dec 30, 2010
2 Suggested Answers
  • 8457 Answers
SOURCE: hi i have the samesung
The tv power supply board is likely the problems and the causes.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Is my college career over?
It's only over if you want it to be. Get some tutoring in math and retake the class. Don't give up. Only the tough survive. Here if you need me.
Jan 04, 2017 | Higher Education (University)
Hi, my rca lcd tv has had a problem for some time now, so I got the tv early 2013 and put away later that year once I moved but recently(6 months ago) I went to college and have started using the tv a
Brent without seeing it. I sound like one of the Caps had leaked sorta like a Battery leaking after a long time. Go to Shop Jimmy.com or Amazon.com and look up the part number. be sure and get the number directly off the power supply board u have. and be careful fooling around back there even tho it is unplugged it still carries stored up charges. take photos of the board BEFORE u remove it and wait till u get the replacement board before u swap out, that way u won't for get what cable went where..
Jan 28, 2015 | RCA 39LB45RQ 39" LCD TV 1920x1080, 60 Hz,...
Volume issues
Seems to have a preset volume for when the tv is turned on. Check the TV menue to find that feature.You may be able to either turn it off, or reset the volume level.
Mar 11, 2014 | Samsung LN26B360 26 in. LCD TV
Blowing fuse on tv
hi there's dead short in the power supply somewhere could be a number of components usually diodes or transistors cause this fault
hope it helps
regards
shaun
Jan 04, 2014 | Magnavox 32MF301B/F7 32 in. LCD TV
22" flatscreen LCD Westinghouse TV.
try use a lowest resollucion 720p and after change to 1080
Sep 20, 2011 | Westinghouse 22" Widescreen LCD Flat Panel...
My HDMI 1 is dull but when i put it on HDMI 2 its clear... and when i go to menu on HDMI 1 picture only can set backlight, contrast and brightness... I cant go to sharpness, color, tint and advanced...
Hi chaz,
I see that your HDMI 1 is having problems when used and on the HDMI 2 everything is ok and clear.
I believe this cannot be fixed since this is going to be a hardware issue, there are no settigns for the HDMI to change any settign rgarding video, the only setting you can get is for the whole LCD TV itself and regardless of what input you use the settings will be the same.
You may need to have that HDMI port check from the manufacturer if you still have warranty on your LCD tv.
I hope this helps.
Have a nice day,
mvincentc
Apr 13, 2011 | Samsung LN26B360 26 in. LCD TV
Hi i have the samesung ln26b360 lcd tv and for some reason when i went off to college like the 3rd day i had my new tv i had to unplus it to move it to the other side of the room well i moved it plugged it...
Dec 30, 2010 | Samsung LN26B360 26 in. LCD TV
I need the remote code for LN26B360 plz
hope this helps   http://tv.manualsonline.com/manuals/mfg/samsung/ln26b360_tv.html
Dec 12, 2010 | Samsung LN26B360 26 in. LCD TV
I have a samsung 26" LN26b360c5d lcd tv. the unit acts to power up, makes the start up sounds, but there is no picture. I tried putting a flashlight to the screen to try and see any image. but saw nothing....
hi,
your lcd ip board (power board) capacitor had already exhusted.
got to replace the ip board. even if the caps look fine you would not know if the transformer coil is working ;)
Feb 12, 2010 | Samsung LN26B360 26 in. LCD TV
Viewsonic 19
Hi...there,
But of course...it's can. Asked him if the LCD Monitor got any power (a green light on) If it has, switch cables, if it have a DVI connection used that cable and see if it work. Still had a problems...Then the backlight is burnt out. Have a nice day!
Sep 07, 2008 | ViewSonic VX924 19" LCD Monitor
Samsung LN26B360 26 in. LCD TV Logo
162 people viewed this question
Henry  Thomas
Henry Thomas
