Question about Gigabyte GA-8IPE1000-G (MBGA81PE1000G) Motherboard
Can i use a ddr2 400mhz ram on a GA8ipe1000 motherboard?
    Novelist:
  • 127 Answers
According to the Gigabyte website
http://www.gigabyte.com/products/product-page.aspx?pid=1863#sp
that motherboard only has DDR slots (4 of them), so, no you cannot use DDR2 RAM modules.
If you do manage to make it fit, the pins won't line up because DDR can be 184pin or 200pin, and DDR2 can be 214-pin, 240-pin, 244-pin.
Since your memory slots or only DDR, there is no way that the DDR2 would make the connections that it would need to make in order for it to work.
I hope this helps! If not, please comment back and let us know!
Posted on Dec 30, 2010
I currently use 256 mb ram,I want change 1 gb ram,pls ur opinion
Upgrading RAM on your ASUS P4B-MX Motherboards is easy, we carry compatible RAM Upgrade for ASUS P4B-MX Motherboards, the ASUS P4B-MX Motherboards takes the PC100/133 SDRAM DIMMs.
Supports ECC RAM Type, and comes installed with 0 MB (removable) of RAM. You can upgrade your ASUS P4B-MX Motherboards to up to a maximum of 3.0 GB RAM, the Motherboards has 3 sockets to install RAM, already with 0 MB (removable) standard RAM installed. For best Motherboards performance use the maximum amount of allowed RAM per slot for your system.
Buy our Motherboards RAM with confidence, we provide lifetime warranty on all RAM Modules purchased, backed with an excelled customer support. Choose the following RAM Upgrade for ASUS P4B-MX Motherboards.
If you're not sure if a module is right for your system, use the Crucial Memory Advisor tool for a list of guaranteed compatible modules
hope this helps you
Mar 20, 2012 | ASUS Intel 845 Chipset P4B-FX Motherboard
No ram beep comes without ram and no display
> No RAM beep comes without RAM.
That is to be expected -- when the motherboard does _NOT_ detect any properly-mounted RAM, the motherboard sounds the "no-RAM" beep.
> and no display
Correct. Without RAM, the computer cannot "paint" anything onto the video screen.
Nov 06, 2010 | Intel D845GVSR Motherboard
PENTIUM-4 865GV CHIP MOTHER BOARD (MBP4I65GV) Motherboard: RAM IS NOT WORKING. SUPPORTING RAM REQUIRED, CAN Y...
*********** supports DDR1 type Ram, you can easily get it from the market. Just ask the retailer to give you the DDR1 Ram, they will ask you how much memory of Ram you want. There are 256Mb, 512Mb, 1gb, 2gb, etc.. the more the better and this motherboard supports upto 2 gb, but some newer make of this motherboard miht have been changed.
May 17, 2010 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
E210882 motherboard powers on but then i get beep code... short 111-11
Remove the RAM from the slot and clean it. after that stick it back on the ram slot and try . If the same sound again then pull back the ram & put in a other ram slot. If you face same problem again then your RAM is damaged. For confirmation just use your ram in different motherboard. If its working there, then your motherboard ram slot not connecting well with motherboard. You need to repair your motherboard.
Thanks & waiting for your feedback.
Feb 12, 2010 | Dell (E210882) Motherboard
Planning to upgrade my RAM(motherboard K7SOM + V7.5C). Ram have high & low density. What is the difference? Which suit my motherboard? Thanks.
Look at the sticks of RAM -- "high" density means fewer chips on each side of the stick, i.e., newer technology and production methods have packed more bits into each chip, while "low" density usually means 8 chips/side, using older RAM chips.
Older motherboards do not expect to find "high" density RAM, and typically will only detect 1/4 or 1/2 of the RAM on the stick.
If you buy a new motherboard, it will support BOTH densities.
Oct 22, 2009 | EliteGroup K7SOM (K7SOM W/CPU) Motherboard
Intel 845 mother support
research the ram to see if it will work on that motherboard. some ram requirements are present when you get memory for a pc. not all ram are compatible with certain motherboards.
Oct 02, 2008 | Intel Motherboard
3 Beep sounds-No boot
As you probably know 3 long beeps on an Intel motherboard is memory failure. Even if RAM is good your Motherboard may have problems in reading your ram module.
If you are using a PCI or AGP video card try also removing and putting back video card, video adapters use shared RAM and can give you troubles with RAM.
Always perform all maintainance on motherboard with power unplugged and avoid to touch contacts and circuits with your finger.
If the 1GB module is new, verify with seller that your motherboard support this memory, some motherboard do not support double density RAM.
Aug 16, 2008 | Intel Desktop Board D845GLVA...
Buying RAM to my ASRock(845GV R5.0) Motherboard ?
it can support up to 2GB ram maximum FSB 533/400MHz,
Memory Supported RAM Technology: SDRAM, DDR SDRAM
RAM ( Max ): 0 MB / 2 GB (max)
Supported RAM Speed: PC2100, PC1600, PC100, PC133
Aug 10, 2008 | Asrock P4I45GV R5 Motherboard
My msi vis p4m800 motherboard don't support two ram
Hi, does your board have 2 diferent color RAM slots?
if it does you must install the RAM in the same color slots.
If not then you have the option of buying a 512 stick of RAM and installing that as a quick fix. The other alternative is to have your board tested by a technician.
Regards mistyman
Oct 15, 2007 | MSI KT4V (MS-6712) Motherboard
Gigabyte GA-8IPE1000-G (MBGA81PE1000G) Motherboard Logo
234 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Tony
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
