Question about Black & Decker Spacemaker 10-Cup Coffee Maker
Was working fine until this morning. Loaded with water and coffee and turned on. Nothing happened. Could element have burned our? Is there a reset button inside the machine? HELP!! I need my coffee in the morning.
    New Friend:
  • 47 Answers
This problem seems to happen quite often. If the symptoms are similar to those posted in this string try the solution posted at the bottom. It seems to fix it most of the time.
Posted on Jan 09, 2011
I have no hot water - circuit breaker tripped to water heater. I removed top front panel and pushed the reset button but nothing seems to be happening
your elements are burned out,be care ful when resetting if they are blown then you could send electricity through the water pipes,call a plumber or replace them yourself,turn off breakers,drain all water,unscrew the 4 screws that hold each element in and slide them out,dont damage or turn anything on the reset or connectors,take them to a parts store and buy two of them,they are about 25 bucks a piece
May 22, 2015 | Water Water Heaters
I did something wrong: I left my machine running for about 20 minutes without any water. The machine was turned on and the switch was turned towards the "coffee" sign. The red/orange lights are still...
Hello 'lord tatien', from my research I suggest you call 1-866-273-8455 8a to 5p Pacific time. I couldn't find technical info on line. You may try this, unplug unit overnight. It should have an internal over/temp power breaker on the heating element witch would reset after cooling off.
Oct 21, 2010 | Breville ESP8XL Espresso Machine
Our office has a Gevalia Deluxe coffeemaker. It
Most likely the cycle thermostat that turns off the heating element has failed. It is supposed to reset after the it senses the water temp below 130 deg. If it did not reset or has failed it will not turn on the heating element but the clock will work fine.
By the time you ship the unit to a repair center with parts and labor and get it returned to you the cost would be as much as a new unit.
Thanks for using FixYa.
Kelly
May 13, 2010 | Gevalia CM-500 12 Cup Coffee Maker
I set up our new coffee maker and it didn't grind...ordered it online from Macy's but had no manual and didn't know what to do...put coffee grinds in the top and then set up the timer for this...
You need to swivel the brew basket cover until it locks for the coffee to grind. Then turn the machine on and the coffe will grind. , then turn the machine off, add water and press the auto on to use the auto timer.
Dec 13, 2009 | Krups KM7000
Coffee maker water does not heat
unless you have a real expensive coffee maker, it is cheaper to just replace it at this point. chances are the heating element has burned in two.
Jun 20, 2009 | Braun Coffee Makers & Espresso Machines
Cuisinart Coffe Maker has no power
vinegar is not the best thing descaler vinegar remove calciumin little piece that might block thr rest of machine descaler produit melt calcium 1 part solution 1 part water fill the water tank start machine leave it running for few second turn off for 15 minute and repeat untill empty dont forget to rince the machine very good that stuff is very corosif but does the jobs thanks for using fixya pierre
Feb 09, 2008 | Cuisinart DCC-1200 Coffee Maker
Power light will not come on.
There is a post with a solution for this with the title: "Machine won't turn on - no power! " - fixmebob has a good solution, but you'll need to be a little tech savvy to perform it yourself. I ended up sending mine in for repair, which ended up being about $55 because I had to ship the machine. But good news is that I'm back up and running.
Nov 18, 2007 | Breville Die Cast 800ESXL Espresso Machine
Odc325
I haven't been able to find the base heating element for sale anymore. Best I can suggest is finding one on ebay that still has a working base heater but the water heater no longer works.
Oct 26, 2007 | Black & Decker SpaceMaker ODC325 Coffee...
Cafe Nero turns on, but will not make coffee
I understand this unit has a fuse inside that blows out. I cannot confirm this as I need to find a special screwdriver to open it. I'll post back my results if possible.
Jul 05, 2007 | DeLonghi Caffe Nero BCO264 Espresso &...
Black & Decker Spacemaker  10-Cup Coffee Maker Logo
606 people viewed this question
Top Black & Decker Coffee Makers & Espresso Machines Experts
eyecam
Lyle Siemens
Lyle Siemens
Are you a Black & Decker Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
