Question about GE Spacemaker JVM1640SJ Microwave Oven
Microwave went dark,has power from outlet but no lights or power
  • GE Master
  • 8,404 Answers
Open the cover, find and replace the fuse. It will be located near where the cord comes into the cabinet. Get an exact replacement at your hardware or home center store.
Thanks for visiting today.
Posted on Dec 30, 2010
Hi our microware is not working, can you help me?
I have serviced 100's of microwaves and the most common problems for microwaves not working 1)fuse blow(but display will be dark), 2)not plugged in(or house fuse blown) (microwave display is dark and other outlets would be off) 3) connections to one of the door switches is burnt out. The display is not dark but microwave will not work. The wire going to the switch looks black right at the switch.(this wire must be removed and a new connector attached to wire and then reattached to the switch
Dec 24, 2017 | Microwave Ovens
Microwave went totally dead while operating; there is power to the outlet.
If the control panel lights up intermittently, then you either have a loose connection somewhere near the panel, or a failing component on the circuit board itself.
Jul 10, 2015 | LG LMV1813ST Microwave Oven
Micro wave went dark on display screen, but outlet has power; where is the fuse
The fuse is located inside. The outside cover has to be removed to gain access.
Sep 16, 2014 | Frigidaire Microwave Ovens
Hi I have a Samsung SMH9187 micowave that is dead (no display, light, fan, mirowave).
Sounds like the main fuse blew. It's either near where the power cord enters the cabinet, or behind the control panel (if an over the range unit).
You may also have some type of failure in the high voltage circuit; based on your description of the symptoms.
Aug 16, 2014 | Samsung SMH9187ST Microwave Oven
Baked potatoes went up in flames now microwave has no power no lights. power outlet has 110v ac
Were the potatoes wrapped in foil? If so, the megatron tube was burned out. Replace unit.
Nov 06, 2009 | Kenmore 62622 Microwave Oven
Hi Yes I have a Whirlpool MIcrowave Oven Model # MH7140XFB-1 And It was working fine this morning I went to use it this afternoon and the panel is not working no lights work nothing the fan under neath...
check for a blown ceramic fuse behind the panel. If the fuse is dark in color it is probly bad. you can get one at radio shack store or on line
Apr 16, 2009 | Microwave Ovens
Panosonic nn-t790 microwave
I pulled the top and sides (one piece) of the microwave. Near where the 110 volt line goes into the unit is a standard fuse ( 18 amp). I used an ohmeter on ther fuse and determined that it was not working and replaced it. Problem solved - unless it blows again.
Nov 06, 2008 | Microwave Ovens
GE Spacemaker JVM1640SJ Microwave Oven Logo
32 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
