Electroview ev42 TV won't play paltstation3 with HDMI no sound
How do I make my TV play in Telefunken 5.1 Home Theatre THT-6000HDMIA speakers?
Does the TV and system have either a coaxil or optical sockets? If it does then I would connect them by one of these. That should trigger the sound. However it might work via the HDMI if you have selected the system to pass digital signals via that connection.
Oct 23, 2015 | home Audio Players & Recorders
How can I get a control code for a electroview tv model number VC42P?
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Pull up older posts.
http://electrohelponline.blogspot.com/
http://remotesearch.blogspot.com/
Aug 11, 2014 | Televison & Video
How do i get a movie to play from computer to the tv with hdmi
If your TV has an HDMI input - connect up the computer to the TV with an HDMI cable.
Select HDMI on the TV inputs.
Play the DVD on the computer, should appear on TV is Input is set. Sound may be a fiddle ~ check you PC sound settings if there is none.
The computer will usually show a blank screen when the HDMI is going elsewhere,
Good luck
Apr 20, 2014 | Vizio E421vl 42 Inch Class Lcd Hdtv
LG blue ray won't play sound from RCA sound bar. HDMI cable is hooked into HDMi slot on TV
the details you provided were very vague, however from my experience when a device is connected to another device via and audio capable hdmi cable, that device renders it audio output to the device its connected to and normally turn off all other audio outputs beside optical- I would assume there is an option in the blue ray player to turn off hdmi audio, which will in turn activate other audio outputs- you may also look for audio out port on your tv, it is ideal to connect the sound bar directly to the tv set audio out ports. To sum this up,
if you plan to use your player via hdmi cable you need to turn off hdmi audio output on the blue ray player and the plug an audio cable from your blue-ray player to your sound bar
you may also as i said connect your sound bar directly to your tv, the issue is most tv sets now a days do not have an audio out port, if you do then everything you play thru your tv will have audio via sound bar
there are several way to go here but unless your sound bar has hdmi av switching capabilities (im sure not) this is one of the most simple--Good Luck.
Jan 29, 2013 | Audio Players & Recorders
My Westinghouse 32 does not play sounds for my video games for my PS3
Your signal board is bad and will need replacement. If you open up your tv and look at the signal board you can get a part number so that you can order one.
You can get get parts for this tv at www.interliquidparts.com
Nov 18, 2011 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Sound won't play through Onkyo TX-SR605 when using HDMI
The chances are that you have selected an incorrect sound setting or not switched it on, for the HDMI you are using. With Onkyo receivers each connection will have it own settings for video and sound. You just need to look in the manual as to how to select the settings.
May 08, 2017 | Onkyo TX-SR605 Receiver
What cables do i need to connect my ps3 to my sony recevier.
do you wan the suround sound to play sound for what the tv is displaying or just the ps3
for just ps3
connect hdmi to ps3 and tv
connect optical to ps3 and suround sound
change video settings to hdmi
change sound settings to optical
it asks to set settings automatically you have tyo doo it manually
if you want to play every thing that tv displays then
connect ps3 to tv with hdmi
connect suround sound with hdmi to tv
(this might not work)
if it dont work then
and your tv should have sound out or something along those lines it should be two phono plugs in the back of the tv connect that to the suround sound
Dec 31, 2009 | Sony HT-DDWG700 Theater System
LG 37LG30 HDMI no sound problem
This is more probably a software fault within the TV. They need instructions for HDMI inputs & a no sound is a related fault. I would get in touch with your dealer to arrange the TV to be updated to cure this problem. Hope this helps.
Apr 11, 2009 | LG 37LG30 37 in. LCD HDTV
Televison & Video Logo
50 people viewed this question
Top Televison & Video Experts
Electro Med Services...
