Question about Cars & Co Walbro Wt603 Carburetor Pocket Bike Scooter Baja 5b
LOOKING FOR A WALBRO WT-212 CARB. DO YOU KNOW WHO HAS ONE.
Carburetor diagrams
I know of no diagram available for this. But if you have both lines out and visible you can just put them on the carb, fill the tank and prime it and see if fuel moves. If it does your done....if not....flip the lines and try again!
Jul 16, 2014 | Poulan Mvm200vs, Ppb430vs Vs2000bv Blower...
Walbro wt-141 changeover to wt-629
If the carb has two connections then it is designed to work with a primer bulb, the fuel inlet will be nearest to the pump cover, the alluminium cover held with a single central screw, you can either get the correct carb for the machine or use a short rubber tube with a blank in the end ti close it off.
Feb 02, 2013 | Poulan Weedeater Carburetor - Walbro...
Fuel line placement on the walbro wt 673 carb
This is superb, the one I'm trying to fix has been piped up wrong, the primer bul is pushing the fuel through the carb.
It will start and idle, but when ypu open the throttle it dies, from lack of fuel.
May 21, 2012 | Homelite Garden
Need A parts diagram for a Sthil G65 Blower carb.
Unfortunately, Stihl won't release any of their illustrated parts diagrams to anyone except Stihl dealers. The dealers won't release them either. It is possible that the manufacturer of the carb will have a breakdown listed on their site. Stihl primarily uses either zama carbs (www.zamacarb.com) or Walbro carbs (www.walbro.com). Look on the carb for engraved numbers and letters to let you know what series and model to search on. The manufacturer is usually listed either on the bottom diaphragm plate or up on top. Walbro series usually start with a WT, or WA. Zama will usually have a C series (ex. C1U)
Nov 02, 2010 | Garden
Which fuel line "port/inlet" on the Walbro wt-380 goes to the fuel tank? It's on a Craftsman 25cc Gas "Weed Wacker" Line Trimmer purchased in 2002. It has Walbro WT-380 carburetor with external primer...
Usually the line with the filter on it that comes from the tank goes to carb. inlet first which is most likely close to the bottom side of the carb.nearest to the engine,then the outlet or return line on the carb.goes to the inlet side of the primer and the outlet side of the primer goes back to the tank. The primer draws fuel through the carb to the primer to the tank if its not? then correct the line connections until it does
Jun 25, 2010 | Craftsman 25cc Gas Line Trimmer
Parts number
You need to know if it is a walbro or a zama carb. to start with.
then look closely at the carb. and find #`s
very small
walbro will be wt or wa then some #`s
zama will be c1q or c1u and some #`s on the opposite side of carb.
Walbro will be on the same side
you need to know the carb. #`s so a kit can be found for that particular carb. IE: complete kit or diaphram kit
May 20, 2009 | Homelite Consumer Products MightyLite...
Walbro wt hose routing on poulan saw
Carb has 2 nipples. top nipple gets line with filter on it from tank, bottom nipple receives line from bulb other side of bulb returns to tank
Jan 22, 2009 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Cars & Co Walbro Wt603 Carburetor Pocket Bike Scooter Baja 5b Logo
79 people viewed this question
Top Cars & Co Toys Experts
Adam Fjeld
Adam Fjeld
Tom Chichester
Are you a Cars & Co Toy Expert? Answer questions, earn points and help others
