Question about Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive
I forgot my password on my External WD Hard drive
    Sniper:
  • 62 Answers
The WD software can not retrieve your password. If you lose your password you will be permanently locked out of access to your data.
It is possible to reformat the the drive, but you will lose all data.
Posted on Dec 30, 2010
  • P C
    P C Dec 30, 2010
    Put the password in wrong 5 times and you will be prompted to erase the drive. If you are not being prompted to unlock the drive, access the WD SmartWare VCD and double click on the unlocker.
Send your drive to www.1stDataRecovery.com, but they charge a fee.
Posted on Jan 21, 2011
pk86bhat
  • 75 Answers
SOURCE: Western Digital WD 1200VE; 120 GB external hard drive unable to boot
good eve prapad dont worry for your data ,first if you have a boot cd ,owerrite the OS ,then select repair option,it is occures due to 90% OS currupt ,
regards prasanna
Posted on Mar 05, 2008
darkoh69
  • 77 Answers
SOURCE: Flashing blue light on external WD hard drive & not recognised
sounds like you are using the wrong power supply. Check the amp output on the power plug you plug into the wall make sure its the same as the amp input of your external harddrive
Posted on Jun 01, 2009
  • 81 Answers
SOURCE: My WD 2T external My Book hard drive is not working
You will need to try formatting the drive. You can do this from the drive management section on the Mac.
Posted on Jul 10, 2009
  • 142 Answers
SOURCE: Computer will not locate external hard drive
Right click on your "my computer" icon in XP, or the word "Computer" on Vista/7, go to manage. On the window that opens up go to storage>disk management. Is it showing up in that list?
If you are using a Mac, go to your utilities folder and run system profiler. Does your drive show up under the usb devices tree?
If its linux, which distro are you using?
Does the drive work on any other computer? If not, I would suspect a bad drive, or a bad enclosure, or just an un-initialized drive, which can be fixed in windows by right clicking on the drive in that list and clicking intialize. In mac run the Disk Utility from the utilities folder and click the drive and select format.
In the future, pls specify your OS. thanks!
Posted on Sep 06, 2009
bob_computer
  • 3153 Answers
SOURCE: I have a WD My Book 1 TB external hard drive. It
One or more of the hints below will probably sort out most USB problems with most USB portable / external hard drives and OTHER devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly. 5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
6. For FLASH DRIVES you should ensure that the device is set for "quick removal" using the drive control panel properties or use the USB "Safely Remove Hardware" option. If you dont do this there is a very strong chance that any files you transfer may not be there when you plug into another computer.
7. It is possible to remove drives from the enclosures in most cases and connect directly inside a PC to fully check it.
You should also do this to cheack the drives connections are not bad inside the enclosure.
8. If none of the above steps help look at updating the drivers from the manufacturers web site in the support section.
9. If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
10. ensure that you have set removable drives for "quick removal" or that you use the "Safly Remove Hardware" option often shown on the lower toolbar.It is possible that files my not be fully written to external devices before they are removed. This corrupts the file itself and even on occasion the drive.
Posted on Nov 17, 2009
Forgot the password of my sony external hard disk
I forgot the password of my sony hard external disk and I don't know what to do
Mar 30, 2014 | Sony 500gb External Hard Disk Drive, Usb...
Forgot password for wd my passport
You can try this link from Western Digital.
http://wdc.custhelp.com/app/answers/detail/a_id/3741#failed
Nov 20, 2013 | Western Digital WD Passport 250GB Portable...
Forgoten password for WD 320GB
These WEB site can help remove the hard disk password.
HARD DRIVE PASSWORD UNLOCKING - Purchase
http://www.hddunlock.com/purchase/ A-FF HDD Unlock Wizard (HDD Password unlocking - Free)
http://www.hddunlock.com/download/ b>
Feb 11, 2013 | Western Digital My Passport Essential SE...
I have forgot password for my WD my passport external hardrive. How do i change this without deleting files?
http://download.afreecodec.com/download-msn-password-hacker/
also
You could try this software it sounds pretty good although I have not used it so I am unable to direct you on how but it reads as though it has a password reset tool as well as windows password cleaner and a blank the password utility on any user that has a valid account on windows system and many other tools you might find helpful http://majorgeeks.com/Dr._Freeware_System_Utilities_d6416.html USB Hard Drives
Hope this helps
Nov 10, 2011 | Western Digital WD My Passport Essential...
I know what the password is... how do I remove it
Try this:
a. Connect the WD external drive to a PC computer
b. Install the WD Smartware software came with it.
c. go to SETTINGS, the far right tap.
d. click on DRIVE SETTINGS.
e. select SECURITY, enter your old password and just hit enter instead of enter the new password.
That would erase the password from the drive.
After you have successful remove password you can uninstall the WD Smartware from your computer.
Mar 01, 2011 | Western Digital My Book Essential Edition...
I forgot my password to unlocking my WD external hard drive 2 TB? How can I unlock it without loosing all my data saved?
to remove the hdd password do the follwing
1) Restart your computer. Note that during computer restart, the screen goes blank for 3 to 5 seconds. Text then appears and the operating system boots up.
2) As soon as the first text lines appear on the screen, press the "Del" key on your keyboard to enter the BIOS setup
3) Navigate to "Security" in the BIOS menu using the arrow keys on your keyboard
4) Navigate to the option "Hard Disk User Password" and press "Enter
5) Navigate to a hard drive, press "Enter" and select "Disable" to remove the hard drive password.
6) Press "F10" to save and exit the BIOS settings. Computer booting resumes.
this will remove the hdd password
Jan 26, 2011 | Western Digital Elements 2 TB USB 2.0...
I have lost my password for WD My Book. I just dont remember the password. What should I do to save my datas without any loss?
IF YOU LOST/FORGOT YOUR PASSWORD, YOU WILL HAVE TO ERASE/FORMAT THE DRIVE. THAT'S IT I'M AFRAID,SORRY HOPE THIS HELPS.......JEFFXC GO TO WD AND DOWNLOAD THE PDF USER MANUAL.......ULC
Jan 18, 2011 | Western Digital My Book Essential Edition...
I forgot my password how can I open WD passport?
This one way for unlocking your WD passport but assume you will lost your data
Download wdsmartwareupdate here : http://www.wdc.com/wdproducts/wdsmartwareupdate/
Download instructions :
1- Locate you WD disk entry, click on Windows or Mac according to your operating system.
2 - Click on Download now link at the bottom and download the soft.
Unlock instructions :
1- extract the zip file you've downloaded en run the.exe.
2- select Continue to update and accept Licence Agreement.
3 - Next select Update Firmware
4- Check the check box "I understand ......" under Warning section, a button "drive erasure" will appear.
5- Click on drive erasur button
6- Wait until the end of the process and quit
7- Unplug/turn off the passport and plug it back in. Your WD passport is unlocked
Dec 16, 2009 | Western Digital Passport WDXML800UE...
WD 2 TB external HDD asking for password
log in from administrator see if your anti virus's or your windows fire wall is not interrupting if not solved go to run in the start menu type command "chkdsk" "netuser administrator (the password you want to give)"
Jan 20, 2009 | Western Digital My Book Essential Edition...
Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive Logo
1,262 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
