Question about Gaggia Syncrony Compact Digital Espresso Machine
I have the gaggia syncrony digital. Whenever i brew or steam water pours out of the bottom behind the drip tray. Gasket issue? Where can i find replacement parts?
  • 2,509 Answers
Http://www.espressoparts.co.uk/gaggia.asp
If you happen to be in the UK
Posted on Dec 30, 2010
Bunn pour omatic commercial coffee maker will not brew and it leaks
VPR is a pour over "Volume Displacement" brewer. Required to completely fill the inner tank and heat prior to using brewer. BEFORE plugging in unit, water must be poured into upper tray and with brew funnel and empty pot in place. Keep pouring water into top fill tray until water drips out of brew funnel. Plug in VPR and allow it 15-20 mins to heat up. leave the pot as there may be additional water dripping. Remove power if there is any water spilling out from other places like the top pan cover or bottom of machine. With the initial heating done, take a full pot of water and slowly pour into the top filling tray. HOT steaming water should come out of the brew funnel to fill the (empty) pot. Prep is done and the machine can be used to brew a pot after 10-15mins of reheat time.
*** the machine you have needs to be checked for leaks in areas mentioned above. Water should only come out of brew funnel (if not present then the brew head or if that is missing then the brew pipe. All will need to be replaced prior to brewing.) Leaking under machine is an indication of leak(s) in pour tray,tank,tank cover, gasket, probe gasket. This machine like any used equipment should be checked out by qualified tech prior to use. Be aware that coffee vendors sometimes rent or loan brewers to customers.
Nov 08, 2017 | Bunn NHB Coffee Maker
Gaggio syncrony, water leaking from bottom after coffee is made
Remove the brew unit and clean the small hole under the white plastic valve make sure the little drain from it leads into the drain tray is clear.
Jun 25, 2011 | Gaggia Syncrony Compact Coffee...
I have a gaggia syncrony logic that has just come back from the repairers.! The coffee dregs are almost liquid whereas before they were solid patties & liquid is found in the drip tray after every...
The coffee grind could be too fine and or not enough coffee is being added to the brew chamber after the machine grinds it. You can try to adjust the amount of coffee being used for an espresso and or adjust the grind.
May 20, 2011 | Gaggia Syncrony Logic 74884 Espresso...
Error message: 'brewunit is blocked' and i cannot get the brewunit out of the machine to look at it. it is stuck pretty hard. dont want to break it...any suggestions?
Hi
Your showing a Syncrony but this is for a Syncrony Compact. They are different.
Open the door. Remove the drip tray, dredge drawer. On the left side and towards the back of the brew group, there is a single screw in the brew group. If you can't get the dredge drawer out, just move it as far to the left as you can to get to the screw. Remove the screw. Grab the handle, squeeze and pull carefully, but firmly fast. Everything will come out (drip tray, dredge drawer, brew group and there might be water in the drip tray). The brew group should come out. There is a piece that remains in the machine. Slide the piece down and to the right and it will come off. Insert the piece into the hole on the backside of the brew group with the clip up. Tighten the screw and move brew group back into position.
To return the brew group to the centered position, you first need to drop the funnel. To do this, look on the opposite side of the brew group from the handle. At the top you will see an object that looks like a sharks fin. If you follow this piece down you will see 2 horizontal bars on the brew group body. Push your finger between these 2 bars and the funnel will drop. Now you can push the puck slide on the left side down and then to the center of the brew group. If you look down through the funnel you should see a piston. This should be centered in the funnel. If not just push the slide to the right until it does. Push the press button and you are now ready to reinsert the brew group into the machine. First you must insert the dredge drawer back into the machine. Close the door and turn on the machine without having the brew group in. You will hear the motor turn on and when it stops completely, pull out the dredge drawer, drip tray, then open the door and insert the brew group. Slide the drip tray,dredge drawer back in, close the door and test.
May 14, 2011 | Gaggia Syncrony Compact Digital Espresso...
We have a Gaggia Syncrony Logic that is just over two years old. After each brew cycle, the puck is successfully ejected but water and some grounds flow out under the drip tray instead of into it....
Hi
Check the drain behind the brew unit. There is a pocket below the injector that can plug up and cause water to drain under the drip tray. Check this first. Stick you finger in the pocket and see if there is water in it. If there is, the drain below and to the right is plugged and just needs to be cleaned.
Dec 09, 2010 | Gaggia Syncrony Logic 74884 Espresso...
My Gaggia Synchrony is leaking - If I remove the water catch basis, I can see a drip. We have used this machine every day for years - can the problem be fixed easily?
HI
There is a panel behind the brew unit, that has 2 screws. Remove it and clean the coffee residue behind it. That is what drains the pressure relieved after brewing, and has coffee residue that can build up and cause the leak. It should leak into the drip tray though, except when you rremove it.
Oct 23, 2010 | Gaggia Syncrony Compact Coffee...
Gaggia Syncrony logic rapid steam machine leaks water from bottom
Check the chamber under the white plastic valve behind the brew unit, it might be blocked with coffee.
Apr 13, 2010 | Coffee Makers & Espresso Machines
Syncrony digital gaggia coffee maker leakage+ventilate message
Just try to pour some hot water out from the steam wand after some seconds the veltilate massage will go out.
Good luck
Feb 02, 2010 | Gaggia Syncrony Compact Coffee...
Gaggia syncrony compact is leaking. Removed top and it appears it is leaking from the area that the line goes into the steam knob. Doesn't leak when using the steam knob, just when brew coffee
Hi What color is the steam manifold? It is located under the black cover with the trough in back under the whit tube. If its whit or black it probably needs to be replaced. If you cool down the manifold after steaming you can prevent this from happening. Just turn off the steam and then open the knob again to run water. It comes out steam at first but then will turn to a water stream. Then you can close the knob and go about brewing or just let it stand.
Jun 14, 2009 | Gaggia Syncrony Compact Coffee...
Water hissing at back of brew unit after coffee made
I think you have to replace the steam valve.
Have you descale your machine regulary?
How old is your machine?
Maybe your boiler have to be replaced:-(
Jul 25, 2008 | Saeco Incanto Classic Espresso Machine
Gaggia Syncrony Compact Digital Espresso Machine Logo
215 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Oloyede Monsuru
Michael Vincent Cruz
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
