Question about Vacuums
John lewis mini sewing machine manual - Vacuums
Need a manual for my singer sewing machine it is a singer genie 353 or 354
HI......................
Singer 353 and 354 sewing machine service manual.
Note* This is a service manual. If you need the instruction manual or the great little trouble shooting and adjusters manual, we also carry both in our store.
Service manual includes:
* Bobbin winder
* Rotating hook
* Motor and electrics
* Needle bar
* Presser bar
* Much more
THE MANUAL LINK IS GIVEN BELOW.............
http://sewingmanuals.blogspot.com/2011/04/singer-genie-353-354-sewing-machine.html
GOOD LUCK..................
Sep 22, 2011 | Vacuums
I have lost my manual to my Sewing Machine Janome Excel Decor 5018 and was wondering if I can down load one :)
A copy of the manual is available for sale here: http://www.sewingpartsonline.com/instruction-manual-janome-decor-excel-5018.aspx . Other sewing machine parts dealers may also have the manual.
The only Decor model for which Janome has an online copy of the manual is the DC3018. I believe this is a very similar sewing machine with slightly different features. The manual for the DC3018 is here: http://content.janome.com/documents/File/ManualFile/DC3018.pdf .
I hope this helps.
Sep 12, 2011 | Vacuums
We have a Magimix M 200 Purchased at John Lewis Registration No: 278739 approx Dec 2008. We have not got the purchase receipt. The nozzle for frothing up the milk is not working at all so we are unable to...
There might be a blockage in the steam tube or the frothing nozzle itself. Make sure the nozzle is clean and try inserting a pipe cleaner gently into the steam tube to clear any blockage that may be preventing steam from passing through.
Jun 30, 2011 | Vacuums
How to get Brother sewing machine apart to replace spool spindle.
To be honest the best thingon such instructions is the manual which is provided along with the machines,but many people don't have it , probably because they have lost the manual orthey have got the machine as a used one and forgot to take the manual alongwith it.
Please follow the belowinstructions :-
Close to the end of theHandwheel , there is usually a spindle, at the back of the machine.
This is where you need to restthe spool on and you would notice it sitting perfectly.
In case the length of the spindleis less , then pull it up gently with your fingers.
Also there are machines these dayswhich have easy to replace facilities , so the spindles just slide intothe machine for safety norms when you put the machine away.
Therefore , all you need to do it pullit up and it would be fine.
An example of a manual forbrother's sewing machine can be found in the below link which would give you anidea of how exactly it's done.
http://bit.ly/j2BdsP
Hope this helps ..:)
Jun 11, 2011 | Vacuums
I need a manual for a JL Mini sewing machine.
This can be obtained from a site called:
www.sewingmanuals.com.They carry manuals for many make and models and if they do not have the one you need you can also try:www.manuals.comI hope this will help you and good luck!
Have a good day!
Oct 13, 2010 | Vacuums
Vacuums Logo
896 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
