Question about Apple iPod touch
I turned my ipod touch on for the first time today, brand new, and the screen is stuck on a connect to itunes screen, how do i set it up
    Scholar:
  • 104 Answers
Dear,
Try and reoot your iPod as following:
  1. Press the power (on top) and home/springboard button (center, bottom) together untill the Apple logo pops up. When it pops up, just release, and wait for a few minutes/seconds.
  2. Problem wasn't solved with n° 1? Well there is a second way, but i got to warn you it causes your iPod to delete all music, photos etc. Just plug your iPod in to iTunes and click on your iPod on the left and, press repair.
Kind regards
Posted on Jan 03, 2011
Itouch disabled
When your iPod Touch displays a message telling you to connect it to iTunes, it may be in recovery mode, or have been disconnected in the middle of an update.
To get rid of the screen, you must reset your device. If in passcode mode, an iPod Touch must be manually unlocked or fully restored to get back to the home screen.Forcing a Reboot
When your iPod Touch is stuck on a screen that is instructing you to connect with iTunes, a normal restart will probably not work, as the hard drive has become frozen.
You can still, however force the iPod to reboot using a process called resetting.
To reset an iPod Touch, hold down the "Sleep/Wake" and "Home" buttons at the same time until an Apple logo appears, indicating that the device is rebooting.
When an iPod Touch reboots, it always goes back to the lock screen. Passcode mode will still be enabled.
Unlocking With the Passcode
If you know the passcode for your iPod Touch, slide the "Slide to Unlock" arrow and then enter your code on the next screen.
Upon entering your password, you will be directed to the device's home screen. If you enter the wrong password too many times, it will become disabled temporarily.
The iPod Touch can also be set to erase all content after 10 incorrect passcode attempts if you previously enabled this feature, don't attempt more than 9 entries.
Unlocking Without Passcode If you have forgotten the passcode to your iPod Touch, the only way to unlock the device is by restoring it.
Restoring an iPod Touch returns it to the factory settings, meaning that any settings, applications or music you added to the iPod are removed.
Once the device is restored, you can re-add your downloads and other information using the backup copies in your computer iTunes program.
The passcode setting will be disabled unless you manually enable it again.
Consideration
If you don't have a backup of your music and applications in iTunes on your computer, you can also download another copy from the iTunes Store or App Store on your device after a restore.
Any photos that are deleted during restore, however, will be lost forever if a backup does not exist.
Always back up your information via sync on a regular basis to avoid this problem.
Nov 05, 2013 | Audio Players & Recorders
My ipod is disabled and says connect to itunes but it also says itunes could not... so what do i do?
Step 1:
Apple's iPod Touch comes with a screen lock feature that allows you to set a four-digit security code to prevent others from using your iPod. Every time the iPod locks, you must enter this code to unlock the screen and access the user interface. Entering the wrong code too many times, or simply forgetting your security code, can cause you to be completely locked out. When this happens, you can quickly unlock your iPod Touch.
Connect your iPod Touch to the computer you usually sync it with. When you disconnect your iPod, it should now be unlocked. If Step 1 does not work, you have to restore your iPod Touch. Be advised that restoring your iPod Touch returns it to the original factory settings. This means that all your songs and files will be deleted and lost. You can resync your files to your iPod from iTunes once you have finished restoration. Connect your iPod to your computer and open iTunes. Make sure you have the latest version of iTunes before proceeding. In the left navigation panel in iTunes, select your iPod under the "Devices" section. Click the "Summary" tab and select "Restore." When iTunes prompts you about backing up your data, click "Back Up." In the following window, click "Restore." After the restore process completes, you will see the Apple logo on the screen of your iPod. Leave your iPod connected to your computer until it shows up again on the iTunes navigation panel. Your iPod touch is now unlocked. In iTunes you will be able to setup your iPod. Select the backup you made in the drop-down menu to restore your data files. Click "Continue" to finish the restoration. iTunes: Restoring iOS software
http://support.apple.com/kb/HT1414
Mar 01, 2013 | Apple iPod touch Original
My ipod touch [4th generation] screen is stuck on the usb cord pointing toward the itunes logo
The solution is: 1. Turn of your iPod. 2. While holding down the 'Home' button, connect to iTunes WARNING: Doing this will return your iPod back to original 'out of the box' settings and you will lose everything. On the bright side, you get a 'fresh' start and it will auto update to the most recent software version.
ipod touch 4 gen
Aug 19, 2012 | Apple iPod touch 4th Generation MP3 Player
IPod touch error message (2003) My iPod touch is stuck on the recovery mode screen and every time i connect, iTunes tells me it has detected my iPod in said mode and needs to restore but after about 10 -...
your going to have to wipe out your ipod and start it over as if it was new by doing a complete master reset on it you tube will be of greater help if you research it and also if you had it jailbroken your really just fucked
Aug 12, 2010 | Apple iPod touch
I have bought a brand new ipod touch, installed itunes and my ipod will not load. Just has a picture of the usb line and the itunes signal. Tried reistalling and restarting computer. Help!
This picture means you need to sync the new ipod with your computer.  Meaning they got to get close and acquainted.
Restart your computer.  Open up itunes and wait for it to load.  Then take the USB sync cord and connect one end to the ipod and the other end to the USB port on your computer.  Click set up new ipod and type in a name you want to use.  Follow the on screen instructions and don't disconnect the ipod until your computer says its done and its safe to disconnect.
Oct 25, 2009 | Apple iPod touch
ITouch stuck on screen with pic of USB pointing to ITunes logo
is it brand new??
if so then connect it to itunes
Jul 07, 2009 | Apple iPod touch
My ipod touch is not being recognised as a device on screen and is locked just showing me the connect to itunes on the screen what do I do it was working perfectly well today and I have downloaded the...
your ipod may have just crashed for an unknown reason, but the only solution to this problem is to follow what the ipod says on the screen in order to gain access to your ipod again.
Note: you will loose anything, itunes will erase all contents from the ipod.
Open Itunes and connect the ipod touch to your computer, itunes will atomically recognize the ipod like it always does and will download system software from apple and restore your ipod. this process will take a little bit longer but wait till it finishes.
after restoring your ipod, you can configure your ipd like you did the first time.
Jun 30, 2009 | Apple iPod touch
Ipod touch stuck in itunes recovery mode. message, error 14.
JUST SHUT IT OFF AND THEN CONNECT YOUR USB CABLE TO YOUR PC AND IPOD, THEN HOLD THE HOME AND POWER BUTTON UNTIL YOUR SEE I TUNES ICON WITH THE USB CONNECTOR RIGHT UNDER IT, WHEN YOU SEE IT LET GO THEN IT'LL SYNC INTO ITUNES AND JUST FOLLOW THE INSTRUCTIONS.
RATE ME PLZ.
May 02, 2009 | Apple iPod touch
I tried doengradin it and i guess i messed up and now every time i switch on my ipod it says connect to i tunes i guess its stuck in recovery mode i tried restorin it but it says it cant(please read f
Try this: turn off your ipod, hold the home button, and plug it into itunes while still holding the home button until the itunes symbol appears with a cable under it. itunes should say "ipod found in restore mode". Restore your ipod to either a backup of that ipod if there is one, or set up a new ipod. (setting up a new ipod will fix any previous problem) (hopefully)
Aug 16, 2008 | Apple iPod touch
Apple iPod touch Logo
18 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
