Question about Yahoo Messenger
When I Try To Sign In, It Says "Messenger Encountered A Connection Problem, Please Check The Network Connection And Then Click "Try Again", (81003004)
    President:
  • 2,291 Answers
Click the "Messenger" menu in Yahoo! Messenger and select "Connection Preferences."
2. Enable the "No network detection" option and then click the "OK" button at the bottom of the window.
3. Yahoo! Messenger will ask you if you want to sign in again with your new proxy settings. Click the "OK" button.
4. Enter your Yahoo! ID and password and click the "Sign In" button.
you may have a registry problem download registry cleaner reginout to fix the issue
Posted on Jan 03, 2011
3 Suggested Answers
craigjamesbt
  • 65 Answers
SOURCE: messenger problem
click the "messenger" menu and select "connection preferences" Select "Firewall with no proxies" click "Apply" you should see a message asking you to sign in again click "oK"
info found in yahoo help here is the link
http://help.yahoo.com/l/us/yahoo/messenger/messenger9/messenger/mstanoconnect.html
Posted on Apr 26, 2009
  • 32 Answers
SOURCE: login error 81003004 from Yahoo Messenger
Are you behind a firewall (like one in schools) or using proxy??
If so, see any options are available to change the connection settings in yahoo messenger before connecting.
Posted on Jun 02, 2009
AFETR SIGNING-IN, A MSG. HAS BEEN DISPLAYED (YAHOO MESSENGER HAS ENCOUNTERED A NETWORK PROBLEM . PLS. CHECK THE NETWORK AND THEN TRY AGAIN). HOWEVER, NETWORK CONNECTON IS STILL ON. BUT, NOT GET CONNECTED...
Please check your internet connection setting if your network is enable and working properly. To solve this just click on your internet network or connection icon and click on repair, to repair it , if not you can get internet connection which means you can connect the internet.
Aug 09, 2010 | Yahoo Messenger
Tip
To sort out your yahoo messenger problems please read carefully this detailed...
<br /> Hallow Friend, <br /> If you have tried restarting <span>your computer</span>,signing in with your <span>Yahoo</span> e-mail prefix (without the @yahoo.com)and your e-mail password without success, and you are sure your caps aren'tlocked and your information is correct, your <span>Yahoo! Messenger</span> connection information maybe incorrect. Follow these steps to configure your connection:<br /><br />Solution 1.) Click <span>theMessenger menu</span> in Yahoo! Messenger and select "ConnectionPreferences."<br /><br />Enable the "Firewall with no proxies" option. <br /><br />Select the <span>correct Internetconnection type</span> and country from the pull-down menus.<br /><br />Click the OK button at <span>thebottom</span> of <span>thewindow</span>.<br /><br />Yahoo! Messenger will ask you if you want to sign in again with your new proxysettings. Click the OK button.<br /><br />Enter your <span>Yahoo!ID</span> and password and click the "Sign In" button.<br /><br />The above configuration works in most situations. (However, if you connect inthis way, you won't be able to use the Voice feature.) If this configurationdoesn't work, follow these steps:<br /><br />Click the Messenger menu in Yahoo! Messenger and select "ConnectionPreferences."<br /><br />Enable the "No network detection" option and then click the OK buttonat the bottom of the window.<br /><br />Yahoo! Messenger will ask you if you want to sign in again with your new proxysettings. Click the OK button.<br /><br />Enter your Yahoo! ID and password and click the "Sign In" button.<br /><br />If neither of the above options work (sorry), you're probably behind a firewallor <span>proxy server</span>that requires you to enter its address. Follow these steps:<br /><br />Click the Messenger menu in Yahoo! Messenger and select "ConnectionPreferences."<br /><br />Enable the "Use proxies" option.<br /><br />Enter your firewall or proxy server's address and port number. Contact your <span>network administrator</span>(if you're at work), or your <span>Internet service provider</span> (if you're athome) to determine the correct firewall and proxy settings.<br /><br />Click the OK button at the bottom of the window.<br /><br />Yahoo! Messenger will ask you if you want to sign in with your new proxysettings. Click the OK button.<br /><br />Enter your Yahoo! ID and password and click the "Sign In" button.<br /><br />If you try all of the steps above and Yahoo! Messenger still can't connect,contact your network administrator, Internet Service Provider (ISP), or theperson who initially set up your computer to ensure that your firewall and/orproxy settings are correct.<br /><a href="http://help.yahoo.com/l/us/yahoo/messenger/messenger8/messenger/messenger-11.html">http://help.yahoo.com/l/us/yahoo/messeng...</a><br /><br />Solution 2.) You may have accidently saved your ID or password with errors init. To resolve this issue, clear your cache.<br /><br />For <span>InternetExplorer</span>:<br />Click on: Tools<br />Click on: Internet options<br />Click on: Delete Cookies<br />Click on: Delete <span>Temporaryfiles</span><br /><br />For Firefox:<br />Click on: Tools<br />Click on: Clear private data<br />Check: All the boxes<br />Click on: Clear private data now<br /><br />Now try to log onto <span>Yahoo Messenger</span>. <br /><br />Solution 3.) If Step 1 and Step 2 don't solve your sign in issue, tryun-installing then re-installing Yahoo Messenger:<br /><br />Close Yahoo Messenger<br />Click on: Start<br />Click on: <span>ControlPanel</span><br />Click on: Add/remove programs<br />Locate and remove Yahoo Messenger<br /><br />Download Yahoo Messenger:<br /><br />Yahoo Messenger for Windows: <br /><a href="http://messenger.yahoo.com/">http://messenger.yahoo.com</a><br /><br />Yahoo Messenger for Vista:<br /><a href="http://messenger.yahoo.com/windowsvista.php">http://messenger.yahoo.com/windowsvista....