We have an old Mitsubishi tv and we can't work out how to tune it to our new video recorder, there are no obvious options on the menu and we are using a generic remote control. The video recorder is second hand and has no remote control either. Argghhh!
  • meliandben Jul 08, 2008
    Thank you so much for your help. We will give it a go if we can. If not then it may be time to purchase a new TV which will be a first - we normally have hand me downs!
  • 70 Answers
You have a problem. the adjusting button is on the original remote.
If you cant get your hands onto an original remote then there is nothing you can do about it.
only thing you can do is run the vid via av leads that way you bypass the tuner.
Posted on Jul 07, 2008
I Have recently Purchased a new LG 22" HDTV and want to connect to an older style video recorder. should i connect the old RF way and if so what input do I select on LG remote.what channel should I...
Your old video recorder should have the cable with the red, white and yellow connection. Plug them into the red, white and yellow boxes in the back of the TV. Usually there is a small white box painted around those three boxes and it says "Video 1" or "Video 2" on it, depending on how many video connections you have. If you turn on your TV you need to push "input" on your remote control and select the option "Video 1" or "Video 2", it needs to match with where you plugged it in the back of the TV.
May 04, 2011 | LG Televison & Video
How do I tape onto a vhs from analog tv with converter box?
There are 2 options-
Option 1
Connect the coax cables in the following order.
1 From the wall to the input of the converter box.
2. From the output of the converter box to the input of the VCR.
3. From the VCR to the TV input.
Here is how you record with this option.
1. Tune the converter box to the channel you wish to record.
2. Turn the channel on the VCR to channel 3 or program the VCR to record channel 3 this will record whatever channel you have your converter box set to at the time of the recording.
Option 2- (will not work on satellite)
1. From the wall to a 2 way splitter (made for digital cable. General rule of thumb with digital cable is gold does not usually mean good.)
2. One output from the splitter to the converter box and the other to the input of the VCR.
3. Connect an Audio Video (RCA (yellow/red/white cable)) from the VCR to the TV input.
4. Select the appropriate input on the TV for the VCR.
Here is how you record with option-
Tune the VCR to the channel you wish to record and push the record button or program the timer to record the channel and time that you wish.
Note- with this option you will only be able to record channels that you would receive without the converter box. Also each time that you split the cable line you loose part of your incoming signal and depending on how you house is set up this option could affect the quality of your digital signals on the converter box.
Jan 02, 2010 | Mitsubishi VS-55707 TV
I have just bought a digital tv and can't tune the video in
If you are talking about an older VHS or Beta recorder, the tuning for recording is done by the player itself. If you are using an outdoor antenna to recieve your local stations to record, most likely you will need a digital TV adaptor to convert the over the air digital signals to an analog signal the tape player can understand.
Nov 03, 2009 | Televison & Video
Options to auto-tune or manual re-tune are greyed
Problem solved!!
According to the Sony website I needed to get a software download in order to fix this problem. I found out how to do this from the manual and realised that the re-tune menu I was looking at was for analogue only. The pictograms onmy remote control are a blurred but the manual helpfully provided a picture showing the correct program "info" button (next to 0) which has options to look at other things, including a "detailed set up" menu on the blue tab, which provides options for software download and re-tune of digital channels.
Incidentally, I discovered that my TV model was not quite as quoted above - it is KD-28DX200U, but expect the same process works for other oldish models.
Oct 01, 2009 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Mitsubishi TV Channel Tuning/Remote Problems
To restore full functionality to your set you must replace the remote that came with set. Universals only control the most basic of functions.
Apr 27, 2017 | Televison & Video
Tuning video programs
I have solved the recent problem myself. I simply retuned the Menu option on channel * and then stored the channel into the TV
Feb 04, 2009 | RCA 32F531T 32" TV
Mitsubishi diva cant tune in
well .... no online user manuals for thoseTVs
you will need to use a digital seck top box and use that units remote to tune the TV
if there are any (needs a user manaual)
use the buttons on the TV lower casing
to tune up
none of the all in ones remote buttons work for all TVs functions
you are lucky if it turns on and off
and changes channel
Apr 29, 2017 | Mitsubishi VS-45609 TV
Problems tuning TV and SLV-900
the video recorder has it's own tuner you do not actually record from the tv... think of the vcr as like a tv but without a screen... connect to your tv via a scart lead and while you are on the vcr's 'channel' (so you could see a tape playing on your tv) and access the menu on you vcr (not the tv's menu) choos auto tune if the vcr supports it or manual tune if it has no auto tune and tune in the required channels on your vcr... it is simply then a matter of selecting on your vcr which channel you wish to record
Oct 13, 2008 | Sony SLV-D900 DVD Player / VCR Combo
Panasonic NV SJ205 changing RF settings
Your VCR has input to record video-audio signal. Here is 2 options to record program in vcr.
1= You need to hook up video-audio cable at Monitor Out in TV and video-audio in at VCR. select Line-1 or Line-2 (where you hook up cable) in vcr and insert cassette with Record Tab intact, VCR is ready to record TV program. select desired channel on tv and hit record button of vcr, recording will start.
2= Plug RF antenna / cable wire in RF In of vcr and tune desired channel in vcr (get help of vcr's user manual for that) and push record button to start record directly in vcr.
Have further query, let me know please.
bye.
Sep 09, 2008 | Panasonic NV-SJ205 VHS VCR
Televison & Video Logo
41 people viewed this question
Top Televison & Video Experts
