The hot water not flowing into the washer and the cold water flows fine?
    Master:
  • 383 Answers
Let's think and work this one thru:
Your machine probably has several temperature settings, right?
So-- when you set it for COLD-- it fills at the normal rate?
When you set it for WARM-- does only COLD water still only come in?
And if you set it for HOT-- Nothing comes in?-- correct?
Now lets get to the pipes in the back:
Is there a Laundry sink, or a hose or something nearby, so you can be sure you have HOT water to the Washing Machine?-- Is the Hot water flowing good and strong nearby the WASHING MACHINE-- WHEN YOU TEST IT?
And the Valve is not shut at the Washing machine-- (Hot shut, but cold open?)
If you are sure that you have a good supply of HOT water to the machine,--- If you have tested that you actually have a good flow, -- say with the Hose removed, and you run the Hot water into the machine (by-passing the internal control valve!!)--
Then it sounds like: Either the control is not telling the internal solenoid valve to open-- or the valve needs to be replaced.
Do you want to attempt this repair-- or do you want to call for help at this point?
Let me know what you find-- and how far you want to go by yourself.
Mack B
Posted on Dec 30, 2010
  • Alexandriala Jan 17, 2011
    I have the same problem ...except with the cold water. I can flip the switch from hot to cold back and forth several times and the cold will eventually stay on until the rinse cycle....then I have to flip it back and forth several times again to get the cold water to stay on...help!
  • Mack Baxter Jan 17, 2011
    Hi Alex,
    Here was your original problem:
    the hot water not flowing into the washer and the cold water flows fine?
    Has the problem gone from HOT water to COLD water now?
    Did you reverse the Water Hose connections?
    When you say now, that you are "flipping it back and forth"-- are you talking about the control, or the hoses?
    Did you shut off the water valves, and test each hose for full flow of Both Hot and Cold water? (Like running full flow into your laundry tub..)-- are you sure the supply is adequate-- or is there a problem in the valves on the wall? --
    Please do these tests that I suggest, and get back with us.
    Mack B
5 Suggested Answers
docjohn174
  • 943 Answers
SOURCE: Hot water cycle flow problem
hi thanks for the question their is a screen in the water valve to catch any dirt you can try and remove the screen in the water valve and try again if it works ok . it usually works thanks the appliance doc
Posted on Sep 24, 2008
SolutionGuy
  • 331 Answers
SOURCE: whirlpool washer model lsr8233eq1
Hi gastang,
The problem is with your water valve. It needs to be replaced.
To access the washer follow these steps...
UNPLUG THE WASHER!
1.) Remove the 2 screws from either side of the control panel.
2.) Pull the control toward you a 1/4", then rotate it up and all the way over.
3.) Remove the white plastic wire connector to the top panel (it has 3 wires in it.).
4.) Remove the two clips on either side of the top panel. Do this with a screwdriver. Poke the screwdriver into the top panel to engage the clip, now rotate the screwdriver toward the rear panel.
5.) Lift the lid (for a hand hold) and rotate the entire cabinet forward to about a 45 degree angle then slide it toward you. Set it aside.
Here's a video that shows how it's done. But you'll notice that the screws on your control panel are in the front, the video has the screws in the back, but the rest is the same. Here's the video.
After you have access, you'll see the water valve on the right.
If this was helpful, would you take a moment and rate my solution? Thanks,
SG
Posted on Mar 29, 2009
mindreader
  • 578 Answers
SOURCE: COLD WATER IS RUNNING SLOW INTO WASHER
Based on your description, the selenoid is bad.
The same device feeds both cold and hot water - so locate your machine model number and year.. and look up the replacement incoming water selenoid part number. You will need to purchase it and replace it.
If your machine is under warranty, call their Customer Service line and report the water flow/noise problem.
Please let us know your findings...
-Jim
Posted on Oct 17, 2009
jsrock516
  • 5911 Answers
SOURCE: hot water not getting to washer
This problem is commonly attributed to a defective water inlet valve (also known as a mixing valve). The valve has two electronic solenoids that control the turning on and off the hot and cold water. If the cold water works, but the hot water does not, chances are the hot water solenoid is bad. The following link explains how to access and replace one:
http://www.fixya.com/support/r3575881-replacing_water_inlet_valve_on_whirlpool
If you post back with the model number I may be able to provide you with a part number. You can purchase replacement parts at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between sites so shop and compare. The first three sites also have helpful exploded view diagrams you can use to refer to for easy part identification.
