Question about HP W2007 LCD Monitor
My monitor on my HP w2007 turned blurry 2 weeks ago. I ran ZoomBrowser as an administrator to open it. Not sure if I caused the problem or not. As icons and picture on desktop blurry as well as any word processing so not internet connection related. Help?
    Genius:
  • 1,550 Answers
First check the driver video on your pc sometimes by mistake they gone bad
Posted on Mar 26, 2013
  • 536 Answers
Check that the data cable of the monitor is properly connected to the back of the monitor and the desktop computer.
If it is properly connected, then most likely a component within your monitor has failed and will have to be replaced. If you have another monitor that you can connect to the computer to compare, you can confirm that the problem is indeed with the monitor and not with the computer itself.
Posted on Dec 30, 2010
I have a Hp 500 (OLD) and a hp w2007 monitor that says' no signal? I have checked chords is the problem the monitor or my old tower
If both monitors give no signal, the computer has a video graphics card issue or a motherboard problem, now when you checked the video cord, do you change it? if you have a extra cord, sub it to be sure.
Apr 16, 2012 | HP W2007 LCD Monitor
HP W2007 + Xbox 360 = Constant Sleep Mode
the monitor is bad
if it will not power on,
or show NOSIG< with XBOX on then turned off the monitor must show NOSIG>
why not test the monitor on any pc made even laptops VGA jacks works, so that works, its not the monitor.
and bad xbox video caused. but is not it. as you said.
the menu needs sync lines active. to pops the OSD button menu.
so the monitor is bad.
or the cable.
what is w2007, lets see.?
its old. at 1680 x 1050 @ 60 Hz
this old monitor runs CCFL lamps.]
im shocked it glows at all up to now.
ever do flash light trick test?
see got data, but no back light, CFFL is dead.
HP W2007
users guide last page.
This HP product contains mercury in the fluorescent lamp
in the display LCD that might
require special handling at
end-of-life:
that means CCFL died, also all do, soon.
(as short as 2 years, full time , they die. 20k hours)
out of your service manual it shows.
ccfl-wcj1avqu0msqxnqr1cdquwfl-1-0.jpg what any running pc connected the OSD menu most work
not in sleep mode.
if there is sinc, H/V pins active
that OSD must work or the blacklamp is dead
use flashlight see, there is data there, see?
Sep 09, 2017 | HP W2007 LCD Monitor
My monitor (HP w2007) presents a screen when it is powered on but the display only remains on for about 1 second before turning off. I disassembled the monitor to examine the power supply board and fuse...
Yes, the likely cause is the power supply/inverter board, in most cases it is bad capacitors and solder connections. If any capacitors are puffed or show a slight dome shape at the top, chances are it is open.
Sep 18, 2011 | HP W2007 LCD Monitor
HP w2007, monitor display goes slightly pink in color, gets dark. Caps?
That can be bad lamps, or bad caps also, but I suspect the lamps.
When lamp gets old it usualy turn on pink and turn white after warm up, but if it is really bad, it will cause the inverter circuits to go into shut down to protect the circuits since bad lamp can draw excessive current. You can see bad lamp album.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Dec 29, 2010 | HP W2007 LCD Monitor
My monitor, hp w2007, shows for about 20 seconds when turned on then goes blurry then black how do i fix???
The most common problem that causes the screen to go to a black screen is due to bad capacitors in the screen's power supply board. The bad caps are the cylindrical and will appear to have bulging tops. 66c561df-0d01-416a-ae23-71f3b3965c88.jpg
Oct 24, 2010 | HP W2007 LCD Monitor
Does my HP w2007 have a mircophone
i am pretty sure it doesnt, sorry, most lcd mointers that arnt t.v.s usally dont have built in speakers or a mic, if it does it would have a 3.5 mm port or plug somewhere
Dec 30, 2009 | HP W2007 LCD Monitor
HP w2007 LCD monitor goes off Monitor going to
Make sure that everything is connected to the monitor properly. Go to the back of it and make sure the VGA or DVI cables are secured and then check the back of the computer to do the same.
Sep 16, 2009 | HP W2007 Desktop Monitor
Wmploc.dll has 11.0.6001.7004 when 11.0.6001.7004 was expected
Hi fcmx1
On Windows Vista:
  1. Reboot your system.
  2. Open cmd.exe as an administrator by selecting Start/All Programs/Accessories.
  3. Right click on Command Prompt and choose Run as administrator.
  4. Type in
    unregmp2.exe /UpdateWMPVersion
  5. Press enter.
On Windows XP and Windows 2003 and earlier:
  2. Select Start/Run and type in:
    %SystemRoot%\inf\unregmp2.exe /UpdateWMP
  3. Click Ok.
Does this help?
May 13, 2009 | HP W2007 Desktop Monitor
Hp w2007 blank screen
we have here , like 1000s of black screens posted here now.
all the same all with CCFL lamps. that die. same solution.
older monitors have a power saver mode inside it,
push the front button called menu, then see OSD menu
then find and turn off power saver.
if the OSD fails to show up; the CCFL are dead.
this monitor was made in 2007, and 2010 is the starting year
for ending the usage of CCFL (starting on large screens working to small)
im reading your manual for you now, free.
page 4 tells you it has CCFT (T mean Tube, L means lamp)
same same.
https://www.manualslib.com/manual/1110533/Hp-W2007.html?page=4#manual
now lets look at the page on saver. power
page 7, (its on by default ) oops !
https://www.manualslib.com/manual/1110533/Hp-W2007.html?page=7#manual
turn saver OFF
see next page 8 and turn DDC ON.
see sleep timer and turn that all off.
if you push factory reset, it the problem begins again.
bad. for you.
https://www.manualslib.com/manual/1110533/Hp-https://www.manualslib.com/manual/1110533/Hp-W2007.html?page=8#manual
you can in fact download the whole manual.
for free. here. the site on the internet in this regard.
all old HP monitors are made for old PC 2000 year.
your PC is not 17 years old i bet.
so all this old saver stuff is now WRONG.
(all this is old school Energy Star , malarkey, )
Nov 13, 2017 | HP W2007 LCD Monitor
My hp w2007 monitor has no sound.
my hp w2007 monitor has no sound
Dec 04, 2008 | HP W2007 LCD Monitor
HP W2007 LCD Monitor Logo
203 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
