Question about Toshiba REGZA 52RV530U LCD TV
We have a purple vertical line about half down the screen sometimes it works fine for a little while when we turn it on and about ahalf hour later it goes back to a purple streak
  • 10 Answers
Was the TV manufactured in 2008? What is the model?
I have a failing LCD panel and am starting a class action lawasuit against Toshiba becuase there is a high number of failing units built during this time that Toshiba is not addressing and their customers are not being herd... well I am going to make them listen!
let me know if you want to be part of this activity.
andedwar@cisco.com
Posted on Jan 06, 2011
  • 1 more comment
  • billyboot Apr 14, 2011
    i got the same problem with toshiba regza 52` screen gone 2 years old....toshiba done nothing said to bad!!!! model#52rv535u
    serial#am4120002265
    my email is billy.boot@hotmail.com
    im pissed
  • tbonnette007 Aug 02, 2011
    I have same issue with my Regza 52' screen model 52RV530U. Bought in 2008 and lines started yesterday and will not stop. It splits the screen right down the middle. Trouble shooting per guide is not the answer. I hate the fact that you pay well over a $1000.00 for product that has a 2 to 3 year life span with moderate use. Not holding much hope for help on this one from what I am reading here. tbonnette007@yahoo.com
  • sail444
    sail444 Sep 08, 2011
    Have same issue with 52rv53u, built in July 2008, purchased at Costco Aug 2008. Vertical multicolor bands, about 6 inches wide, a bit left of the center of screen. Always there, even with no video input of any kind.
Purple laptop display
Sounds like you either cracked the screen (does it get more colorful with a little pressure?) or that the video cabling has come loose at either the motherboard or the lcd. Find a tear-down video for your laptop model and check these connections. Reseating them should be fairly straightforward.
Nov 10, 2012 | Toshiba Computers & Internet
Display problem after bulb change
the vertical display IC must have gone..
you need to replace it
Jun 01, 2008 | Optoma HD70 DLP Projector
NO PICTURE
Turned the Tv seton had only half a screen tried to used the remote to reset the set to is regular settings it reset but the picture was offset to the right of the right of the screen I the brought up the menu in hopes of using the vertical or horizontal to bring it back full screen and the remote stop functioning for the tv and i put new batteries in it thinking matbe the remote was down but to no avail it still didnot work I had to unplug thr tv for about an hour and plug it back up for the remte to work and still had only a half of sreen and now i have sound and no picture just a green screen
Nov 15, 2008 | Televison & Video
Vertical Grey Lines- WD 52327
Good Day, sara926;
Suspect the Light Engine part # 939P977010. This is an expensive item. So, I would suggest that that contact the manufacture and asked them if could give a concession for this; part and labor. They may not give labor but most times they will give you the part.
Good Luck, Big Irish.
Jun 23, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi VS-45607 45" Big Screen
Good Day, Delano1981;
It may cure the problem but I would suspect the 9 Volt source
CHECK C2P05 100 UFD 16 V OFF PIN 3 OF IC2P01 AND
IC2P01 PART # 270P466020 (9-VOLT REGULATOR). BOTH
ARE ON THE SIGNAL PCB.
This should resolve your TV"s condition.
Good Luck, big IRISH.
May 27, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Vertical line
Hi Abouttime
This is unfortunately a sign of Mainbaord damage to any make of Projector.
But do give this a go , you've got nothing to lose.
Try using a different signal cable and then pressing Auto on either the remote of the Projector or the Projector it self once the line appears.
Thanks for using Fixya !
May 22, 2008 | Optoma EP719 XGA DLP PROJECTOR 2000L...
Black Screen with vertical lines down the side?
· http://esupport.sony.com/perl/news-item.pl?news_id=24
· Which models are affected with the "flicker" problem?
A1: There are 12 models in total: KDP57XBR2, KDP65XBR2, KP46WT500, KP51HW40, KP51WS500, KP57HW40, KP57WS500, KP57WV600, KP57WV700, KP65WS500, KP65WV600 and KP65WV700.
Jan 03, 2008 | Sony KP-57HW40 57" Rear Projection...
Horizontal lines obstructing the second half of the ti 83 calculator screen, anyone know repair tips?
I had the same prob with vertical lines on the screen, and getting messed up when there was lots of numbers on the screen.
Solution: Change your batteries. Put some freshies in then adjust your contrast until you see the little black box. If you still have a problem with the lines, darken the screen until it's black (2nd up repeatedly) and let it sit for a couple minutes. Lighten your screen back to normal (2nd down) and turn off then turn her back on.
Jan 17, 2007 | Texas Instruments TI-83 Plus Calculator
Vertical Green/Purple Lines on lower half of screen
I would contact RCA if the repair center dosent know how to troubleshoot this set. But I bet its an eeprom or ground issue. Contact RCA here at 580-634-0151 or At https://www.rca.com/secure/service/contactrca/1,,,00.html Good Luck
Jun 15, 2006 | RCA Scenium HD65W20 65" Rear Projection...
Toshiba REGZA 52RV530U LCD TV Logo
369 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
