Question about Philips SAA7130 TV Tuner/FM Radio/Video PCI Capture Card (683728017118)
In my philips SAA1732 fm is not working, if put scan, it scanning my no channel were is found. i connect to outside aerial but it still not detecting any fm stations... what i should do sir, please suggest me... Another problem is when connected to cable tv function working properly but while recording channel problem video only coming audio not coming for the recorded one. what i should do for that sir...
  • 2,509 Answers
You probably need to install a proper fm aerial and diplexer, is your aerial a TV aerial or a radio aerial?
You need to set it for the correct TV system in the software to get the audio from the TV, there will be a number of options like PAL I or PAL M or N. etc They have different sound settings, you need to choose the correct one for your system.
Posted on Dec 30, 2010
Matsui M19DIGB19 will not scan for Channels even though I can tune in other televisions through the aerial connection
There may be no antenna connection as required for detection of channels during scanning.
Aug 01, 2017 | Televison & Video
How do I get rid of Kingdom.uk
Well depending on what type of aerial you have connected....not a sat dish or and analogue aerial but a digital aerial....you should go into menu settings and rescan all free to air or freesat channels ...then once it has finished to 100 % scan .....save list then when you go back to the electronic program guide you will have all the usual stuff.be aware that you can also scan all channels some of which are not freeview and are encrypted so it's better to just scan for FTA channels.hope this is of help....please vote ....thanks.
Feb 28, 2015 | Televison & Video
Signal not found problem
Connect an outside aerial and then run scan on the channel search and programming.
Mar 17, 2014 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Hannspree TV tuning from aerial problem.
do you mean if you hooked up the tv with the aerial antenna can not get any channel? ok if just a white raster only and doesn't scan or tuned even manually and auto search, the cause is bad tuner.
Sep 06, 2012 | Hannspree Televison & Video
I have a brand new technika tv 216/54g. It has freeview built in. I have a brand new indoor digital amplified aerial also technika but I cant get it to pick up any stations. Do I need anything else? please...
You don't necessarily need anything else, but you may not have a strong enough signal to pick up the digital/freeview channels using an indoor aerial. It could also be that the indoor aerial is not correctly aligned.
If the signal strength is lower than approx. 50%, the TV may detect them during the automatic channel scan but it wont store them. When the signal strength for any digital channel is 50% or lower it's more or less unwatchable - the picture would be constantly breaking-up or freezing and the audio drops out continually. Trying to scan for channels using an indoor aerial is rather hit and miss. Numerous attempts may be necessary before you get any channels.
Assuming you have a roof aerial, it is far easier to temporarily connect the TV to a fixed aerial point while you run the automatic channel scan. The TV will store all the channels and you can then move it to it's permanent location and connect the indoor aerial. You can then adjust the indoor aerial with the channels already stored until you find a location for the aerial where you have a good signal.
Doing it this way also eliminates the possibility of a fault with the TV and confirms that you are performing the channel scan correctly. If the TV is connected to a fixed aerial point and you are still unable to receive or store any channels, then it's likely that you are performing the channel scan incorrectly or there is a fault with the TV.
Please try scanning your channels using a known working fixed aerial point. If you are still unable
to receive any channels - or you don't have any fixed aerial points - please post back for further assistance.
Hope this helps.
Regards,
BElectric
Feb 28, 2011 | Televison & Video
Have problem with Philips On digital terrestrial receiver (DV3). Since the digital switchover in Bolton, where I live, it wont let me do an update. Can't get any channels now. Stewart
Try unplugging the unit from the wall, unplug the Aerial cable from the box. Plug the mains back in and switch on. Do a channel scan (with the aerial still unplugged). Reconnect aerial and do another scan. With luck it will have flushed the old settings and pick up the channel changes.
Regards
Zahc
Jun 17, 2010 | Televison & Video
Find channels
You say you`ve plugged the outside aerial lead directly into the DVD recorder aerial input socket, you connected an aerial link lead from the aerial output socket on the DVD recorder and you`ve got a Scart lead from the TV output socket on the rear of the DVD recorder into the AV1 socket on the TV. I`m saying all this because in the past, I`ve had customers say this to me only to find when I call round that they`ve plugged the aerial into phono sockets instead of the earial input socket. The aerial lead will fit physically but not electrically. Have you got a good picture on your TV with the DVD recorder switched to standby?? If yes, Does it play a DVD perfectly through the TV?? If yes, then everything is connected up correctly, When you press the virgin menu button to your DVD, it should show setup/install?? When you do get to the free-view or channel setup/install menu, and you tell it to search for new channels, does it scan?? Does a bar or do the numbers rise and the % number rise as it finds new channels?? If they do and everything is connected and working as I described earlier but still no channels are found, Try unplugging from the mains and reboot your DVD recorder, then repeat the whole menu install procedure sequence again. Other than that, there`s nothing else you can do, Basically, you`ve got a faulty machine where it requires an engineers eye I`m afraid. Ian
Jul 29, 2009 | Wharfedale Televison & Video
I have lost my tv channels!
I have a philips freeview box (although it is not built in). I recently lost all my channels also. It took me back to the installation screen and started to look for channels, furthermore if it couldn't find any it 'bugged out' on me. The only way I got around this was by unplugging the aerial, watching the screen trying to scan the channels and when the progress bar / channel # was near the end plugging the aerial back in. For some reason this started the scanning over again but this time it found channels! Strange I know, but maybe its different for me and one of those conspiracies that they program products to fail after a few years to make you buy more. Try this and let me know if it works Thanks Matthew
Jun 18, 2006 | Philips 26PF5320 26 in. LCD Television
Philips SAA7130 TV Tuner/FM Radio/Video PCI Capture Card (683728017118) Logo
62 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