If you have any questions about this repair, please let me know. I hope this helps you.
Posted on Dec 08, 2009
Testimonial: "totally rocked it for us !! We are do it yourselfers and appreciate the help!!"
Why would the hot water cycle of my washing machine not work?
The solenoid that opens to admit hot water is either defective or not being energized by control panel.
Jun 20, 2017 | Washing Machines
Error code of NF (no fill) on samsung top load washer (WA422PRHDWR/AA) even after checking lines for restrictions and ensuring clean line filters (red and blue). Now, when it does work, it will only do a...
Put the temp select switch on HOT, start machine. If water comes out check the flow amount. If no water flow, replace inlet water valve. If there is water flow switch to COLD, start machine. If water comes out check the flow amount should be approximately equal or slightly more than flow on HOT. If no water flow, replace inlet water valve. Move selector to WARM, start machine. Now there should be twice the flow of water than there was with HOT and COLD temps. I suspect it is the HOT side of inlet water valve that has failed because machines usually rinse with COLD water.
Jan 20, 2013 | Samsung WA422PRHDWR 4.2 Cu. Ft. VRT Top...
Hot water fills very slow(30 MIN OR MORE TO FILL) good water flow from spicket to washer, screens are clear. sewems to be something with the washer its self
Might be a bad inlet valve. To confirm, swap the hot and cold hoses to your washer so that the cold water feeds the hot water connection and the hot water feeds the cold water connection. Turn off both hot and cold water faucets. Set the washer for a warm water wash. Turn on the cold water faucet, and check the flow. Then turn off the cold water faucet, and turn on the hot water faucet and check the flow. If the cold water flow fill slowly, then the problem is with the inlet valve.
It an easy part to obtain from an appliance supply house. To install disconnect the hoses to the back of the machine, and remove the back panel to get access to the valve. Should only take a couple of minutes to remove and install. Hope this helps you.
Oct 26, 2010 | Kenmore 24032\24036 Top Load Washer
Why doesn't cold water flow into the washer through the Smartwater filter? When my Maytag Performa's Wash/Rinse temperature dial is set on Cold/cold no water flows into the tub. But when I set it on...
Hi .. I would first check the supply valve at the washer to be sure that it is open. if it is open , you can check the flow by shutting it off, removing the supply hose, opening the valve slowly and observing the flow. You might need a small bucket here. If you have water flow here at the washer supply valve, then the problem is inside the washer control.
Apr 18, 2010 | General Electric GE SmartWater Household...
COLD WATER IS RUNNING SLOW INTO WASHER. THERE IS PLENTY OF FLOW IN THE HOSE AND NO KINKS AND THE SCREEN IS CLEAN. HOT WATER FLOW IS FINE. WASHING MACHINE MAKES A GROANING NOISE WHEN COLD WATER IS ENTERING.
-Jim
Oct 17, 2009 | Washing Machines
Hot water just trickles in both of my Kenmore top loader washers
Try reversing hot for cold hoses and see what happens. That will test your valves, hot water pressure, etc. As far as I know, the valve screens are right where the hoses hook up.
Apr 30, 2009 | Kenmore 22422 Top Load Washer
Fisher Paykel GWL11 Cold Water Not Flowing
you can swap the hot and cold valves over and see if this fixes the problem as it sound like your cold valve is faulty but not the hot valve.
Cheers
Mar 24, 2009 | Fisher and Paykel GWL11 Top Load Washer
Water Flow
disconnect your hoses and check for pressure without connected o machine, then check with int he water inlet valce for a clogged screeen slowing the pressure
Jan 25, 2009 | Roper RTW4300SQ Top Load Washer
Washing maching won't rinse in cold water
hi is this hot and cold water piped machine? ie two connections on rear of machine for hot and cold pipes ? if so are your pipes connected properly on machine and the water supplies? if cold supply is connected to hot supply then wash inlet allows water in washer then washes in cold? but when rinse is due? the elec valve that has hot water pipe connected?? is failing to open allowing water flow of hot on rinse so advise recheck pipes for flow of water from both? when disconnected from machine if flow ok then possible valve blocked/faulty hope you can understand above? if you can give more info on your machine it would help to offer a remedy?
Nov 01, 2008 | Hotpoint Washing Machines
Washing Machines Logo
74 people viewed this question
Top Washing Machines Experts
