Question about Kenmore 24642 Top Load Washer
My washing machine is making a small buzzing noise and is cutting off and i have to restart a few times to get it going
SOURCE: washer fills, but won't start wash cycle....makes buzzing sound
Try replacing the timer switch..I had the same problem on my Simpson 175..
Posted on Dec 26, 2007
  • 1028 Answers
SOURCE: Kenmore washing Machine 4450290
lid switch
Posted on Jul 15, 2008
danromarris
  • 101 Answers
SOURCE: stopped during wash cycle and started making a loud noise
Sounds like your motor coupling is broken. It's not a big thing so don't worry to much. It only costs about 10 dollars and is easy to repair. The motor coupling sits between the motor and the transmission and is what spins the transmission when the motor spins it. It breaks from age or from over loading the machine to many times. To fix, just unplug the washer and tip it back so you can work under it comfortably. Remove the wire harness connected to the motor. Next, there are two clamps holding the motor up. Remove the screws and pop off the clamps with a flat head. Be careful because once you get one clamp off the motor will fall so hold it and don't smash your fingers. The motor coupling will come out with it. Put your new one on, it only goes on one way. Put the motor back and hook it all back up and you will be good to go again. You should be able to get a motor coupling easy as they are pretty common. Just check with your local appliance repair shop. Let me know if you have any other questions and let me know if this was helpful to you. Good luck and I am glad I could help you out.
Posted on Jan 22, 2009
SOURCE: Kenmore 70 series washing machine
SearsTechTwo had very helpful information, thank you! I did have a broken coupler on my Kenmore 70 Series washing machine and fixed the problem for a total of $18.30. The center hole of the white plastic coupler part that is seated on the motor shaft side had cracked. Fortunately, the replacement part now includes a metal sleeve for that center hole to help prevent cracks in the plastic. Because this was my first appliance repair, I found it easiest to remove the machine to my garage workshop with a hand cart and then lay the hand cart on its side to access the bottom of the machine without working upside down or removing the outer case of the appliance. Removing the water pump clips was easy with a flat screwdriver for leverage. I did not need to disconnect any hoses to slide the pump off the motor shaft and out of the way. It can be supported away from your work area with a large twist tie or string. Removing the motor clips was not hard with a 1/4” socket and a screwdriver. Rather than remove the wire bundles, I used a rag to cushion the wire bundles from chafing on the edges of the frame as I slid the motor out of the way allowing it to gently rest naturally below the work area. Removing the old coupler was easy. The tolerance was not tight at all on the center hole of the white plastic pieces due to years of wear. My mistake was installing the new coupler halves on the transmission shaft and the motor shaft without properly seating them as SearsTechTwo had described. The new part with the metal sleeve in the center hole fits snugly and needs a few taps with a small hammer to be fully seated on the shaft. Approximately 1/4” of movement is needed for the coupler to be properly seated beyond where it would lie with finger pressure alone. Once the coupler is properly seated and the motor and pump are reassembled, the coupler should spin freely when using your finger to turn the black rubber disk that joins the two plastic halves as they turn the motor and transmission. On my first try, I did not properly seat the coupler on the shafts and the coupler did not spin freely. The result was a burning smell because the motor was working too hard to turn the coupler. I repeated my work and seated the coupler halves on each shaft with a hammer. The machine now works well. Here is an alternate source for the Part # 285753A: www.appliancepartspros.com/part_details.aspx?part_id=3963893&pn_=285753A. I noticed that AppliancePartsPros ships directly from UPS’ world headquarters in Louisville. I live there and had the part before lunchtime the very next day. Most places in the USA can be reached from Louisville by UPS ground in 2 days. According to their website, that same part # fits all Whirlpool, Kenmore, Roper and KitchenAid direct drive washers (no belt). Good luck!
Posted on Mar 22, 2009
  • 351 Answers
SOURCE: 29522800 Kenmore Won't wash.
ouch def get a new one or get warranty to come out could be bad news
Posted on Jun 26, 2009
During wash and rinse cycles, washer stops loud buzzing noise, turn it off , wait a few minutes and will restart after a few more minutes will do the same thing again ??????
does it allow much water into the tub? u may beed to check ur water inlet valve for OHMS and for proper voltage at the coils, they may have went bad
Jun 02, 2015 | Admiral ATW4475XQ
Washer is making different noises during wash and rinse cycle
could have been the motor,you might also smell like a shellac kind of smell,when the motor overheats,also how old is it and what's the brand name and model number.you can feel the motor,if it's hot then it is cutting out for some reason.
Dec 20, 2017 | Washing Machines
Machine filled with water then just began beeping. Never started to wash the clothes. When turned off and then on again, it makes a buzzing noise and nothing happens.
If your buzzing noise stops after a few seconds, it could be the motor failing to start. If it sounds like a signal buzzer, it could be indicating the lid open, or a failed lid switch.
May 18, 2011 | Maytag Bravos MTW6600T Top Load Washer
My GLTF 2940 makes a buzzing sound like a relay not pulling in all the way, during the rinse cycle. If you shut off the washer, and restart it on the rinse only cycle, it goes away.
its probably your cold water rinse only valves solenoid thats loose on the structure or the coil itself is loose,you may not hear it all the time especially during the initial wash start fill,try this, set the washer for cold water fill only on the washer,but turn off the water valves that supply water and start your machine to a wash cycle as normal,try this and see if it dry buzzes(without water),then try the same on the hot side,then with the water still off open up the machine and you can localize the buzzing noise
Mar 12, 2010 | Frigidaire GLTF2940ES Front Load Washer
Makes a weird buzzing sound while in the wash cycle, sounds like a problem with a relay perhaps
The timer sometimes will buzz like that, nothing to worry about usually, if the timer ever stops, and you can restart it by pulling out the knob and moving it a bit further in the cycle and restarting it, then your timer is going out.
But it may also be a bobby pin or something like it in the pump ,My atlantis has had this several times ( daughter never checks her pockets ) most times it travels on through in time, but a few times i needed to remove the front of the machine and pull the hoses off the pump and get the bugger out.
Nov 05, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Me Estate washing machine, when started fills to specified water level then, it makes a buzzing noise then the buzz quits and nothing happens. Machine won't agitate or drain, just buzz then buzz quits.
sounds like you have a problem with your water supply to washer. the buzzing noise sounds like it's the valve opening to receive water but nothing going in. check supply hoses and water taps
Jul 14, 2009 | Washing Machines
Waher will not go into spin cycle. It makes a buzzing noise and will not spin.
it's most likely your timer....u can get the machine to spin out your clothes by pushing the timer in and pulling it back out. this resets the motor and makes it turn backwards. it's a pain to do this because you have to keep an eye on the time. this will get you through until you change the timer.
May 28, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing machine makes buzzing noise
Check the water pump for an obstruction in the chamber area, your pump may be sticking and that will cause the buzzing sound. The water pump runs during the fill portion of the cycle on several of the selected wash cycles to recirculate the water.
Nov 06, 2008 | Fisher Paykel EcoSmart GWL15
Washing machine problem
Sure you need to lubricate. But change the belt, you get all sizes easily. The wiirring noise is usually when the belt is off, worn out likely.
Pl rate, thanks
Dec 27, 2007 | Hoover PE235 Front Load Washer
Kenmore 24642 Top Load Washer Logo
23 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
