How to program an apex rm-1010w remote - Televison & Video
2 Suggested Answers
SOURCE: Apex Digital GB4308 remote
Programming the Remote Control Remote-control switchover Press VCR/DVD, SAT/CABLE or AUX to select the device you want to control. To program the remote control Press and hold VCR.DVD, SAT/CABLE or AUX for over 2 seconds until the LED on the remote control turns off. Release the button the LED will light again (the remote control enters the PROGRAMMING mode). Enter three-digit code number for your equipment. If the correct code number is entered, the LED blinks three times. If you enter a code not listed below, or you press any other buttons than SEARCH and 100+, the LED turns off. To search codes Press ad hold VCR/DVD,SAT/CABLE or AUX for over 2 seconds unil the LED turns off. Release the button (the LED wil light again) and the remote control enters the PROGRAMMING mode. Press SEARCH. Press CH+/- to search codes downwards or upwards. Each time you press CH+/-, the code number decreases or increases by 1 while the remote control sends the code number for POWER button on your device. If the desired code number is found,press 100+ to program the code for your device until the LED blinks three times.Then the remote control exits from the PROGRAMMING mode and returns to norml operation. Or press any other button to exit from the PROGRAMMING mode after the LED blinks rapidly eight times, and the operation is not active. To check the current code number Press and hold VCR/DVD, SAT/CABLE or AUX for over 2 seconds until the LED turns off. Release the button (the LED will light again) and the remote control enters the PROGRAMMING mode. Press 100+ . You may read the code numder according to the LED display status as follows. * If there is no operation within 20 seconds during the steps mentioned above, the remote control will automatically exit from the appropriate operation. Code Number First - digit 0 1 0 1 Second - digit 0 0 4 5 Third - digit 0 6 3 0 First - digit Blinks rapidly once Blinks once Blinks rapidly once Bliks once Secod - digit Blinks rapidly once Blinks rapidly once Blinks four times Bliks five times Third - digit Blinks rapidly once Blinks six times Blinks three times Bliks rapidly once
Posted on May 01, 2007
SOURCE: How do you program the Sony rm-p311 remote
You may wish to clear the remote's memory before starting. Slide the top left switch to "Learn." Press ANY button on the remote, do not worry if the indicator light flashes. Press the "Program Clear" button. The indicator should flash 4 (maybe 5?) times. You are now ready to program. Make sure the switch is in the "Learn" position. Place the rm-p311 and the remote you want to program in about 2 cm apart facing each other. Push the button you wish to program on the rm-p311. The indicator light should come on with a slight delay. Press and hold the button on the other remote until the indicator light goes out. Put the slider back to "User" mode and test it! For more info., go to sony's support site and search for the user manual for the STR-AV1070 receiver. It contains instructions for the remote.
Posted on Aug 20, 2011
Need TV and DVD codes
0408 0421 0469 0654 0767. Try these codes. If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" view. It will make surf easier.
http://electrohelponline.blogspot.com/
Mar 21, 2014 | Apex Digital APEX RM-1010W Remote Control
I need the JVC TV Remote code for the Apex RM-1010w remote
Codes to check with JVC TVs are: 0060 0026 0197 0069 0247 0923 0012 0065 0067 0141
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
If you wish to get more details, check this.
Dec 28, 2012 | Apex Digital APEX RM-1010W Remtoe Control
How do I program my Direct TV remote so my Apex ad-1200 dvd player works
How do I connect JVC DVD Video recorder RM-SDR107U remote to Sony TV?
Sep 11, 2011 | Apex Digital AD-1200 DVD Player
Whats the code for an Apex DT 504 converter box, I have a Sony RM-vz220 universal remote
try the Samsung codes. Apex used their chassis for a while.
Please let me know if this works
Good luck and rate FIXYA when its done :)
Mar 28, 2011 | Sony RM-Y168 Remote Control
The remoate that came with tv is not turning the unit off or on . we have tried to program a universal remote it the tv will not takr the codes. what are we doing wrong?
You may have the problem in the IR receiver in the TV itself.
Is the remote code for APEX listed in the remote user manual? Brand of this remote?
Not too may universal remote will support APEX DIGITAL TV, you can try SONY universal remote RM-V210 which has APEX TV in the listing
http://esupport.sony.com/US/perl/model-remote.pl?mdl=RMV210#
Mar 25, 2011 | Apex Digital LD4088 LCD TV
Trying to program Sony RM-V202 universal remote for an APEX tv
Press SET and POWER button at the same time, press TV,press and release the CH+ button,then press and release the POWER button, each time you press CH+ and POWER button a code is entered. Keep trying until the TV goes Off. It may take 70 trys, when it does turn off press ENT.button to save code. hope this helps..
Apr 01, 2010 | Sony RM-V202 Remote Control
Need remote control for my Apex Digital DVD player (model 1110W)
DVD remotes typically have 2 sets of up and down arrows for such things. Make sure the remote you purchase is meant for dvd players.
There really isn't anywhere to search for what remote would work perfect for you other than some very costly ones. So I can't really point you in the direction of a make or model.
You can also Email Apex Support and ask them for a replacment remote. It will cost you but no more than a normal remote and its made for your dvd player.
Thank you for stopping by Fixya!
May 20, 2009 | Apex Digital AD-1110W DVD Player
Televison & Video Logo
111 people viewed this question
Top Televison & Video Experts
Electro Med Services...
