Question about Char-Broil CharBroil 4637318 Grill
I WANT TO REMOVE A SIDE BURNER FROM MY GRILL TO MAKE IT SMALLER TO FIT ON MY DECK IN NY. I AM SURE I WILL HAVE TO CAP SOMETHING...WHERE DO I FIND THAT CAP?
    Genius:
  • 2,028 Answers
You can find a cap at any hardware store (Home Depot), you'll need the thread size and diameter, and remember thread tape so it doesn't leak.
Posted on Jul 07, 2008
Burners go out
It is most likely something in the tube under the burners. Remove the burners and blow the tubes out or use something flexible that will fit into the tubes. I found dirt dabber bees in mine one time. Other possibilities, would be the obvious, is there gas in the tank?
May 06, 2012 | Weber Ducane Affinity 4400 Gas Grill
One burner of my four burner grill only lights on one side. I have traded places in the grill with other working burners and they work fine in that spot but the one will still only light on one side unless...
If you remove the burner to clean it, did you also check and clean the venturi valve near the open end of the burner, where it fit's over the burner orifice? If not, the venturi is probably clogged. Spiders love to build nest in them. While you have the burner out, inspect it closely for anything you may have missed when you cleaned it the first time.
Hope this helps you and Happy Grilling!!
Jun 25, 2011 | Cal Flame 4-Burner Drop-In Grill
Need photo of how to replace the 5 "V" shaped
The 'V' shaped metal bars are the flavorizer, flame tamer or whatever Weber wants to cal them. They go over top of each burner from front to rear, setting on the ledge of the interior of the grill, just above the burners. make sure that cover each burner equally. Now's a good time to clean them if they have a lot of grease on them.
Since the grill was blown off your deck ... make sure all the burners are intact are not damage and there are no gas leaks from tank to the grill.
Feb 11, 2011 | Weber Spirit? E-310 Propane Grill
Front burner won't get hot
The burner and the orifice may be clogged. To check this, remove the offending burner and tap it lightly on a firm surface. Turn the burner on end, open side down and shake it. If debris falls out that's part of the problem. While the burner is out, check the burner orifice by looking in the brill toward the front control panel, where the burner slides over the orifice. Remove the orifice with a nut driver or appropriately sized sock wrench and check the orifice hole for clogs. If it's clogged, take a sewing needle the same size as the hole or smaller and clean it out.
Reassemble everything and give it a try.
Jan 31, 2011 | Weber Genesis E-310 Gas Grill
Where is the low side sevice port for my air conditioner. I need to charge it up and I'm not sure which one it is?
the low side is the smaller of the two the hose will only fit the small one, this fitting is near the compressor, the cap should have an l on it for low side if not remove both caps anduse the smaller fitting.
Jul 12, 2010 | 1999 Dodge Durango
One side seems clogged, no propane gets through.
More than likely you can fix it yourself. Remove the burner that's not working or if the burners are joined remove the entire burner unit. Check small holes around edge og burner for anything that may be clogging them. I've used a round toothpick or a small nail to poke each hole gently to make sure it's clear. replace the burner and try agin, it should work fine. In the worst case the burner needs replacing. This can also be done yourself. Purchase the burner from a large hardware store or contact Weber for a replacement.
May 01, 2010 | Weber Genesis E-320 Propane Grill
How do I install replacement burners for my Charmglow 720-0036-hd-05 grill
Replacing Burners on Charmglow 720-0036-HD-05.
1. Disconnect the gas line to the "side burner".
2. Remove the two "side shelves", each of which is held on by 4 large phillips screws.
3. Remove the "control panel" that is held on by two smaller phillips screws at each side of the "control panel".
4. Remove the "front baffle" located directly behind the "control panel that is held on by 4 phillips screws.
5. Lift off the "cooking grills" and the "flame tamers" (the plates over the burners) so that you can see the burners.
6. Now you can slide each of the burners forward and then left them out of the grill.
Replace everything in the reverse order.
Apr 07, 2010 | Grilling
Viking range burners won't light
All of these ranges have a spark module at each burner sight and they all click when ever you attempt to light one burner. Therefore, it can not be assummed that the spark module for those nonworking burners are actually clicking. Remove the burner covers and actually look for the sparks. If there is no spark make sure the connections are nice and tight. IF they are, you most likely need to replace the spark module.
Apr 30, 2009 | Viking VGIC485-6G Gas Kitchen Range
I need the assembly instructions for a Four Seasons Gas Grill
I purchased this grill and assembled it yesterday. I noted the area that is providing confusion as it is wrong. Please follow the following instructions. It is quite simple when you have a background in electrical and electronics engineering. These directions should translate my knowledge into step by step instructions for all.
1. Attach the two thinner wires with two terminals on each wire, from the front of the grill head to the larger (Input or Control) terminals on the igniter assembly. These two wires are from the push to turn micro switches on each of the burner control knobs on the grill head. Attach the two smaller terminals on these thinner wires to the micro switch on the side burner control connected as part of the regulator and hose assembly.
2. Attach the three thicker wires from the front of the grill head to three of the six smaller (output) terminals on the igniter assembly. These wires go to the igniters themselves.
3. Connect the two thicker wires from the rear of the grill head to two of the six output terminals on the igniter assembly. The small wire is for the igniter on the bottom infrared burner and the larger, thermally insulated wire, connects to the igniter on the rear infrared burner.
4. Connect the lead from the side burner to the remaining small output terminal on the igniter assembly.
5. Mount the igniter to the front of the right side shelf by removing the battery cover and hexagonal nut. Insert the shaft through the hole in the front of the right side shelf and secure with the hexagonal nut. Replace the battery cap. Do not install the battery at this time.
6. Mount the side burner control by inserting the long end of the control into the side burner assembly. Attach the control to the front of the right side shelf with the two screws held in the front of the control assembly. NOTE: You must remove the screws from the control assembly and insert them through the Off/On bezel and front panel of the right side shelf before screwing them back into the control assembly. Install the control knob for the right side shelf. Verify that the connections to the side burner control micro switch made in step 1 are still intact.
7. Insert the battery into the igniter assembly by removing the batter cap and inserting the AA size battery with the positive (pointed) end out. Replace the battery cap.
8. Test the igniter assembly prior to installing the gas tank and installing the “Flame Tamers” and grates by pushing in on each burner control knob in turn. Listen for a popping sound and look for sparks at each burner.
I hope this helps.
Ed Roberts
President
E. F. Roberts & Associates
www.efrobertsassoc.com
Mar 19, 2009 | Grilling
Side burner on Jennaire grill
Hello
The soot stains come from the air mixture, that will show too much yellow flame tips, just adjust the air intake, too have an idea how much to adjust it, and also it wouldn't hurt to clean the flames holes by sticking a pin. Alos make sure you have the right fittings converters. It's the grill LP Gas or Natural?
Hope this help
Eddie Rentas
Tupper Lake NY
Aug 01, 2008 | DCS Double 30'' Grill Cart Side Burners in...
Char-Broil CharBroil 4637318 Grill Logo
83 people viewed this question
Top Char-Broil Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dean Gruber
Are you a Char-Broil Grilling Expert? Answer questions, earn points and help others
