Question about Yamaha HTR-6090 Receiver
I bought a used Yamaha HTR-6190 receiver few days ago, and I simply cannot get pass the set menu. I have tried SVHS monitor out, and RCA monitor out. Can you help?
  • 1 more comment
  • adelorme738 Dec 30, 2010
    I have a PS3, and XBox 360, and an HTPC connected to an IScan Duo. The Iscan is the hub of my system, and I the video signal is sent directly to the projector.
    Only the audio signal is sent to the HTR-6190, via an optical connection. I selected the BD input. So, there is no video signal going to the HTR-6190. I want to use it only as an audio processor. I even don't use the amplifier part of the receiver. I connected 6 RCA video cables on the preout outputs(FR/FR/Center/RS/LS,and subwoofer.
    I don't know if this setting can be the problem, but when I want to start the auto setup mode or select the manual mode, I can 't get pass the initial screen ''Set menu". I can move the arrow to auto setup, manual setup, system memory, and signal info, but nothing happen when I press enter!
    I can't access special features, I can't specify the size of the speakers, ect. There are hundreds of options with this receiver, and right now I can't change one.
    AD
    Sir,
    The remote is the model that you have indicated in your reply! Is it a known problem?
    Best regards
    Alain Delorme
    Sir,
    You have found the problem!!!. I have a Harmony Remote, and I just download the code to mimic the Yamaha remote. I was able to access the other menus.
    It is a 10/10 solution.
    Thank you very much! I will check for a replacement as indicated.
    Best regards
    Alain Delorme
  • 1,868 Answers
Hello! A little clarification...Are you having a problem with video monitor or a component...ie DVD player? If so, identify the equipment that you are trying to connect...Guru...saailer
Posted on Dec 30, 2010
  • David Burbee
    David Burbee Dec 30, 2010
    Hello! Thanks for the clarification...It appears that the Remote is defective...
    Is the remote a RX-V1800 (RAV367) LargeWK480500? See picture below...I want to verify that you have the correct remote...To order a replacement remote control call 1.800-292-2982, press 5, then 9888, Weekdays: 8 am to 4 pm Pacific time (closed 12-1 pm)...If their price exceeds $50 it can be purchased online.............Guru....Saailer
  • David Burbee
    Hello! There isn't a known problem with this particular remote...Since your the second owner the remote may have been damaged...The HTR-6100 is a classy unit with rave reviews, and zero reported faults in the unit itself...Most remotes are cheaply made...You could visit an audio store that sells your unit and have them try your remote...However I'm convinced it's defective and suggest that you buy a new one...
    Saailer
How to pass video through the receiver
the cable hdmi to rca does not work it is a scam. b option will work but cost a lot of money. if your receiver has an rca out that should work to your projector not sure about the in and output mode to do that from your receiver
Mar 25, 2014 | Yamaha HTR-5063 Receiver
I have a Yamaha HTR-5630 receiver. Can I add a
try use 1/4" stereo plug to two RCA plugs used with amplifiers and mixers
[img]http://www.mcmelectronics.com/images/product/icons/magnifier250.gif[/img]
use yamaha cd or aux input ..
Dec 31, 2009 | Yamaha HTR-5630 Receiver
Setting up DVR, Receiver & VCR w/out cable box
For TV audio thru the receiver, you will need to run an optical cable or RCA analog audio cable from the "Audio Output" or "Monitor Output" on the back of the TV to the CBL/Sat input on the Yamaha. The VCR goes to Video 1 on the receiver and the DVDR will go to DVR/VCR2 on the receiver. If you want to pass Video thru the Yamaha to the TV, use the "Monitor Output" on the Yamaha if it's at least "Component Video" if not, connect your video sources directly to the TV and audio to the Yamaha. Hope this helps. If you need further assistance with this, post a comment and I will help you further.
Sep 26, 2009 | Yamaha HTR-6030 Receiver
Do I need to turn anything on to get the component monitor out?
If you are up-converting or down-converting, yes. Meaning, standard video or s video to component, or HDMI to component. Otherwise, component is passed directly. Check your "Video Settings" in the "Main Menu". If you still have a problem, post a comment and I can help some more.
Aug 07, 2009 | Yamaha HTR-5740 Receiver
HTR-5740 Subwoofer Hooking Up Issue
You can use a hi-level to low-level adapter. Just remember, the Yamaha does not send power (wattage) to the sub, just signal. You need to use a subwoofer that has an amplifier either externally or built in.
Jun 26, 2009 | Yamaha HTR-5740 Receiver
Hdmi in but no analog out
the guy was wrong. the analog and digital portions of the receiver are totally separate.
according to Yamaha:
"Be sure to connect your video components in the same way you connect your video monitor to this unit. For example, if you connect your video monitor to this unit using an HDMI or COMPONENT VIDEO connection, connect your video components to this unit using
the HDMI or COMPONENT VIDEO connection."
sorry bud:-(
Feb 28, 2009 | Yamaha HTR-6130 Receiver
Want to connect my RCA sub to my yamaha htr-5940 reciever
Subwoofer needs to be enabled through menu on Yamaha. LINE OUT might be turned off or Subwoofer volume set to low or off... (-db level) kinda thing...speaker wires are usually always live etc...
Feb 03, 2009 | Yamaha HTR-5940 Receiver
PS3 connection to Yamaha HTR-6130 Av Receiver
URNOTME is right. HDMI is great and all, but wish i would have spent a few more dollars on a unit that supports switching. htr-6130 does pass-through, so you have to use seperate audio connections. really there is no use running HDMI into the receiver and then into the receiver and THEN to the tv. just go straight to the tv, then run your audio either optical (best) or coaxial.
Nov 28, 2008 | Audio Players & Recorders
My yamaha htr 6050
Make sure you speakers are turned on on the receiver,
Jan 23, 2008 | Yamaha HTR-6030 Receiver
No component video output
Hope this helps
The Yamaha HTR-6030 offers two types of video monitor output: Component and Composite. You may need to connect both types to your television as the HTR-6030 does not have composite to component video conversion. In other words, to view your VCR on your TV, you need to use the composite video monitor connection. However, for a DVD player or other source that has component video connections, use the component video monitor output to your TV. If your TV has both types, you simply switch between the two with your TV remote to access the proper video monitor output signal from the HTR-6030.
Yamaha HTR-6090 Receiver Logo
391 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
