Question about Danby DPAC8020 Air Conditioner
Not cooling properly
Begins to operate and cool just fine,after a couple minutes isnt cool anymore..Filters are clean and venting is clear..Low freon??
  • 1 more comment
  • IDA_BAER Jul 12, 2008
    EVERSTAR MODEL 10CCR-1 NOT COOLING
  • Anonymous Jul 30, 2008
    the unit is a year old. The filters are clean. but it no longer draws water from the unit. I have a plastic hose attached but it never gets rid of any water and the unit no longer works as it should.
    Also I have lost the manual and need an explaination of the various buttons
  • iburney Aug 31, 2008
    air conditioner starts to freeze up and makes a clicking, cracking noise. Only about a year or two old.
EVERSTAR MODEL 10CR-1NOT COOLING CLEAN VENTS, STILL NOT COOLING.
Posted on Jul 12, 2008
Optimizing performance in taskalfa 820
When you see "optimizing performance", the machine is going through a cool down cycle and will return to ready after the machine's internal temperature reaches an acceptable amount (usually appears after a large amount of copying). Sometimes I have seen it take as long as 5-10 minutes for the message to clear but if you turn it off before it finishes it's cool down cycle, most of the time the machine immediately shows the message again on display. As mentioned, make sure your filters are clean. I'd also check to ensure your exhaust fans are operational (especially those near fuser area), fuser thermistors clean and in proper position, and ensure machine has proper clearance around the cabinet so it can breath properly.
check the place of the machine.there is not enough cooling temperature for the machine.provide the recommenced temperature 16 to 20 degree.your problem will be solved.
Apr 24, 2014 | Kyocera Ecosys FS-820 Laser Printer 14,499...
I have a V reg 1999 Audi A4 that I am very fond of. Recently when I start the car up it begins to over heat reaching 100oC and a nasty burning smell comes through the vents. After running the car for 10-15...
It could be the thermostat not opening soon enough. It's very risky to run the car while it's overheating. Check to see if the thermostat is operating properly.
Oct 13, 2013 | 1999 Audi A4
I have 2 Mitsubishi electric "Mr Slim" type
Have your system checked by a professional.
From what you are describing here it seems as thoug you have a slight leak in the system somewhere and therefore the system is not cooling or heating properly.
Have them check the system... verify the low charge, fine the leak and repair it.
Vacuum and recharge the system...
Then check the operation before you let them out of your sight.
...It can be tough to get some contrators back if you let them go before you check it...espec. if you pay them...:-)
heatman101
Nov 19, 2010 | Mitsubishi Heating & Cooling
Power Shuts off when making popcorn Why? Only popcorn.......
Popcorn is a very low-moisture food to cook, and cooking low-moisture foods often reveals impending or existing part failure in the microwave.
It may be that you have inadequate magnetron cooling or your magnetron may be going out.
Inadequate cooling can be caused by:
- failing / failed internal cooling fan
- blocked air vent or filter
- microwave cover not installed properly
We have a sound clip of what a microwave should sound like when the cooling fan and high voltage section are operating here.
There should be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, & testing.
At
our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can find links to helpful exploded view diagrams and part ordering help here.
I'd recommend that your bookmark this link to your favorites.
Please note that FixYa is not currently notifying us Experts when Clarification Requests are answered.
To allow us to help you effectively (at no charge), please post a
NEW problem to FixYa, and please include your brand name and the full model number from the tag in or on the unit, your symptoms, as well as the answers to these questions:
Is the internal cooling fan running when you cook?
Are the air vents and filters clear?
Feb 09, 2010 | Daewoo Microwave Ovens
Wont blow cold air
First check and clean the filters, and the evaporator coil. (thats the "inside" coil that has the indoor air sucked through it, cooling it and then pushing it out the vents.
If the filter is clogged or the coils are dirty, it will not cool properly and potentially freeze up.
Also check the condensor (outdoor) coil, if it is dirty/clogged, it will run hot and not cool properly.
If all coils and filters are clean, and the fan motors are running and in good condition and it is still not cooling then you are likely low on refridgerant. (handling/purchasing refridgerant other than R134A requres a CFC certification by law)
Aug 20, 2009 | Heating & Cooling
No more cooling.
check filters and depending on how new the unit is they dont operate as cold as the older units did
May 17, 2009 | Frigidaire FAA065P7A Thru-Wall/Window Air...
Cooling on and off
Behind the filter there should be a small metal tube that senses the temp. entering the unit sometime this is too close to the metal fins and sense the cold from the fins and not the air coming in. Make sure this is away from the fins and try a different temp. setting.And relocating the unit. These units tend to give off more heat that cooling because the hot air is returned to the inside of the room and not vented outside like window units.This is an  EdgeStar 12,000 BTU unit, correct?
Oct 22, 2007 | EdgeStar Portable Air Conditioner Heater
Cooling problems
Check the filters inside and the evap coil to make sure it isnt filthy. The evap coil can be cleaned with a credit card if its wet. The large line outside should sweat all the way to the compressor if its got enough freon. Will freeze when its cool outside or not sweat at all if its low. Good luck with it.
Jul 30, 2007 | Ruud UAKA030 Air Conditioner
Danby DPAC8020 Air Conditioner Logo
778 people viewed this question
Top Danby Heating & Cooling Experts
coolfelix
Level 1 Expert
Dan Webster
Dan Webster
Dennis Boxerman
Are you a Danby Heating and Cooling Expert? Answer questions, earn points and help others
