Question about Stanley 77 500 Intellilaser Pro Stud Sensor & Laser Level
When AC light is on, bullseye pattern is always on
After getting scope on bullseye,what do they mean by,Zero setting of scale grip? my scope is a Nikon Bolt XR, for crossbows
you need to decide what distance you want bullseye to be. the arrow in flight is either rising or falling. if you get bullseyes at say 50 yards you will be low at 25 yards (arrow rising) and low at 75 yards (arrow falling). this is due to the scope is mounted higher than the arrow.
Sep 22, 2013 | Nikon Bolt XR Crossbow Scope Black Matte...
GENERATOR CLICKS WHEN RUN IS DEPRESSED BUT WILL NOT TURN OVER GOES STRAIGHT TO OC. CHANGED BATTERY NO HELP?
Put it to run while holding the bullseye, you'll see the decimel move, wait for a number other than the run time to show and hit down, up, down, up, down, up then hit the bullseye until you see EC, it should should EC00, if not, select EC00 using up or down, then hit the bullseye until it says save and hit up and the bullseye again.
Aug 21, 2011 | Kohler 12 kW Emergency Power System -...
I have a ASUS P8P67 LE motherboard, intel i5 - 2310 processor, kingston DDR3 RAM and ASUS ENGTX560 DC/2DI/1GD5 graphic card. When I turn on the PC i get one long and then three short beeps, and the...
> one long and three short BEEP
Something is wrong with some of your hardware.
Turn the computer off.
Disconnect the AC power.
Remove the graphic card.
Connect the AC power.
Turn the computer on, to see if the pattern of BEEP has changed.
Remove the RAM -- all of it.
Reinsert one stick of RAM.
Reinsert the graphic card.
Jul 16, 2011 | ASUS P8P67 LE LGA 1155 P67 SATA 6 Gbps and...
Bullseye rainbow of colors
This is either a purity fault which is caused by magnetism affecting the screen. You would need to call a service engineer to remedy this as a special tool is required called a de-gauss coil. However there is also the posssibility that it could also be a fault with the shadowmask which is caused by the CRT itself, if this is the case then the CRT will need replaced & this would probably not be economical.
Nov 11, 2009 | Samsung TX-P3075WH 30" TV
HVAC intermittent problem with 2002 Olds Intrigue
I assume you are talking about whether or not the blower fan is running. I had a similar problem. The likely cause is the resistors that control the motor speed. I took off the resistor pack and because it didn't look like any of the electronics were damaged I replaced the blower motor and that fixed it. One or the other, or both should do it.
Check fuses first.
Aug 18, 2009 | 2002 Oldsmobile Intrigue
Help with instructions
Open the printer and remove the cartridges. You should see a bullseye logo with a thumb icon. There is a little press catch on the underside of the black plastic bar just above the bullseye. Press it in and the printhead will be released.
Dec 16, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Bullseye chat pc camera en headset
http://www.ngs.eu/upload/drivers/Bullseye.rar
i hope that this resolve the problem.
Sergio
Feb 28, 2008 | NGS Technology ShowCam Plus Webcam
Stanley 77 500 Intellilaser Pro Stud Sensor & Laser Level Logo
76 people viewed this question
Top Stanley Measuring Tools & Sensors Experts
Lawrence Oravetz
Vernon Taylor
Are you a Stanley Measuring Tool and Sensor Expert? Answer questions, earn points and help others
