Question about ViewSonic VG700b 17" LCD Monitor
Just got used unit from friend. powers up, then says OUT OF RANGE WHAT DO I DO. ??
  • 11,361 Answers
You need to lower your PC video resolution to the native resolution (1280 x 1024 @60Hz) of this monitor, it is too high right now for the monitor to work.
Please read here:
http://www.fixya.com/support/r4873371-fixing_out_range_format_not_supported
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Posted on Dec 30, 2010
I have a 1976 Gaffers & Sattlers slide in range I want to replace. Any idea how to remove it? Thanks
this taken from ehow site:
Slide-in ranges and freestanding ranges use the same installation techniques, with one minor difference: the slide-in range rests on the edge of your counter top. Removing a slide-in range is not difficult but will require a friend to assist. Removing the storage drawer from the slide-in range first will give you access to the power cord and gas shut-off valve, if your unit uses gas
Instructions
    • 1 Pull the bottom storage drawer out as far as it will slide. Lift up the front of the drawer and unhook the back of the drawer from the drawer guide. Pull the drawer away from the range.
    • 2 Reach under the slide-in range and unplug the power cord from the wall outlet. Turn the gas valve to the off position on the house line coming from the wall.
  • 3 Lift the top of the slide-in range with the assistance of your helper, and pull the range forward enough that you can access the back of the range.
  • 4 Go behind the range and locate the connection between the house gas line and the range gas line. Disconnect the flexible gas line from the house gas line with a pair of channel lock pliers or a pipe wrench.
  • 5 Lift up on the rear of the slide-in range while your partner lifts the front. Slide the range out of the cabinet opening and out of the house. Lifting the unit will prevent unnecessary damage to your counter tops.
  • Read more : http://www.ehow.com/how_5959888_remove-slide-range.html
    Jan 03, 2015 | Kitchen Ranges
    How do I use my Sears kenmore double oven gs range incase of a power failure
    You can use a butane lighter or a match. Be very careful not to let gas stay on for to long before you light burner. GOOD LUCK FRIEND.
    Oct 16, 2014 | Kenmore 78812 / 78814 / 78819 Gas Kitchen...
    Need a wiring diagram for Electrolux range model EW30EF65G5H
    Hey friend, thanks for your inquiry!
    I have located the wiring diagram for your Electrolux range, EW30EF65GSH. The link will be attached. I hope this information provides you efficient assistance. -Matt
    Frigidaire Manual Search Results
    Oct 07, 2014 | Electrolux Kitchen Ranges
    After power failure, burners say 8.8 , how do I restart the stove?
    Hey friend, thank you for the post!
    Based off the information you had a power failure on your Electrolux range EW30ES65GS and now your burners are reading 8.8. The best way to reset your stove is to remove power from it you can do this by unplugging your range or flipping the household circuit breaker, for ten minutes. When you restore power to your range, if it still reads 8.8, I recommend contacting an authorized technician. Hopefully this information is helpful. -Matt
    Jul 21, 2014 | Electrolux EW30ES65GS 30" Slide-in...
    My netbook does not take cd's, how can i start up 362?
    The netbook we got was our 6th computer. Please don't comment that this is your only machine :-)
    There are about 3 or 4 ways to get the information.
    1. Buy an external CD/DVD unit
    2. Share your CD rom on the network and use network neighborhood to find the drivers
    3. Transfer the data to a USB memory stick
    4. Do any combination of the above like borrow whatever you need, be it CD rom, Memory Stick, or a friend with a desktop computer.
    Good luck.
    Carl
    Dec 08, 2009 | EnGenius EUB-362 EXT WIRELESS USB 2.0...
    Problem with ''long range'' connection...
    problem is for the firewall enable dis able it
    Mar 03, 2009 | NetGear WGX102 54 Mbps Wall-Plugged...
    Not powering on
    Will it start if attached to a charging cradle directly?
    May 21, 2008 | Toshiba e740 Pocket PC
    ViewSonic VG700b 17" LCD Monitor Logo
    32 people viewed this question
    Top ViewSonic Computers & Internet Experts
    Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
