Question about Dyson DC11 All Floors Bagless Canister Cyclonic Vacuum
The beater bar doesn't rotate - Dyson DC11 All Floors Bagless Canister Cyclonic Vacuum
If you have anyone in your house with long hair you'll probably find that it has hair wound around the shaft that spins. It's possible to take the whole thing apart & strip it down to the bare shaft & you don't need any tools. Turn the head upside down, and slide the flat clip that is at the back of the underside further backwards to unlock the back of the bottom plate. Then turn the two round latches on the back of the cross-arms of the head about 1/4 turn anti-clockwise, this will unlock the front edges. You should now be able to remove the bottom plate of the head. Once you have the head off, remove any hair and dust you can see, and if you hold the two ends of the beater and twist them gently against each other one way or the other, you will hopefully find that the beater comes loose on the shaft and the two black beater sleeves with the brushes on them can be slid outwards & removed. Once you've taken them out, thoroughly clean them (you can wash them in water) and carefully pull out any hair that is wrapped around the shaft, bearing in mind that some could have gone in under the edge of the plastic part that the shafts poke out of. Once you've got everything as clean as you can (I washed all the pieces of the head) and dried it all off you can put it back together again in the opposite order that you pulled it apart.
Posted on May 28, 2011
The beater bar in my machine will not rotate just makes a squealing noise
It could be that the bearings in the beater bar are shot or are full of dirt or pet hair. A new beater bar will fix the problem.
Dec 25, 2017 | Vacuums
I was told by a previous repair man that there is a fuse in the beater bar that needed to be replaced.
Up to my experience in my Panasonic vacuum cleaner, if the beater bar is not working this could be because the 'Carpet/Floor' selector switch is in the 'OFF' or 'FLOOR' position. In both of these positions the beater bar will not rotate. Move the selector switch to the 'CARPET' position. When in this position the beater bar will rotate once the foot pedal is pressed.
If the selector switch is in the 'CARPET' position and the beater bar is still not rotating it could be that there is something entangled in the beater bar, or the belt is worn or broken.
To check this first unplug the vacuum cleaner
Inspect the beater bar and belts to ensure that there is nothing entangled in the beater bar and that the belts are intact and are not excessively worn. If the belts are excessively worn they may slip resulting in the beater bar not rotating.
The vacuum cleaners often have an overload protection system inside the nozzle, which stops the nozzle motor when the beater bar jams to prevent belt breakage. After clearing any lint build up or jamming you may need to reset the overload protection, by pressing the reset button on the top of the floor nozzle.
May 04, 2015 | Vacuums
Installing new belt
+>> Unplug the mains lead from electrical socket <<+
• Turn cleaner over in flat position.
• Release lower plate by rotating the 3 lower plate latches to the UNLOCK position.
• Remove lower plate and remove any dirt that may exist in belt area.
• Remove beater bar by gripping the belt side of the beater bar and carefully lifting it out.
• Remove worn or broken belt.
• Clean beater bar and the end caps.
• Loop new belt around motor shaft and beater bar belt groove.
• Reinstall the beater bar by inserting the end cap of the beater bar to the slots at both ends of th beater bar.
• After reinstalling the beater bar, turn it by hand to make sure that belt is not twisted or pinched and that all rotating parts turn freely.
• Reinstall lower plate by hooking front end of lower plate into slots on front of nozzle.
• Press lower plate onto nozzle and secure by rotating the 3 lower plate latches to the LOCK position.
Jan 12, 2013 | Panasonic Mc-Ul594 Eco Max - Bagless...
Miele model SEB217-3 beater bar stooped working
Check the switch .It usually have a wiring diagram
Jan 25, 2018 | Miele Vacuums
DC15 - beater bar is not rotating
There is a tiny motor for the bar itself at the side of the bar you will see tiny slits which is the vent for the motor which is most likely burned out and will need a replacement.
Apr 11, 2010 | Dyson DC15 All Floors - The Ball Bagless...
Beater bar not rotating
Remove the screws from the bottom of the power head.
Oct 09, 2009 | Panasonic Kenmore Canister Vacuum Vacuum
Change belt on a eureka
With the vacuum unplugged, turn the machine beater side uo. On the plate that surrounds the beater bar, look for release tabs to open the plate. Flip them and set the plate to the side. The beater bar rides in sockets. Remove the bar, install the new belt around the motor shaft, then work the beater back into the sockets. Replace the plate. Test your work by rotating the beater bar by hand, making sure that it is reinstalled correctly.
Best Regards, --WoobieDog--
Jul 10, 2009 | Eureka Vacuums
There is suction but no rotation of beater bar
replace the drive belt.
turn the vacuum over. take the buttom plate off, you can access the roller (beater). there should be a belt attached to the roller and the motor shaft.
Apr 14, 2009 | Vacuums
Vacuum turns on and suction in hose works, beater bar won't turn
If you hear the motor in the head running and the beater bar isn't rotating, you probably need a drive belt. With the power off, make sure you can rotate the beater bar freely by hand, if it isn't bound up.. then locate and remove the baseplate screws to gain access to the beater bar itself, you'll see a drive belt pulley system and chances are, a broken belt. Replace it with a new one by pulling the beater bar assembly out of the housing and plcing the belt onto the motor shaft pulley as well as the beater bar pulley.. nest the beater bar back into the holder and reinstall the cover. Hope that helps !
Aug 14, 2008 | Eureka Vacuums
Dyson DC11 All Floors Bagless Canister Cyclonic Vacuum Logo
156 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
