Question about Genie Company Genie PowerLift Excelerator 8 Ft Door Extension Kit, 36326R
Why wont the carriage assembly go past the screw splice
I think the threads are different. I have the same problem and the threads in the small splice part are different. i must have the wrong splice.
Posted on Jan 18, 2011
I cannot figure out how to install the left had rail for the Ice drawer on my Sub zero #632 refrigerator
you have to remove both screws in both rails, and pull the whole carriage and rail out as an assembly. then replace the rail, put the whole assembly back in, making sure to line up the hooks on the back of the rail with the screws way back in the back that aren't removed. then slide the ice bucket carriage back all the way in and put back in the 2 screws in each rail. good luck!
Dec 10, 2013 | Sub-Zero Refrigerators
Replacing the service station
Switch off the printer and remove the power cable
1. Remove the Right Cover
2. Disconnect the two lower connectors from the PrintMech PCA.
3. Unroute the two cables disconnected in step 2 from the two cable clamps below the PrintMech PCA.
4. Remove the grounding cable attachment screw from the PrintMech PCA.
5. Disconnect the Aerosol Fan Assembly inline connector.
6. Disconnect connector from the Drop Detector Motor and Drop Detector Sensor.
7. Unroute the cables disconnected in steps 4 and 6 from the two cable clamps.
8. Loosen the T-10 uncapping screw sufficiently so you can manually move the Carriage.
9. Push the Carriage Assembly into the print path to gain access to two T-15 screws that secure the Service Station to the Carriage Rail.
10. Remove the two allen screws that secure the Service Station to the Carriage Rail.
If you are uncapping a 44 inch printer, you will need to use either a very long or very short
screwdriver to loosen the uncapping screw.
In this way, you can loosen the screw and pass the rewinder motor.
Support the Service Station so it does not fall when you remove the attachment screws.
11. Unclip the clip to release the Service Station from the printer.
12. Lower the Service Station until you can slide it carefully from the printer.
13. Carefully slide the Service Station from the printer.
When you finish installing or replacing this component, you must perform the
necessary Service Calibrations.
Aug 28, 2013 | HP Designjet T610 InkJet Printer
C3100 call service
C3100 is a scanner carriage problem... The error code indicates that the "home signal" is not reaching the main board in the required time; The problem could be a bad board, bad motor or something mechanical...
Keeping it simple: look through the copy glass; there are two main parts or carriages. The first part is the assembly with the lamp and single mirror. The second part is the assembly with two mirrors. Both of these *ssemblies ride on rails and are connected to each other by a system of cables and pulleys. When unboxed, the KM3035 has 3 yellow screws on the upper left cover that lock the scanner assembly to prevent damage during transit... were these screws removed? Does the scanner assembly move at all when you power the machine on? Look through the copy glass: the scanner cables should be seen connected to the carriages and going around the pulleys; the cables should not be loose or laying on the deck. The home sensor might not be visible to you if the both carriages are in the way, but it is a small black object with two projections. A flag on the carriage slides between the gap created by the projections (this is the home position). Looking through the glass, the sensor is located at the left rear corner and it should not be hanging or tilted.
Feb 06, 2013 | Kyocera Office Equipment & Supplies
Hp designjet 500plus ,first time i change carriage belt ,but now it shown allignment error..
Two thing you need to check:
1. Are you replaced genuine carriage belt?.. Original belt having two type of inner tracks.. Right side horizontal & left side vertical tracks. Are you fixed it properly or not..
2. Check carriage assembly play.If it is over play(carriage bushes may be warn out) alignment won't complete, If bushes are available in your country replace them & do the calibration..If not go down how to alter bush. see the snap shot
3. While carriage movement pl check trailing cable flexibility.
Carriage Bush:
Note:This modification only professional not for users:
Un screw screws both sides as shown in fig, take out bushes estimate how much warn out happened.
Thing needed:
Fevi quik(glue),small peace of miler sheet,scissor & tweezers.
Cut miler sheet in to small peace & insert warn out place of bush(between bush & rail) & apply glue, fix it permanently,do it both sides & check for the carriage play.. once its finished try for alignment.. For this activity no need to remove carriage assembly from the rail. Main aim is alter bush warn out..
May 30, 2012 | HP DESIGNJET 500 InkJet Plotter Printer
What to do?
Clean Cartridge contacts in carriage assembly with solvent(Alcohol), try it. No result any one of carriage assembly or fomatter faulty, I wont suggest to go for repair because of it's expensive.
Feb 02, 2012 | HP Officejet 5510 All-In-One Thermal...
Hi the gun wont fire
Had the same problem with mine. Remove the 3 screws on top and remove the lid. on mine the firing pin assembly was jammed. If the roller seems to be holding the pin carriage too tight then you need to prise up the spring mechanism over the carriage. To do this go to the end at the back of the machine and insert a screwdriver between the top carriage and the frame. prise gently and it should pop up. the firing pin should now move freely
May 12, 2010 | Dewalt DC618KA Angled Nailer Kit
RIBBON WONT STAY DOWN WHEN YOU TYPE
Carrriage assembly could be broken, otherwise screw is popped out of gear in the right. With carriage all the way left, take out screw in the middle of white gear, pull out gear and pin, push down carriage top, insert pin in carriage and re-install screw.
Jul 02, 2009 | Brother GX-6750 Typewriter
Problem with Printhead Path
Something (not sure what) is obstructing the movement of the carriage assembly. Turn off the power and remove the cleaners. Push the carriage assembly out and pull/push the belt to move the carriage assembly until you find the bind. If you've recently changed the belt or carriage assembly, make sure you properly adjusted the carriage height.
Jun 05, 2009 | HP DesignJet 1050c plus InkJet Printer
Return key doesnt work properly
Try putting a little light oil on the silver shaft that the printer slides on, WD40 works well.
DickyO
Dec 09, 2008 | Lexmark Wheelwriter 1000 Typewriter
Genie Company Genie PowerLift Excelerator 8 Ft Door Extension Kit, 36326R Logo
176 people viewed this question
Top Genie Company Home Security Experts
Lawrence Oravetz
Are you a Genie Company Home Security Expert? Answer questions, earn points and help others
