Question about Sylvania G-Netbook
What settings do I use with the 7-in Sylvania netbook to connect to my wired network?
    Problem Solver:
  • 10 Answers
Open network and sharing center and you should be able to find out there
Posted on Dec 30, 2010
Cannot accress WiFi on Sylvania SYBET7WIC-BK-Z
The Sylvania Netbook is an inexpensive 7-inch device that is convenient for accessing the Internet on public or private Wi-Fi networks. It is not intended to replace a regular computer for daily tasks; its purpose is to provide a lightweight unit to access social media and perform small tasks. The netbook defaults to mobile websites, but it does a good job at what it is intended to do. Connecting to Wi-Fi networks with your Sylvania Netbook requires configuring the device properly.
Boot up the Sylvania Netbook by pushing the manual switch below the screen. Push the F9 key to turn on the Wi-Fi on the device. Select the little wireless icon in the toolbar at the bottom; it looks like a small computer. Choose the "Wireless Information" tab. This will show the online status of the device, as in whether it has connected to the Internet. If you have checked the box beside this option, this tab also notifies you when new networks are available. If the status shows that you have connected. You may need to add your wireless router manually in the setup. Do this by choosing, "Add New." Obtain the necessary setup information from your wireless Internet provider. If you have an encrypted network, you will need to fill in that information about your router. To configure the wireless setup further, click on the name of the wireless network. Click on "Advanced Settings" and adjust your connection choices; this tab determines the order of connection if there is more than one network available. Another important setting on this tab is the "Allow Windows to configure my wireless settings" option. Check that box. Click the "Internet Explorer" icon on the desktop. If you are online, you will pull up the Google homepage. Hope this helps.
Dec 27, 2012 | Sylvania Synet7wic-bk-z2 Netbook
My new sylvania 7" netbook is not
Go to start menu. click on control panel. click on network connections. click on the computer icon that comes up, to the left with list options, one of the options should be search for wireless networks. Your Wifi card might have gotten switched off by accident. The computer icon I spoke of earlier would likely say "not connected" right click and a box will appear click "connect".Or if it is a wireless window, you will want to click scan for available networks. Hope this helps
Mar 21, 2011 | Sylvania G-Netbook
I recently purchased the Sylvania wireless Netbook whose operating system is Windows CE. On our two desktops at home both use Windows 7. My computer downstairs is wired but through the use of a Cisco E...
It is looking for the password that you set your router to or network key.
couple of ways. You can reset your router, then it will default to factory settings and then it will delete your password and open itself up to not needing a password to get on your network. However, anyone can connect to your network, so you will have to enter into your networks menus and reset a password to prevent this, then set that password on all of the computers on the network now. You generally access your set up menu by typing your server IP address into your browser address bar, which is ususlly http://192.168.1.1
This is not all conclusive as some routers have other access methods, but the majority use the above. It will also require a User and a password and the default is usually admin and password or password1 for the default. If however, you have set a password then you definitely have to reset.
Reset is usually a small button , some recessed in a small hole that requires a tooth pick or un-bent paper clip to push into the hole and hold for 15 seconds with the power on the router. Sometimes turning the power off of the router for 2-5 minutes will cause it to reset.
You can also force the laptop(or any client of that server) that you are using and is connected to the internet to give you the english translation of the password. Click on your WiFi icon down in the right corner, A window opens,right click on the name of your network that is connected, click on properties, click on "show charcters." The network key(your password) will be revealed
Jan 31, 2011 | Sylvania G-Netbook
We have new netbook and we are connect to a wireless internet but my netbook will not connect to the internet.
First, on the left side of the main screen, you will see an icon that says "WI-FI Power". That's the switch to turn it on. When you click it, a little box will appear that says "turn on" when it's off and "turn off" when it's on.
But maybe you hadn't fully set machine up yet.
Try checking the following to see if any of these steps were missed.
On a "hooked up" computer, Google "digital gadgets.com". There find "Sylvania Products". Then click on "7 inch netbook support" and follow directions inputing to the 7" netbook as you go.
For item # 4, you find your "hot spot" name (on the 7" netbook) and click "connect".
For item # 5, you may have to call your Internet Service Provider (Charter, AT&T or whoever you pay for your internet) in order to get your "network key" fill that in (on the 7" netbook) and then click "OK".
Next (on the 7" netbook) be sure you go to "Start", "Settings", "Control Panel", "Internet Options", "General" and complete "user agent (requires browser restart" by selecting:
"Default (same as windows XP)" or
"Same As Pocket PC" or
"Windows CE".
I selected "default" and was off and running.
Dec 30, 2010 | Sylvania G-Netbook
I got a new Sylvania netbook and for some reason it won't connect completely to the internet. We have an open network and sometimes it won't connect at all, but when it does, it won't let me open certain...
Maybe you hadn't fully set it up.
For item # 5, you may have to call your Internet Service Provider (Charter, AT&T or whoever you pay for your internet) in order to get your "network keys" fill that in (on the 7" netbook) and then click "OK".
"Windows CE".
Although this isn't a "lap-top" it is a really neat little machine and does a lot of stuff almost like one. It should be great for travel! It is a little slow and has small memory, but it's inexpensive and usb/sd ports are there. A regular universal mouse helps-just plug it into a USB port. I'm doing internet, movies, YouTube, word processing,etc like everything and I think a lot of people have way under-rated this fun little machine!
IT WONT CONNECT TO WIRELESS AT ALL!!!!!!!!!! dsi's work but not computer wat iss up with that!?
But maybe you hadn't fully set the machine up yet.
"Windows CE".
Dec 28, 2010 | Sylvania G-Netbook
WiFi is connected , but internet explorer wont run
But maybe you hadn't fully set it up.
"Windows CE".
Dec 27, 2010 | Sylvania G-Netbook
7 inch netbook will connect to my wireless router with excellent strength however when connecting to internet says page cannot be displayed
"Windows CE".
Yes how you connect to the internet with your sylvania 7" netbook what programs you use to connect to the internet
Make sure your DHCP routers LanIP is setup as 192.168.1.1(nothing else will work). This is needed for wireless or wired access. On the Sylvania netbook press fn-F9 keys to turn on the wireless access. click and launch the wireless icon on the bottom of the screen and choose your wireless network from the information tab and click connect. Look at the connection status below the wireless list.
Sep 19, 2010 | Sylvania G-Netbook
Sylvania G-Netbook Logo
42 people viewed this question
Top Sylvania Computers & Internet Experts
Mike
Are you a Sylvania Computer and Internet Expert? Answer questions, earn points and help others
