Question about LG Televison & Video
Can someone help This tv has sound but no video.
Can someone help This tv has sound but no video. VS,VA and 5V are ok, Led D103 lit , The video processor get hot
    Guru:
  • 2,178 Answers
Check the inverter.
Posted on Dec 30, 2010
How do I fix my LG 42PG25 plasma TV? The model number is 42PG60UA. What should I try next see details below?
It is 19 years old, and I would say beyond economical repair. You will be chasing blown components that were damaged when the power surge or brownout occurred. It is only a 42" set and it is plasma. Technology has moved on to 4K Ultra HD, LED and smart hubs. Treat yourself, it's Christmas :>)
Dec 19, 2017 | LG Televison & Video
Why is the picture on my LG TV so dim?
Sounds like the back light panel is going bad.
May 01, 2015 | LG Televison & Video
I HAVE A PROBLEM WITH A POWER SUPLY OF SAMSUNG PLASMA PS 51 E530 ALL VOLTAGE IS OK,5VOLT 12 VOLT IS OK,BUT VS AND VA VOLTAGE 0VOLT SO NO SCREEN,I CHECK POWER ON AND VS ON IS OK,can you help me
Sounds like it could be a bad capacitor on the power supply, or possibly on the video out circuit. Bad capacitors are a common problem in Plasma and LCD monitors and T.V.'s.
Jun 25, 2014 | Samsung 51 INCH PS51E530 Full HD Plasma...
Hisense plasma no picture
tv on after class out side coming
Jan 07, 2014 | Televison & Video
PLASMA TV
test this Check panel
appearance
Check PSU output
(Va,Vs,5v)
Check the input of Y,
Z board
Replace ctrl B/D Replace Y, Z B/Dd1bdcdd3-1a41-48ef-8ae2-a01afed70a7d.gif
Jul 20, 2013 | Televison & Video
Hitachi hd1080
Model? what if any lights on front of set come on? If total dead unplug and look for fuse connected where power cord enters set, as much as I can suggest without more info.
Hitachi 55in plasma TV, model 55HDS69. It will not power up from either the remote or the on/off switch on the side. The TV was used a lot, for more than 5 years. It shut off while running. The red...
Hi sir Jim!!!!
kindly check the 5 LED if there is lit lights to diagnose where the fault came from..You said the 5 led turn off for 1 -2 seconds it means no error but still won't turn on I think there sometime wrong on logic circuitry..
Try to read the voltages on highlighted words on picture of block diagram above such as vs,va,vcc,stby+5v,stby+3.3v,+5.5,+10.5 and +12v...
After that let me know the results to diagnose where the fault from..
Hope it helps...
chester..
Jan 19, 2012 | Hitachi 55HDS69 55 in. Plasma Television
My 42 inch tv wont turn on model nu 42pfl5603d/10
what you need is trouble shooting and a good digital tester to fix that problem. since the problem is power off start at the back light check if their is a small maldischarge at the module then check if their is a click on relay and then if the front LED is turn from red to green. then check the power supply if normal, check the low and high voltage except the stand by supply. then check the Y board the Va and Vs supply look for the blown fuse. and then the Z board check the 5v and Va supply, check also blown fuse.
Apr 28, 2011 | Philips Televison & Video
My 50" lg plasma has
first thing you you need to do is open the back cover for trouble shooting. then check the normal connection of all the connectors and then look for the back light if their is a maldischarge from the module.disconnect all the connectors to isolate excessive voltage. turn on the tv and check the Y board if normal the Va, Vs, -Vy and Vsc voltage are all present.the same thing with the Z board the Vzb, Vs and Va voltage if normal,check if no blown fuse.there are FET at control board check the 3.3v, 1.8v and 5v.be careful always especially in performing voltage checking.
Apr 26, 2011 | LG Televison & Video
Televison & Video Logo
