Question about Pioneer Audio Players & Recorders
I have a Pioneer vsx-919 receiver an an LG TV. The problem is: Using an HMI cable I have hooked my cable box to an in port of the receiver, then put a an HMI cable from the out port of the receiver to an in port on theTV. I select the proper input port on my TV and the right out put on the receiver. The TV screen says No Signal. If I attach the DVD to this set up I get a picture but onlty one track of sound. It comes out of both speakers.
    Brigadier General:
  • 8,546 Answers
Assuming a single cause we need to isolate which single device is involved in all these failure modes.
"It comes out of both speakers" on what - the TV?
You don't say how the DVD interefaces with the receiver. Is the DVD feeding digital multichannel audio out at that time? Many DVD's are simple stereo until the show actually begins. You know that.
Try running an HDMI connection straight to the TV from the cable box. Result?
Substitute the other HDMI cable for the first one. Result?
If either one does NOT work satisfactorily we may have part of the problem isolated.
If they both work, the TV and cables are ok.
Attach the HDMI out of the receiver and IN to the TV and the HDMI from the Cable Box as before. Same result?
Can you try using Component Video out of the receiver to the TV just to change something in the equation? On my rig I 'see' no difference between HDMI and Component Video on my HDTV. A change in the result may help to isolate or work around part of your problem.
My $.02...
I'd recommend you go for minimal receiver involvement in the video side other than to send composite video to the TV from "Monitor Out" so you can set up and manage the receiver.
You can also send Cable- or Sat Box basic analog audio directly to the TV if it has inputs for audio. That way if you just want to watch the news or weather you don't need to fire up the Pioneer.
Your video sources (DVD, BD, Cable/Sat) will suffer fewer video anomalies if you send their best video directly to the TV and their best audio directly to the receiver. That way everything is handled only once by the best electronics you have for each function.
Posted on Dec 30, 2010
Hi I just bought a pioneer vsx-42 cable box and was wondering how to hook my Xbox 360 up through there so I can play on the tv, I have an hdmi cord And will be playing on a Samsung smart tv
Hook your X Box into the Receiver HDMI input with your HDMI cable and another HDMI cable from the HDMI out on the receiver to the HDMI input on your TV.
Aug 02, 2012 | Audio Players & Recorders
I have a Pioneer VSX-D308 reciever and I have... no idea how to hook it up to my big TV (bought receiver used). Do I need the red/white cords? Do I need other cables? HELP! Wanting to hook up to big...
What your unidentified TV >>requires<< is the BEST Video from every video source. That would be the DVD, SAT Box. It probably has multiple high-end video inputs, right?
What your receiver needs is at least a basic composite video connection to the TV so you can set it up and manage it.
A web search for "Pioneer VSX-D308 manual" will find the manual.
ALL of the BEST Audio should go directly to the Pioneer. That includes the SAT and DVD player.
Your TV can exist just fine with basic audio from the video sources. And you could still watch it/them without the Pioneer turned of if you want.
I can't find the exact manual for free anywhere but if you download something similar like http://www.retrevo.com/support/Pioneer-VSX-D409-Receivers-manual/id/385ci977/t/2/ it should give you the basic guidance you need.
I recommend
Do some web searching for what the cables are for. It's all basic and standard.
Sep 07, 2011 | Pioneer VSX-D308 Receiver
I have a pioneer vsx-30 with hdcp error on the face i see it when a scientific atlantic cable box is connected through a componet connection
Component cables don't have the ability to carry decrypted HD info.
HDCP is "High Definition Copy Protection"...In theory, it prevents you from running the HDMI cable out of your receiver, and into a recording device, thereby recording HD content without a license for it.
HDCP handshaking is done between devices that run HDMI, or DVI.
If you're running component from your Cable box, and then HDMI out to your TV, then the content you're carrying from the Cable box may not be getting decrypted properly when it gets upscaled onto the HDMI port from Component.
IT could also simply be that you're using an HDMI 1.1 or HDMI 1.2 cable, which may not be able to carry the high bandwidth stream of your Receiver and TV.
Please be sure that all HDMI devices can support the same HDMI version, and also be sure your HDMI cable is labled "HDMI 1.x compliant". . .e.g. if your TV and Amp support HDMI 1.2, make sure you're also using an HDMI 1.2 Cable.
Apr 21, 2011 | Pioneer VSX-305 Receiver
How to hook up direct tv box,samsung hd tv,pioneer vsx-820 receiver,samsung blue ray bd-c5500
If you're using HDMI cables, which I suggest you do, this is how you set it up.
From the TV, you'll connect an HDMI cable to your receiver.
Connect the blu-ray player to your receiver.
There's a small amount of setup required with the receiver, but it's self explanatory.
Mar 12, 2011 | Pioneer Televison & Video
I am trying to hook up my Pioneer vsx-455 to a LG LED LCD TV. I am not sure on how to do this and I can not find a manual anywhere. Can you help me?
your reciever does not have hdmi, so the audio is not going to be true DD+ or DTS for broadcast tv.
if your dvd/blue ray player has digital optical spdif, this can be used to transfer the encoded DD+/DTS digital audio.
the besat way to run your tv audio through the reciever is to hook up the dvd/blue ray player up with (perferrably) digital optical spdif, composite spdif or (least favorably) through the stereo stereo analog inputs on the reciever for "dvd" audio in and hook the video from the dvd/blue ray up to the corresponding "dvd" video component input on the reciever.
this way is only going to get your dvd/blue ray sound, next you need to hook up your cable box to the reciever so that you can get broadcast tv sound. hook up the cable box audio to the "tv" stereo analog audio ins, and hook the video to the corresponding "tv" video component inputs.
the component video inputs have separate jacks for red, green and blue ( labeled "Y" "Pb" and "Pr") and are capable of carrying a 1080p full hd signal. use the component video outputs on the reciever to output the video signal to a component video input on the tv, using the receiver's input selector to change the video source.
Nov 25, 2010 | Pioneer VSX-455 Receiver
Pioneer works with cable box but not with new blue
HDMI version is 1.3 in your receiver.The current version is 1.3b. I would suggest calling Pioneer cust assistance and see if there is a firmware update. Your unit has a 2 year parts & labor warranty. Their # is 1-800-421-1404 It sounds like a CODEC issue. Hope this helps
Dec 25, 2009 | Pioneer VSX-92TXH Receiver
Pioneer VSX-72TXV used to work but trying HDMI just broke it...
I fixed it myself. Didn't realize that I loosened speaker cables on the wall panel when I moved the receiver and two were touching...
Dec 10, 2009 | Pioneer VSX-72TXV Receiver
Pioneer vsx-519 no sound from center and surround
Make sure that the sound field/programme you have selected is dolby digital not stereo.(On the amp)
You also need to check on the display that is says DIGITAL not ANOLOUGE, as only a digital input, Optical fibre cable, HDMI, COAX will be a digital signal.
If you are using red and white rca connectors, it is not going to work, as this is an Anolouge signal.
Sep 08, 2009 | Pioneer VSX-818V-K Receiver
181 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
