Question about Frigidaire FGF316 Gas Kitchen Range
When turning on the oven it heats up slowly. And u start. To smell. Gas bad
  • 1,772 Answers
Sorry to read about your problem, I hope this helps you out.
you may have a defective gas control valve.i would keep off until corrected.
THIS IS A GAS PRODUCT, INCORRECT REPAIR CAN CAUSE A EXPLOSION, AND DEATH CAN OCCUR. IF YOU DO HAVE THE PROPER TOOLS SUCH AS MANOMETER AND LEAK DETECTORS, I SUGGEST YOU CONTACT A SERVICE COMPANY
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
Posted on Dec 30, 2010
Testimonial: "Thank you for all your help with your help I will be able to keep my 2 children and prgenant wise safe. "
Have a maytag Stove Model# mgr5729adw oven stopped working and just before it did smelled gas. ignitor looks to be good no cracks.
Our Maytag MGR5729ADW recently started having a problem. Whenever the oven was turned on gas would flow but did not ignite. My wife thought she was baking, but I walked in the kitchen and smell a heavy gas smell. Bad igniter or not the gas control valve should never open unless there is ignition. Had we turned on the oven and left the house, there would have been a major problem.
After a little more checking I will probably replace the igniter and the gas control valve. The parts are not cheap but neither is a house.
Dec 30, 2012 | Kitchen Ranges
Replace the heating element, second time using it turned it on and started to smell gas. Opened the oven and was greeted by a fireball. turned off no damage. I turned it on again and didn't smell a leak...
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
m,vn
Sep 06, 2010 | Frigidaire FGF366CC Stainless Steel Gas...
Oven ingniter lights , smell gas but oven doesnt turn on
Hello- Ignitors may 'light' yet not reach proper resistance and temperature, causing improper gas flow past valve. If resistance is below 4 ohms, ignitor is bad. Part is 40-75$ at local app. parts store. Fairly easy to replace. Hope this helps. -Thanks- ED
Mar 01, 2010 | Kenmore 71513 Gas Kitchen Range
My Amana gas oven won't heat up gas smell strong
Sounds like a sticking gas valve or a defective hot surface igniter. Open the broiler drawer or remove the bottom cover in the oven compartment. The oven usually has a hot surface igniter or a spark igniter. Turn on the oven and watch for the hot surface igniter to start glowing. It should glow very bright. Once it is glowing the burner gas should come on. If you hear the gas come on it should light right away. If there is any delay shut off the oven and stay back. Let the gas clear out then inspect the area near the igniter and make sure the burner is not plugged(the little holes may have debris in them). If you turn on the oven and the igniter comes,glows brightly,no gas is heard but you can smell gas it is either a blocked burner orfice/assembly or sticking gas control valve. Try giving the burner and gas control valve a tap and see if it comes on. If you tap the control valve and it starts working then shut of the oven and try it several times. If it starts to come on and off now you may have cleared whatever debris was causing the problem. If it does it again then it could be the control valve or a weak hot surface igniter. The igniter can be tested with a ohm meter. Most of the time when I get this complaint it is the oven control valve that is sticking. Be very careful when doing these procedures....gas can build up in the oven compartment very quicky and flash if ignited. Always have the gas shut off valve at the back of the range within reach and the electrical outlet in case you need to unplug it.
Sep 13, 2009 | Magic Chef 9122 Gas Single Oven
Oven works sporadically
IF YOU CAN SMELL GAS, TURN THE STOVE TAP OFF. Get it checked out immediatly.
Aug 03, 2009 | Whirlpool GS460 Gas Kitchen Range
Oven heats very slowly
If your top burners work ok, regulator should be ok. Majority of times the fail part in the oven is the ignitor...turn oven on and check for a flame after 10 mins. small flame could mean a bad safety valve.
Jun 09, 2009 | Maytag MGR5870 Gas Kitchen Range
Ge gas oven with electronic ignition
yea sounds like you have a bad oven ignitor, tell tale signs are not heating past warm, smells gas, too long to cook, popping noises while cooking. Id replace that ignitor. Although it might appear to "glow" not glowing strong enough
Feb 28, 2008 | Kitchen Ranges
Amana oven gas leak issue
staunch has no idea what he is talking about. It has nothing to do with the igniter, or it would fire up at all. Since you are saying that your oven does ignite and heat up, it is the internal gas valve that is the problem.
The way all recent (20 year at least) are designed, the gas valve internally can not open unless the igniter is working, for obvious reasons ... boom! The igniter circuit allows the gas valve to open, once it detects that the igniter is ready to "ignite" a gas flow. BUT, the valve can be bad in the AMOUNT of gas being delivered. Your's is allowing too much gas, more than can be burned, hence the smell.
DON'T use the oven until you have a qualitifed tech come out and replace the valve. It is very dangerous for you to do it yourself.
Nov 22, 2007 | Kitchen Ranges
Gas leak from oven
Sounds like the ignitor is weak and needs to be replaced. How old is the oven and what is the model # from the sticker on oven?
Nov 06, 2007 | Jenn-Air JJW8530C Expressions Collection...
Frigidaire FGF316 Gas Kitchen Range Logo
2,220 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
