Question about Toshiba 37HLX95 37 in. LCD TV/DVD Combo
Toshiba 37HLX95 no audio only on over-the-air antenna input #2, all channels. Just started today. All other inputs are okay, including cable on antenna #1 and ReplyTV on another input. I've checked all settings.
    Guru:
  • 2,178 Answers
Swap input 1 and 2 and see if you get same result - could be a bad tuner in the set (#2).
Posted on Dec 30, 2010
  • 3 more comments
  • Anonymous Dec 30, 2010
    Both antennas work fine on cable. Both antennas show OTA video. Neither antenna input has OTA audio. OTA signal strength, of course, is fine. (The problem occurred because my 5-yr protection plan expired last week. :-) Is there a reset button?
    Update: both antennas work fin on analog cable. The digital channels (our local stations) sent by cable have the same problem (video only, no audio).
  • Rommel Alilin
    Rommel Alilin Dec 30, 2010
    Are you using an OTA digital receiver box or the TV has a built-in digital tuner?
    I'm using the built-in tuner. No cable card or external turner.
  • Rommel Alilin
    There is a "Restore Factory Default".
    Here's the user manual link:http://www.csd.toshiba.com/cgi-bin/tais/...
When i mak the automatical programin for my tv (toshiba model no. CN27H95) it find nothing!!!! so there are others ways to mak manual programing to find chanels?
This feature is pretty reliable and the lack of channels may be due to the lack of signal to the set.
You must have either an antenna, a cable from a cable service or a satellite receiver connected for the set to find any channels.
Oct 24, 2014 | Toshiba CN27H95 27" TV
Can get only 1 channel to program on my toshiba
hi if the tv has dtv just select air digital only thanks
shaun
Mar 25, 2017 | Toshiba 40RV525U 40 in. LCD TV
I moved and cant figure out how to hook my 4030 channel master antenna up again. I have a converter box and hd toshiba tv
INSTALLATION
Channel Master by PCT indoor antennas are designed to provide optimum reception of
UHF / VHF and FM signals. These antennas have 75 ohm outputs, which allow simple,
hassle-free connections to today's newer TV sets that have 75 ohm F type connector
inputs.
Simply attach one end of the supplied 6' cable with F connectors to the output of the
antenna (Fig.1). Attach the other end of the cable to the input of the TV set or VCR
(Fig. 2). Some adjustment of the antenna might be necessary for optimum viewing.
Model CM-4030 includes a built-in amplifier and separate power supply.
1. Follow the same steps as above for antenna to TV / VCR hookup. Note : Model
CM-4030 also allows for two set / VCR hookups with its unique dual output feature.
2. Insert the power injector into the back of the antenna (Fig. 3). Plug in the power
transformer to the closest electrical outlet (Fig. 4).
Google 4030 Channel Master Instruction Sheet for the PDF File with the diagram.
Fig 2a
Fig 3 Fig 4
prohibido por ley.
TV
Fig 1 VCR
Fig 2
Fig 2a
Fig 3 Fig 4
Jan 10, 2014 | Channel Master 4030 Amplified indoor HDTV...
Why can't I use a digital antenna on my flat
Most televisions today have a setup mode for the tuner where it searches for channels based upon the input type. Older sets required the user to input whether or not the source was over-the-air broadcast, analog cable, or digital cable. If you were using your set with the cable or satellite system previously. you will most likely need to run the setup again with the digital antenna and let the set find the channels available via the antenna.
Jan 30, 2012 | Televison & Video
I just acquired a Toshiba 32HL95 TV and cannot get any hd channels although I have a digital cable box. I have tried using the coaxial, hdmi and video connections to no avail.
Try configuring your antenna input. Menu, Installation, Terrestrial, Input Config select your antenna 1 or 2 and > arrow over to select cable. Next auto program: under Terrestrial, Channel Program...this take some time.
Oct 23, 2011 | Toshiba 32HL95 32 in. LCD TV/HD Combo
I cannot get a picture on any channel. Not hooked to cable. No antenna. What is the problem?
Most of the TV sets have " Picture Mute" feature which means; if no signal exists on either Antenna plug or on Video input (RCA jack) no picture at all.Blank screen..no audio as well..all MUTED..
to test it ,play a DVD ,you must have pictures and audio together..
Use an antenna ( even a piece of plain cable will work ) ,and run "search" ,you must receive some TV channels thru AIR.
Take care and please Remember to rate/vote for us to
continue f
or Helping out the Community :)
Jul 09, 2011 | Toshiba MD13N3 13 in. TV/DVD Combo
I need instructions for hooking my VCR to my TV set,
using a scart cable, connect the tv socket on the vcr to the scart - in socket on the tv.
good luck.
May 10, 2011 | Philips Televison & Video
In just bought new Toshiba regza 40" Lcd tv and auto tuned it, but the picture is terible , snowy and colours are not good, what to do...
Hello
First of all reset the TV. for that
press and hold the POWER button
on the TV control panel for 5 or more seconds to reset the TV.
Then connect the TV tt any source like outdoor areiel or cable box etc, select the appropriate input, and retune the TV. First of all, connect it to an external antenna, and set it to autotune.
You must configure the ANT/CABLE input source before
programming channels (-left-hand column).
If the ANT/CABLE input signal type is set to Cable, the
automatic channel programming process erases channels
that were previously programmed into the TV's memory.
If the ANT/CABLE input signal type is set to Antenna, the
automatic channel programming process adds newly found
channels to the existing set of programmed channels (and
does NOT erase channels that were previously
programmed into the TV's memory.) To remove an Antenna
source channel from the memory, you must manually delete
it.
To tune the TV to a channel not programmed in the channel
memory, you must use the Channel Number buttons on the
remote control.
Programming channels when the ANT/CABLE input is
configured for Cable will take substantially longer than when
the antenna input is configured for Antenna. This is normal;
however, once channel programming is finished, you should
not have to repeat the programming process again unless
your Cable TV service lineup changes significantly.
Find out the received channels are clear or not. If they are clear, your TV is perfect, and the input device you connects ot the TV is faulty. OK.
Feb 16, 2011 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
My tv just stopped getting antenna reception today.
It is not possible clear picture use indoor antenna it is use cable tv then get a lot of channel enjoy
Sep 24, 2009 | Philips SAA7130 TV Tuner/FM Radio/Video...
Toshiba Model: SD-V295 DVD/VCR Combo Setup for TV recording
The proper hookup is antenna or cable into the VCR RF/antenna input, then VCR RF/antenna output to the TV RF input. The hookup you describe means no signal is getting to the VCR.
With some TVs, there can be Video and audio output jacks which can be hooked to the video and audio jacks of the VCR. However this would likely mean you could only record the channel being watched, and, the TV would have to be on.
Jun 07, 2008 | Toshiba Televison & Video
Toshiba 37HLX95 37 in. LCD TV/DVD Combo Logo
110 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