</a><br /><br />If you are still unable to sign in, on Internet Explorer:<br /><br />RESTART YOUR COMPUTER<br /><br />If that doesn't help, here is a link to <span>Yahoo Help</span>:<br /><br />IMPORTANT: If all of the above does NOT solve your problem, here is a link to <span>Yahoo! MessengerHelp Form:<br /><a href="http://help.yahoo.com/l/us/yahoo/messenger/messenger8/help8.html?from_url=http://help.yahoo.com/l/us/yahoo/messenger/contactus/contactus-01.html">http://help.yahoo.com/l/us/yahoo/messeng...</a><br /><br />For future reference, please note there is a link to Yahoo Messenger Help atthe very top of your Yahoo Messenger!</span>
on Apr 27, 2011 | Computers & Internet
Yahoo messeger cannot sign network encountered a coonection problem
May be u using any kind of proxy...to check it open IE ...click Tools>Internet options> Connections> Lan settings > Unchecked the Box written for [Use a proxy server for you LAN(This setting will not apply to Dial-up or VPN setting)]
or
open Yahoo messenger click Messenger> Connection Preferences>In the Network or Internet connection >select Connect directly to the Internet> Apply > OK.....
If you still facing the connection issue ..try uninstall yahoo messenger, download and install latest version of Yahoo messenger ..if that doesn't help ...may be that is blocked by your network administrator or ISP ..contact them for solution...Good luck
Sep 18, 2009 | Yahoo Messenger
I cannot sign in to my mssnger
I can not sign in to my e mail account.
Jul 09, 2009 | Yahoo Messenger
Network connection try again 81003004
your not getting connected for some reason.do other sites load ok!
Jun 12, 2009 | Microsoft Windows XP Home Edition
When I try to sign into Yahoo Messenger 9.0 I get this error message "Messenger encountered a connection problem. Please check the network connection and then click try again. (81003004)" I've changed my...
You might have some options to fix it: firstly; this error occurs when your connection preferences are not properly set. I'm not talking about your Yahoo! ID and Password here, but you may need to adjust certain features depending on what network you're on. Maybe, i think you should check your firewall settings. If you use Personal Firewall, make sure it allows your connection to receiving incoming connections and allows you to use yahoo messenger,check it out, may be it blocked your yahoo messenger. if a firewall protects your network, it may block yahoo messenger when it tries to connect to the server. You need to change your connection settings, click the Messenger menu in yahoo messenger and select Connection Preferences. Select Firewall With No Proxies. Select your Internet Connection type from the pull-down menu at the bottom and enter your Home Country if the adoptions aren’t grayed out. Click OK and login again using the new settings. If this option doesn’t work, click Connection Preferences in Yahoo! Messenger again and select No Network Detection. Try to login again using the new settings. In some instances, you may need to provide yahoo messenger with the IP address of your firewall or proxy server (you can get this information from your network administrator or from your Internet service provider). Click Messenger and select Connection Preferences again. Select Use Proxies. Enable either the HTTP Proxy or the SOCKS Proxy as needed and provide the proper address. Click OK and login again using the new settings.
Or other way, open your Internet Explorer>Go to File>Then, 'uncheck Work Offline', make sure your Internet connection is not working offline. Then, close Internet Explorer, try to sign in your yahoo messenger.
thirdly, if you are using IM9 there are sign in problems. This is what yahoo has to say. Try an updated version of Yahoo! Messenger 9.0(9.0.0.2128). This latest build includes a fix for the sign-in issues that have been affecting some users. If you were seeing an error code“81003004” when trying to sign in, this latest version may fix that problem. Even if you were experiencing a different kind of sign-in issue, I recommend installing this latest version. Hope it was helpful and it works to solve your problems.. Please kindly support me.. Thank You!
Jun 10, 2009 | Yahoo Messenger
I cant log into my yahoo messenger
internet explorer might be offline... open iternet explorer and connect it to the internet... it worked for me
May 03, 2009 | Yahoo YHT-630 System
After i install yahoo messenger this script shows up ..
i cannot sign in to yahoo messenger. it keeps on saying "messenger encountered a connection problem. please check the network connection and then click "try again". (81003004
Apr 25, 2009 | Yahoo Messenger
Messenger problem
Feb 26, 2009 | Yahoo Messenger
When i log on it says Messenger encountered a connection problem. Please check the network connection and then click try again (81003004)
Is this Yahoo messenger? if so,try this:
Click messenger / Choose connect via a proxy server/choose http proxy
Joe
Oct 09, 2008 | Computers & Internet
Yahoo Messenger Logo
107 people viewed this question
Top Yahoo Computers & Internet Experts
micky dee
Mike
fixrfast
Level 1 Expert
Are you a Yahoo Computer and Internet Expert? Answer questions, earn points and help others
