Question about Asko 24 in. D3350 Dishwasher
We have an Asko D3350 Dishwasher and the upper blade does not appear to be spinning and the dishes are not coming clean. Bottom appears to be working fine and dishes on bottom are clean. What could be the problem?
On my d3350 it is possible to choose which tray (bottom, top or both) is cleaning.
The button is the bottom left, and above it there are two lights. As you push this button, the lghts cycle through lower tray, upper tray and the both trays. You want both lights on.
Also try this - take the spray arm out (it just snaps free) and rinse it out in case there are some blocking materials in the arm which are stopping it from spraying
Posted on Jan 10, 2011
The lower spray arm on my ASKO 1805 dishwasher has stopped turning, the dishes are still getting washed, so fluid still goes through the sytem, and drains at the end, the heater works. When turning, t
If the arm spins easily by hand, but won't spin when operating, that points to poor water delivery...
1) check the strainer. Not just the holey one you can see, but there might well be a very fine mesh filter under it ~ if so, remove it to clean it (it can appear clean, but still be clogged with transparent cellulose fibres). Try running the machine empty without the strainer/filter fitted. You should hear a difference if the filter was causing the problem.
2) you might have a weak impeller. After a while the plastic impeller on some machines just wears away, leaving insufficient fins to move the water, this can be accelerated by e.g. broken glass stuck in the pump. Impellers can also slip on the motor shaft; the motor's spinning but the impeller doesn't. This means removing the machine, turning it over and removing the pump for inspection...
Feb 13, 2015 | Asko 24 in. 1805 Built-in Dishwasher
My asko 3122 dishwasher wont drain
It is likely that there is some minor clogging in the diswasher drain filter.Clean as per the user instructions available with the dishwasher. Also likely the kitchen drain could be clogging. Buy a dishwasher cleaning kit from supermarket. Finish make a good product. Use it to clean the dishwasher as per instructions on the kit.
Nov 27, 2012 | Asko Dishwashers
Dishes not clean and covered in sticky, gritty residue at end of wash water sitting in sump under filter
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Jun 30, 2011 | Asko 24 in. D3350 Dishwasher
I have an Asco D3350 dishwasher. When the cycle starts the machine fills with water and when there appears to be the right amount of water in the machine an error code F4 shows on the panel. 3 clicks can...
There could be a variety of problems most common clean filter sensor water level faulty replace or pump not working how old and how often do you use it?
Aug 29, 2017 | Asko 24 in. D3350 Dishwasher
Our Asko dishwasher no longer cleans the top shelf of dishes properly. Fine white and black grit is left on the dishes after every wash, and if there is any food residue on the dishes it does not come off....
The problem is most likely that there is still water residue at the bottom of your machine. If the machine is not fully drained it picks up some of the residue and sprays that onto the dishes during the final rinse, leaving an unhealthy and unsightly film on everything.
Remove the bottom strainers and make sure that there is nothing obstructing the outlet pipe and the pump. If possible back flush through the outlet pipe and try draining the machine again before using it again.
Check also that the arm outlet jets at the trailing end of the arms are not blocked with food particles and other solid matter. This often happens and the arm is unable to turn because the water jet that is supposed to drive the arm does not have the force to rotate it.
Feb 04, 2011 | Asko 24 in. D3350 Dishwasher
The upper and lower spinning arms in the washer do not appear to spin at all. Water comes out of the lower arm but not forcfully at all.Not cleasning dishes and leaving soap residue all over.
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
Heating Element not Working
Dishwasher Maintenance
Dishwasher Residue and Film on Dishes
heatman101
Feb 02, 2011 | Asko D1876 Dishwasher
Asko 1996 appears "dead".....no lights flashing, won't respond to repeatedly pushing on/off button. Some water left in the bottom...siphoned it out, cleaned filters, no blockage there. Almost like it's...
Don't know if this will help, but my dishwasher has a "propeller" device above the top and bottom racks that spins while dispensing the water. If the dishes on either rack are stacked too high (i.e. if even one plate comes in contact with that propeller, keeping it from spinning properly) the dishwasher will go through its full cycle but will not use the soap (soap door will still be closed and soap packet still intact) and will not get the dishes clean.
However, it sounds like you either have a bit of a drain issue as well--or perhaps your dishwasher acts the same way as mine (if that's the case) but ceases to drain as well if blocked.
Jun 26, 2010 | Asko D1996SS Built-in Dishwasher
Hi,\r\n
yes you need to reset dishwasher to time fill.turn off the power button wait 10 sec,push and hold the programme and start buttons then turn power back on.hold buttons down until display lights up then release them.press programe button until 4 shows in display,then press start.test dishwasher. F4 is an inlet fault.
Jun 07, 2010 | Asko 24 in. D3350 Dishwasher
The upper and lower blades will not spin; not cleaning dishes
You will more than likely find that the holes in the arms are clogged with food you will need to remove these and unblock all the holes on both arms and replace them the arms usually come of by unclipping or on some machines there is a nut at the base centre of the arm wich you will need to unscrew first then pull them off.after you have unblocked and cleaned the arms then replace and it should work.All this above is assuming the machine is takeing on water to check this start the machine give it about 3 or 4 minutes and check if water is in the machine if there is then do the above if no water then let me know and we can investigate further.
Feb 05, 2009 | Asko D1876 Dishwasher
Dishwasher appear to be clogged
It could be a motor or a pump issue. The dishwasher has a motor that attached to a pump which forces the water up into the sprayer arms and during the drain cycle, it pushes the water out of the dishwasher. The motor (and pump) located beneath the dishwasher. Check if motor spins. In case it spins, the problem is with the pump ,in case it doesn't spin it could be a motor problem or a motor and pump problem. Good luck
Sep 07, 2007 | Maytag MDB7100AWB Dishwasher
Asko 24 in. D3350 Dishwasher Logo
350 people viewed this question
Top Asko Dishwashers Experts
John Tripp
John Tripp
Owen Barnes
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
