Question about Garden
What the mixture of oil and petrol? - Garden
  • 8,404 Answers
Usually, 52 to one (but it could be 30 to more than 50) ... Your owners manual should tell you exactly. Get the oil that is made by or for your machine and it will tell you how to mix. Usually, one small bottle per gallon of gas.
Thanks for your visit today.
Posted on Dec 30, 2010
What is the petrol to oil ratio for this engine
http://www.csgnetwork.com/oilfuelcalc.html
In the Mix
All STIHL gasoline-powered equipment uses a 50:1 gasoline/oil mixture. The chart below can help you figure out the correct measurements to use. For high-performance fuel that requires no mixing, choose STIHL MotoMix® premixed fuel.
Jul 20, 2015 | Garden
Plug is oiling up after 15 min of running
Either:
1. If it's a two-stroke the oil/petrol(gas) mixture could be wrong. if you mixed it last year or left it in the tank, the petrol (gas) will evaporate leaving the oil behind making it too oily and fouling the plug.
2. The mixture is too rich - the plug will be sooty and smell of petrol. Check carburettor adjustment and float height.
3. There is lubricating oil entering the cylinder, either worn or broken piston rings or (four strokes only) worn valve guides
Mar 06, 2015 | Garden
Do i put an oil/gas mixture in gas tank?
the 4 stroke engine only needs petrol in its tank . if your motor has a dipstick for oil it is a four stroke ,,only two strokes requires oil and petrol mix as they have no oil sump in their design
Jun 01, 2014 | Yard Machines 158cc Push Lawn Mower #11a...
I have just bought a 1978 Vespa 125 px I can't get leaded petrol what can I use ?
The old PX from 1977-1981 need a 2% 2T Oil mixture in the Petrol or it will be broken in an instant....!
The mix should always be 2% oil = ratio 1:50
for 1 Gallon Petrol = 2,6 oz oil
(1 liter =20ml / for 5 liter =100ml of 2stroke oil)
- you better get an oil measuring jug to be sure -see photo
leaded petrl is not needed
Jul 18, 2012 | Peg Perego Vespa Scooter
What is the fuel mixture?
hi there
pfrolander
the ratio of oil to petrol you should use is 50:1 ( that is 20 mils of hi quality 2 stroke oil per 1.0 litre of petrol you mix ) using hi quality sthil / husqvarna 2 stroke oil
1000 divided by 50 = 20 mils of oil per 1.0 litre of petrol
NOTE if you do not have any hi quality 2 stroke but some from your local garage ( that you may use in say a scooter for example use 40 mils of oil per litre it is richer
this will do the job
cheers hope it helps
May 27, 2011 | Ryobi 30cc 17" String Trimmer Zrry30530...
Regarding makita petrol disc cutter dpc6410- how much oil do i need to add to a full tank?
Don't add oil to the fuel tank, it doesn't mix well in there and you'll almost always use too much oil. Mix your two-cycle oil and petrol in a gas can to get a 50:1 mixture. Read the directions on the two-cycle oil bottle for how much to use and put the oil in the can first so the petrol will mix well with it as you add it to the can.
Oct 11, 2010 | Makita DPC6410 64cc 12" Power Cutter
Do you have to make a petrol/oil mixture for briggs ans stratton lawn mower engines?
Typically no, it uses gas only in the fuel tank and oil in a separate tank. To make sure do you have a separate cap for oil? If yes then you only use gas not a mixture of gas and oil.
Aug 18, 2010 | Briggs & Stratton Garden
Fuel oil mixture for 1986 mercury 115
I own a small Mercury outboard so I did alittle reading in the manual and the ratio for your 86' 115 HP is 50-1. Hope it helps. Coach Theune
Oct 25, 2009 | Boating
What oil to petrol ratio does this engine run on?
http://www.briggsandstratton.com/maint_repair/manual_and_more/
Go here and enter the proper information, and see if they have the manual available.
Apr 18, 2009 | Husqvarna Garden
Garden Logo
11 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
