Question about Garden
I have an older Allied International 3 ton service jack that does not work correctly. It does not appear to have a leak, but the it only goes up about half way when pump the handle. I remember from several years ago (ten or twelve) that I had to pump the handle quickly 20 times with the lock released then it would work. I have not used it in six years and now it will not jack up. I tried the pumping and that did not help. I think perhaps it is low on hydraulic jack oil, which I have some, but am not sure of the procedure to put the jack oil in. Exactly where and how much?
  • Dan Maguire Dec 30, 2010
    I am not sure how this got listed under Chainsaws, I did not make any inference to chainsaws when I asked for help.
dontbother10
  • 2220 Answers
SOURCE: My Stihl 015AV leaks oil from the oil pump area.
This is an international collection of chainsaw enthusiasts with a few 2-cycle mechanics thrown in for good measure.
ArboristSite.com Chainsaw thread (free to join)
http://www.arboristsite.com/forumdisplay.php?f=9
This thread is discussing an oil leak on a Stihl 015; join in.
http://www.arboristsite.com/showthread.php?t=114962&highlight=stihl+015+oil
HTH
Lou
Posted on Jan 17, 2010
SOURCE: pp4620avhd (Oil pump does not work)
Poluan has redesigned the oil pickup from multiple pieces, to a single rubber piece that fixes this problem as well as the leaking after shut-off. Its only a couple of dollars, and actually works
Posted on Dec 30, 2008
  • 3 Answers
SOURCE: Hydraulics Pump not working
look around for a valve or a switch,and or button
Posted on Jan 13, 2009
  • 211 Answers
SOURCE: Bad Clutch??
Hi
Before other checking change the spring of the clutch(2).
best regards savumihai71
Posted on Feb 16, 2009
  • 29 Answers
SOURCE: 2002 Mitsubishi Lancer Oil Light at Low RPMS.
could be the oil pump, but before you get to that, whens the last time you had you oil changed? is it the right type? was the filter changed to? if the oil is to thick for your engine, the pump could be having a problem pushing it. If its dirty, same thing applies. Next time you change your oil, be sure to use a full synthetic. its a superior oil all around.
Posted on Mar 23, 2009
How to overhaul/ repair a hydraulic floor jack?
Sounds like a bad seal on that plunger that pumps up and down. That plunger should unscrew and then it's pilled out , there should be an O ring. That is where it probably is leaking. You probably need to top off oil. You can jack oil in an auto store or Lowes, etc.
Jun 08, 2014 | Automotive HEAVYDUTY Hydraulic Bottle Jack...
Sears 11/2 ton floor jack
Is there anywhere that you can tighten the seal retainer if not needs a new seal . My experience is that a seal kit is as expensive as buying a new jack plus the work that goes into it. Look up how much to buy a new one and a set of seals then decide
Oct 21, 2013 | Washing Machines
Your company has just moved to a new office building. The server has a fiber optic network adapter, but the building does not have fiber optic cables installed. How do you install a media converter?
100BaeFX to 100BaseTx media converter. ST to SC cable.
SCA connector goes to the RX port in media converter.
STA connector goes to the TX jack on network adapter.
SC male B to TX port on media converter.
ST male B connector to the RX jack on network adapter.
Connect media converter to network with Cat5e cable which uses RJ-45 connectors.
Jan 25, 2012 | Allied Telesyn Allied Telesis AT MC1004 -...
I just inherited an older 3 ton floor jack. Guardian make, Model 4-102, 3000 lb. capacity. What type of fluyid does it take. who would I contact for repair parts? thanks
It was made by Hein-Werner, Similar to the WS model also 3,000lbs (not 3 tons). Been out of production at least 20 years or more. Guardian was Hein-Werner's cheaper off brand. Kind of a "dumbed-down" version. Also made an H-101 which was similar to H-W OS (O-Boy) model of 2500lbs.
Try a hydraulics dealer who sells Hein Werner parts. although obsolete, about 1/2 the parts are still available.
Lastly: Hydraulic jack oil. Never use brake fluid. Engine oil in a pinch, by I would never do it.
Jun 22, 2011 | Garden
Jack will not stay up under a load
the jack could be leaking oil out of the ram. the seals will need replacing if the ram is leaking.
Jan 29, 2011 | OTC Stinger 3 Ton Jack Pack
15-ton Allied commercial a/c
it may not be the start of the generator but the voltage drop. most monitors have a low voltage cut out and a line differential setting have you compared the settings with this monitor, does it have an auto reset option to turn on
Jul 30, 2009 | Heating & Cooling
Craftsman 3 ton floor jack will not stay up
you need to bleed the air from the cylinder. there should be an air bleed or else you bleed it at the relief needle. also, if it still leaks down after you bleeed out the air, the seat for the relief valve or the seals at the relief valve cartridge are worn
Apr 01, 2009 | Home Fencing
What Jack and stand to get for my '04 Ram 1500 Short Bed V6?
THE SAFEST CHOICE IS THE 3 TON.. YOU COULD GO WITH THE 2 OR 2.5 TON, BUT WITH THE SIZE OF YOUR TRUCK YOU NEED THE 3 TON..REMEBER TO ALWAYS USE THE JACK STANDS..GOOD LUCK KEITH...
Mar 14, 2009 | 2004 Dodge Ram 1500
Sears 4 Ton Hydraulic Automotive Floor Jack-Will Not Lift ?
I have a Sears 1 1/2 ton floor jack. I was able to buy a repair kit from Astro Pneumatic Tool Company 372 OLD U.S. Hwy 52 South Mount Airy N,C 27030-8093
1-800-221-9705
John
Sep 27, 2008 | Plumbing
Garden Logo
245 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
