Question about Duracell Crank Light 3 In 1, 3 Led Flashlight, Radio, Charger. 2 Pack
Model: KP028 It doesn't work no matter how long I tried to charge it. I haven't used it for a few months though. Is there anyway that I can make it work again?
The batteries are gone . it carries 3 small 1.2volts battery 1 1/8" long and 3/8" in diameter soldered together making it 3.6 volts why couldnt duracel used aaa instead .couldnt find these batteries online. batteries are nickel metal hydride type 300mah.
Posted on Jul 22, 2011
I have a Samsung TL100 camera and it will not take a charge
If you haven't used it for the last 8 months and before it was all fine then the most common reason would be the battery. Your battery is absolutely dead but then again if you plug it to AC then it must show some sign of life. But give it a go by replacing new battery. To check get it from a friend and then test the camera on it.
If the battery replacement doesn't work then take it to an authorized dealer for inspection.
Oct 30, 2012 | Samsung TL100 Digital Camera
Knee pressed on screen but not broken. Few letters smeared.
You may try rebooting it, but it will most likely not work. The screen doesn't have to be broken in the most common sense to be faulty. If you still have your warranty, then just replace it. As there really aren't any parts sold separately, you won't be able to replace it by yourself anyways and you have to replace it either way if you don't want a faulty screen.
Oct 18, 2012 | Amazon Kindle Wireless Reading Device
Whirlpool model 110.88752792 dryer runs but does not heat
Concerning the Kenmore 11088752792 model where the dryer spins but does not heat. I had that problem a few years ago with the same model.
I replaced the fuse (part No. 3399849 about $10.00) and the thermostat (part no 3398128 about $25.00). Dryer worked fine the first try.
FYI. Today, I'm searching for what makes the dryer squeak when I came across your issue (though 6 months since you posted, but I figure there are other Kenmore stack-able owners out there searching for a fix). I haven't taken the dryer apart yet but have ordered the dryer belt, rollers, pulley (a package deal with RepairClinic) and the felt bearing/seal. May as well do a full replacement of the likely components that are causing the squeaks and not spend any more time going through trial and error repairs.
If you haven't already, the dogs on your agitator are probably due for replacement as well. RepairClinic has an agitator package deal with replacement dogs and seals.
Jul 14, 2011 | Kenmore 94802 Front Load Stacked Washer /...
I have recently purchased a LG LCD TV Model 32LK330. Everything seems to work fine except all of the people look as if they had gained an additional 100 pounds. Is this distortion natural.
It is aboslutely normal. The aspect ratios on LCDs are different from the good ol' CRTs and CRT based projection tvs. As a matter of fact when I got my first LCD tv, it took me a few months to get used to it. You can try other aspect ratios though by going to Menu-> Picture->aspect ratio and try the different settings available to see if any of them works for you.
Jul 14, 2011 | LG Televison & Video
Appears to be working but we only get cool air; not outside temp and not cold, no matter how high we turn it up. Model is really Goldstar AC 301KA00871.
This sounds as though you are low on freon. Normally, this is the last thing I would say, but with what you have said, you need to have the charge checked. If all is working but the air is not cold, but cool only, The model you gave me doesn't tell me much on the type system you have, if its a window, central system or package unit. You can try taking the water hose and washing the condenser coil if you are able to do so, if it is dirty it will cause the system pressures to be very high causing it not to cool.Anyway, do this and if you still have this problem, you will need to get it charged up. This is something you can't do on your own, as you can't buy this freon, or you don't have the know how to do this. You have to have the gauges and know the pressures in the system. I hope this has been of help to you.
Shastalaker7
A/C, & Heating Contractor.
May 27, 2011 | Heating & Cooling
I have a gateway Model NV59C i ahve used it sparingly for the past month now all of a sudden it will only charge to 90% no matter how long it's plugged in.
The battery calibration is off.Run the battery all the way down until it shuts off then recharge it till it stops charging.Do this several times and maybe it will get recalibrated but sometimes it won't help though.
Feb 04, 2011 | Gateway Computers & Internet
1993 CORVETTE AC PROBLEM
Are you fully charged though? If you don't have a full charge the clutch will not kick in.
Aug 18, 2009 | 1993 Chevrolet Corvette
Short Battery Life
it is the matter of battery life time-nothing wrong
Aug 05, 2007 | Sharp EL-9600C Calculator
Duracell Crank Light 3 In 1, 3 Led Flashlight, Radio, Charger. 2 Pack Logo
1,091 people viewed this question
Top Duracell Camping, Backpacking & Hiking Experts
Andrew Taylor
Andrew Taylor
Tom Chichester
Bill Boyd
Are you a Duracell Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
