Question about Fisher and Paykel IWL12 Top Load Washer
I am getting service code 37, what does that mean and how can I fix it?
    President:
  • 1,554 Answers
It's error code 37 and it means pump blocked error. Either the drain hose is clogged or kinked, the diverter valve has failed, or the pump itself is restricted or not working at all. Check to make sure that the drain hose is clear then disconnect power and lay the machine on its front on a cushioned surface to access the drain pump and the diverter valve. Remove the pump's inlet and outlet hoses then check and clear them from any debris that may prevent water from draining out. Check the impeller for any damage or restriction. Make sure the impeller is not frozen or blocked.
Check the diverter valve for the same condition as the pump described above. The diverter valve is where the drain pump and the recirculation pump inlet hoses are attached from. Make sure the diverter valve is in the drain position while the drain pump is working. Replace the drain pump and/or the diverter valve if deemed necessary.
Posted on Dec 30, 2010
Testimonial: "so far, so good--thank you!"
  • kmwatson Jan 11, 2011
    I had the same error and went to fix it after reading this. First I had to empty out the clothes and in doing so, realised there was a belt for a dressing gown wrapped around the agitator. Once that was removed the machine worked properly again. :)
  • Jahn27
    Jahn27 Feb 27, 2011
    The same error popped up because the gown belt wrapped around the agitator prevented the basket to engage for the spin cycle. The basket drops as it drains to engage the basket for spin and if the basket cannot engage, the motor controller module thinks the basket is still floating due water not being drained because of a blocked pump.
Car keep cutting off while driving
Code 37 means your torque converter clutch solenoid could be bad however the electrical connection for that is located just above the dipstick on the front of the tranny check that first unplug it clean it up and reseat it this will usually fix it .
Jun 17, 2013 | 1995 Plymouth Neon
Code 37 -
To my knowledge, Error Code 37 on a Fisher & Paykel machine refers to "drain fault" which could either mean that the drain valve will not open or that the drain pump will not run. The easiest user intervention that could be performed is to check for any blockage/clog at the drain filter, drain pipe, drain pump impeller and drain valve.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jul 16, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
What does code 37 mean for check engine on 2007 v star 1100
Hi, Michael for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
http://www.starmotorcycles.com/assets/service/manuals/2000/LIT-11626-13-36_96.pdf
OEM parts for Yamaha
http://www.sloneservices.com/SilverBack/Other-Stuff/V-StarShopManual99-07.pdf
Check Engine Trouble Codes Star 1100 Wiki Knowledge Base
ERROR code 37
Jul 21, 2012 | Yamaha V Star 1100 Classic Motorcycles
I have a 1993 Chevy Silverado 1500. trouble codes 22, 35, & 37. what do they mean?
code 22 throttle position sensor low voltage
code 35 EGR
code 37 doesnt exist but im getting a code 37 also
Nov 08, 2011 | 1993 Chevrolet K1500
CODE P1456
this obd2 trouble code table can help u understand the meaning of code.
http://www.chinasinoy.com/service/how-to-understand-trouble-codes-37.html
Sep 08, 2011 | 2000 Acura TL
I own a Philips 42PF7220A/37 42'' TV (LED flashes red, some people on the net say its the capacitor c2074 to be replaced with a 2200uf 35v. for some reason i cant seem to find that capacitor number. can...
Most likely the problem is your Philips 42PF7220A/37, may not have the same power supply board as other people are talking about on the net. So, the C2074 capacitor maybe under a different number.
The best thing I would do if I had the same problem is to get a Service Manual on the internet. It cost about less than $20. Right now your TV is in " Protection Mode" and blinking a trouble code with the red light. The Service Manual will tell you what the red light blinking code means. Plus, it will give you schematics, part numbers list, and test point for diagnosing. It's better to have a manual for fixing than going by guesses over the internet.
Jul 17, 2009 | Philips Televison & Video
Screen has code 37 on it
Hi, welcome!
Code 37 is a "pump blocked error" code. Typically this code is triggered when the machine does not sense a change in the water level when called for. Check for debris caught in the pump, either in the impeller for moving water or in some cases, the external cooling fan impeller (exposed underneath the machine) gets snagged with a piece of fabric softener sheet (such as "bounce") and this will stall the pump and trigger a code 37.
I hope you find this info useful and thanks for using Fixya.
Jan 26, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
Mitsubishi wd52525 shows error code 37
error code 37 is either the dmd fan or the lamp fan. you can see the dmd fan with the cover off. you cannot set the lamp fan as it is under the light engine. I guess the easiest thing to do is get a lamp fan 299P282010 and a dmd fan 299P283010 and change them both.
Nov 16, 2008 | Mitsubishi WD-52525 52" Rear Projection...
KEEP GETTING CODE 37
From your description Code 37 means either DMD board deffective or lamp fan stopped.so in your case fan is good I would suggest replace light engine.because DMD board is the part of light engine.
Part number # 915P026010
Oct 06, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Philips 51PP9200D/37 not comming on
Check the site www.TvRepairKits.com. They have put together a couple of kits to fix the chirping set/dead set condition. If you don't see your model listed send them and email and they will build a parts kit for you.
Dec 11, 2007 | Philips 51PP9200D Television
Fisher and Paykel IWL12 Top Load Washer Logo
598 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
marley mcelhinney
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
