Question about TitanNet Water Heaters
The heater want come on unless you bump the side of it and then it want stay on long
    President:
  • 1,378 Answers
Thank you for posting your question here on Fixya.com.
Check the power output of the thermocouple. Often times as they weaken the power output drops well below the 750mV they should develope and will not be high enough to pop open the vgas valve unless you help it with the 'bump'. Even then it struggles with holding the valve open and eventually lets it close.
Thermocouples wear out over time and are a common part to replace every several years. You should be able to remove the old one and take it to any local appliance parts store for a replacement.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. You may also contact me thru our website at www.arrowpools.net. Positive feedback is appreciated once your problem is solved!
John
Posted on Dec 30, 2010
I have brand new Whirlpool gas water heater and forgot to put on air filter. Have tried to light the pilot light and it will not stay lit. Can you tell me if the air filter could cause this
Not unless the system has a fault switch whereby the switch requires a filter to activate the heater. Generally Not.
As a rule, your GAS company will come to your residence FREE of charge to check the heater and start it for you.
Apr 02, 2015 | Whirlpool Water Heaters
My ford econoline e150 van wont start unless you sray starting fluid in it then it runs but barely
Check the fuel pump pressure and volume. Fords also have a fuel inertia switch/relay. If the vehicle was bumped hard and then no t starting, find the switch and press the red reset button. This will restore fuel pump activity.
Dec 06, 2013 | Water Heaters
The pilot and flame dont stay on in my gas water heater
Different water heaters have different problems.
Look at label on side of water heater for brand, model and type so expert can identify correct action.
Add a comment.
If this is tank heater, the air intake could be clogged, gas pressure low, bad gas control, etc.
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html
Oct 07, 2012 | Reliance Natural Gas Water Heater Control
The pilot ligth dont stay on
Let's don't guess.
Add a comment.
Oct 07, 2012 | Reliance Water Heaters
Piolt light will not stay lit
Please look at label on side of unit for brand, Model and Type of water heater, and include approximate age of water heater.
Add a comment with that information.
This will let me access specific information about your water heater.
Oct 07, 2012 | Water Heaters
Low boy water heater leaks at point where cold water pipe enters caseing.The leak is below the threads.The caseing is rusted at the point where the pipe goes through.Can this rusted place be patched or...
1) Your water heater needs to be replaced.
It cannot be repaired.
Tanks rust out after anode rod is depleted unless anode is inspected and replaced 1-3 years.
Water softener causes anode to deplete quicker, so inspect every 2 years.
Also stray household current can cause tank to rust out. Put bare copper ground wire between hot and cold pipes on new heater.
2) First thing is protect yourself from tank rupture where water heater bursts open and water runs until it's shut off. Ruptured tanks are big topic in homeowner insurance industry today because they cause major damage inside house.
- Turn off heat source so tank is not under pressure:
Gas: Rotate dial to pilot so pilot light stays lit, but burner does not turn on
Electric: turn off circuit breaker
- Turn off water going into tank using shut off above tank.
- Open hot side to bathtub to relieve pressure from tank.
- Check label on side of tank to get tank specifications for replacement.
3) What to do until replacement.
You can get by for a while on leaking tank by turning it ON only when needed.
Make sure tank is full of water before turning heat source back on.
This will buy time until replacement.
Electric tank heats 21 gallons water per hour.
Gas water heater 41 gallons per hour
Shower uses 6-9 gallons hot water, bath uses 12-15 gallon hot water.
4) Additional reading so next tank lasts longer
http://waterheatertimer.org/Replace-anode-rod.html
http://waterheatertimer.org/9-ways-to-save-with-water-heater.html
http://waterheatertimer.org/Water-at-bottom-of-water-heater.html
Dec 05, 2010 | Water Heaters
Atwwod 10 gal gas/elec water heater won't work on elec.
THE LIGHTED SWITCH SHOULD BE THE 12V ENERGY SOURCE TO ACTIVATE THE LP SIDE OF THE HEATER. THERE SHOULDN'T BE A LIGHTED SWITCH FOR THE 110 SIDE. THERE SHOULD BE A SWITCH OR A COMBINATION OF SWITCHES. ONE ON THE WALL LIKE A LIGHT SWITCH AND ONE MOUNTED BEHIND THE HEATER.
Jul 07, 2009 | RTO Atwood DSI-RV Water Heater-6 Gallon
Water Heaters Logo
35 people viewed this question
Top TitanNet Water Heaters Experts
Gene Haynes
Are you a TitanNet Water Heater Expert? Answer questions, earn points and help others
