Question about Toshiba Satellite A105 Notebook
Gets to hot and keeps shutting down
My computer keeps getting hot and shutting down.. Any suggestions?
  • mauicutiepie Jul 11, 2008
    There, I did as you suggest.......gave you feedback but to be honest, it didn't help me in the least because I have no idea how to take the fan out.. And I would never take my laptop apart myself
    President:
  • Toshiba Master
  • 1,314 Answers
1. Check to make sure the air vents are dust free.
2. Check to make sure the fan is working.
3. If it is dust free and you can feel the fan working, then you may need to reapply new thermal compound between the heatsink and the cpu. This involves removing various components on the computer such as the power switch cover, the keyboard, and possibly the lcd screen.
Thanks and please take a moment to rate as fixya.
Posted on Jul 07, 2008
  • Kevin Shafer
    Kevin Shafer Jul 10, 2008
    Can you please come back and either rate as helpful or fixya? Your question was for suggestions about why your computer keeps getting hot and shutting down and that is what i gave you were suggestions; at the very least helpful. Thank you.
  • Kevin Shafer
    Kevin Shafer Jul 11, 2008
    Thanks but your question was for suggestions and that is what I gave you was a suggestion. Just because you didn't feel comfortable fixing it shouldn't mean I should get a mediocre rating especially when you rated someone else a helpful rating with the same answer. Thanks again.
My acer aspire ax 1300 is shutting off at startup and it gets hot plus the fan is running really slow making noises and it keeps showing windows error recovery it keeps shutting down? please help? it...
Your CPU is overheating. When this happens the safety mechanism causes your computer to shutdown to prevent further problems. The CPU fan will need to be replaced.
Apr 09, 2014 | Acer Computers & Internet
My 96 jeep grand cherokee keeps dieing when it gets hot
My first question would be, do you know if the cooling fan is coming on ? ?
The computer can shut down the engine if it reaches 250 or 260 degrees. You could also have a coil or other electrical part that is failing when hot.
Aug 30, 2012 | 1996 Jeep Grand Cherokee
When the car is driven and motor gets hot the car shuts down but when it cools down it starts and runs fine again until it gets hot
IT is most likely the thermastat but i would not suggest driving it until it fixed as that could cause the head to crack witch costs around $213 - $250
Jul 27, 2012 | 1993 Dodge Dynasty
Car got hot and shut off. I was hoping for a fuel shut off switch of some sort in the trunk or a fuse block/circuit breaker or something easy. Any suggestions?
if it only shut's down when it gets hot and won't start until it cools down it sounds like the ignition module is getting hot and breaking down
Nov 04, 2009 | 2001 Buick Century
Freezer not freezing, and the panel between the fridge and the freezer gets very hot
The condensor fan motor is probably not running. The condensor fan keeps the compresor cooled, if the compresor gets to hot, it shuts down until it cools off and tuns back on, but will not keep temp. Heat exchange lines go in the panel between the doors to serve as a heater so the doors dont freeze shut, but when the compresor overheats, so do those lines. That would be why that panel gets so hot. Both problems will be resolved with a new condensor fan motor ( located by the compresor).
Oct 16, 2009 | Estate TS25AFXK Side by Side Refrigerator
HAVE A KENWOOD AMP MODEL KAC-9102D . iT KEEPS SHUTTING OFF WHEN i TURN THE RADIO LOUD. ANY SUGGESTIONS
either bad ohm load or over heat if the ohs on the speaker wires to the amp are lower than specified use in the manual it will act funny cause it is pusing harder than its meant to and if it gets too hot either bad location or bad amp you can try turning the gain down a little until the amp stays on constantly at high volume
May 18, 2009 | Kenwood KAC-9152D Car Audio Amplifier
Top of keyboard gets hot and shuts off frequently.
The reason it is shutting down is because it is overheating. It used to happen to me as well. Are you using this on a bed or other soft object?
May 09, 2009 | Computers & Internet
Keeps Shutting Down
First, start by taking the fan and heat sink out and cleaning them. Dust build up can cause overheating. Also check the fan for hairs or carpet fibers that have gotten wound in it, I've had fans stop working due to this. Then put it back together and check to see if the fan is coming on and running in regular intervals. If it's not it will need replaced. If it is, then there may be a malfunction with the processor or a short on the motherboard.
Jul 07, 2008 | Toshiba Satellite A105 Notebook
Laptop shutting off
There might be a setting in the BIOS that shuts down the computer when the processor gets too hot. so, getting better cooling or turning off the setting will stop it. but, if you disable the setting, the Processor could overheat and explode.
Jun 11, 2008 | Gateway 7320GZ Notebook
Toshiba Satellite A105 Notebook Logo
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
