Question about AEG Microwave Ovens
We have purchased a 15 year old apartment in a multi residential building in Brisbane which has AEG appliances. The self circulating range hood 14W fluro light fitting has ceased to operate and the clips or light cover has also been broken (cannot be "locked" back in the closed position). I have no reference to the model name of the rangehood other than a number [760D-w/GB] Can you advise where I may be able to obtain the 360mm long 14W fluro tube as well as the light cover diffuser and clips fort his particular unit, here in Brisbane Your assistance woud be much appreciated Thank you M. W. Cord
  • 3,083 Answers
The following website has some parts for your model, and might be able to help you:
http://www.inter-spares.co.uk/aeg/aeg-extractor-fans.html
If they don't have your parts, contact AEG- their contact information will be on the literature included with the unit.
Good luck, and hope this helps.
Posted on Dec 30, 2010
Machine goes through the motions but water comes out cold
Hi,you have not stated how old this unit is ? I think they are supposed to last for 4-5 years but I've known some to break after just one year and others that worked great for 15 years or more.
Read more: What is the average life span (during normal use) of a microwave oven? ' Answerbag http://www.answerbag.com/q_view/1540053#ixzz1TQlW7RlH
Carbon Heating Lamp for microwave oven strong heat resistance. More than 6000hrs lifespan.
From a website...
7.3.7 Magnetron Life Expectancy
The typical life of a magnetron tube is approximately 2000 hours of operation. Some factors that can diminish the life of a magnetron are: 1) no-load operation, 2) operating with too much metal in the cooking cavity, 3) line voltage consistently too low or too high, 4) improper phasing, 5) improper installation or removal, 6) replacing associated high-voltage components with substitutes that are incompatible with the system design, 6) continual operation at the upper limit of its heat tolerance due to inadequate air circulation, 7) obstruction in the wave-guide, 8) failed stirrer operation.
We use ours about 15 mins a day which would mean 2000 hours would be reached in 22 years but as they say there are a lot of factors which may reduce its life. The design and parameters of the oven will make a considerable difference. E.G. A highish power magnetron always underrun will last much longer than a smaller one run at its max ratings.
A restaurant might reach 2000 hours in only a year or so and industrial machines whether for cooking food or other processes will require frequent magnetron replacement.
http://www.alibaba.com/product-gs/439406670/Carbon_Heating_Lamp_for_microwave_oven.html
Jul 28, 2011 | AEG Microwave Ovens
GETTING A NEW STOVE THE OLD ONE HAS UPPER MICROWAVE ATTACHED W/ FAN UNDER IT LANDLORD SAYS ITS NOT MANDATORY TO HAVE A FAN IF YOU HAVE AN ELECTRIC STOVE. I THINK THEY ARE JUST CUTTING CORNERS? PLEASE REPLY...
Codes vary from district to district.
Contact your local building department for range hood codes in your area.
Code or not,range hoods are great for removing cooking fumes.
Sep 22, 2010 | Microwave Ovens
#mmv4203dw installation, the old one is out
The new microwave oven dimensions are 29 7/8" wide, with a depth of 15 1/2" and a height of 16 15/16". These measurements are listed on page 3 of your installation manual. If you do not have an installation manual, you can go to managemylife.com and type in the model number you provided under the "Manuals" link. The owner's and installation manuals are both listed in .pdf (Adobe) format that you can download or print for FREE.
So...to answer your initial question, "Yes", this model microwave oven will fit in the space that your old one previously occupied.
If you have any questions, please post back and let me know. I hope this helps you.
Apr 27, 2010 | Maytag 2.0 Cu. Ft. Over-the-Range...
My Maytag MMV1153BA Over The Range Micro suddenly lost power.
problem is a blow fuse inside the microwave, you need to call a appliance repair tech
Jun 28, 2009 | Maytag MMV1153A Microwave Oven
MIcrowave quit on February 15, 2008. I can't get parts to repair
seems like you have to replace the control/touch panel module of the oven.
Mar 21, 2009 | Jenn-Air JMC7000 Microwave Oven
JMV8208 BAW Model 30" Jenn-Air Convection/Micro combo
have a good look at front to see reset??.press it once it comes back on unplug from the wall and & open it up and go to the part and give it a good clean with wd40, check the push pad for ware & tare dirt gathers and builds up
Mar 09, 2009 | Jenn-Air JMV8208A Microwave Oven
Microwave not heating up food
This model is a lower-end type that probably didn't cost very much. Since it's over 2 years old, you have no warranty left. Most appliance repair shops charge extra $$ for servicing installed items in the home. You'd probably be better off purchasing a new comparable model. The labor fee alone might equal what you paid for it.
Jan 08, 2009 | Magic Chef Microwave Ovens
Need replacement bulbs for over-range hood
These are 20W 120V bulbs with what's called the intermediate base. The new Panasonic part number is ANE6030540AP and you can get them at Tritronics at http://www.wehaveparts.com or Vance Baldwin at http://www.vancebaldwin.com You should also be able to get them at local appliance parts stores, Lowe's (or similar) or even a large grocery store. You can also use Sharp part # RLMPT0003YBE0 from either of the above sites.
Dec 13, 2006 | Panasonic NN-2505A Microwave Oven
Microwave Ovens Logo
66 people viewed this question
Top AEG Microwave Ovens Experts
William Miller
William Miller
Kazim ERGUNEY
Kazim ERGUNEY
Raj Patel
Are you an AEG Microwave Oven Expert? Answer questions, earn points and help others
