Question about Whirlpool RF365 Electric Kitchen Range
I need the control switch part number for model # RF365PXMW Whirpool elecrtic range. Thank you, Bridget
Rf365pxmw control panel blank
Do you have the black, white, or biscuit colored control panel?
Feb 22, 2013 | Whirlpool RF365 Electric Kitchen Range
Want to download a user's guide/manual for an old wall mount double oven from the 70's. I believe it is a P7!
If im not mistaken the P7 was a General Elecrtic oven?
the FULL exact model number is needed to downlaod a manual and chanches a manual for a30- 40 year oven will not be on the net. If its GE find the full entire model number and go here to try to download that manual http://www.geappliances.com/service_and_support/literature/
Aug 13, 2011 | Kitchen Ranges
We got a kenmore range with a timer and I can't stop it from beeping F1.... its used no papers or anything,,,
Depending on model number since GE, Whirpool, Frigidaire and Maytag, LG, Samsung and so on makes the Kenmore brand appliances you either have a bad EOC, (clock), or oven sensor. Guess work is all it is with out the model number. Model number should be on range somewhere and will start with numbers .numbers.
Mar 12, 2010 | Kitchen Ranges
I need a instruction book for my 2004 freestanding range, with flat top, whirpool
You don't give a model number so I can't help more, but here is the literature search page at Whirlpool. Enter your model number in the search box and if the manual's available you can click the link to download it.
Good luck in your search! Thanks for using Fixya.
Feb 28, 2010 | Kitchen Ranges
Im having problems with my electric Gaffers Sattler stove. One of the burners is alwas on high when you turn it on. I cant find a serial number. Thank you for your time.
The switch that controls that burner is defective.
Pull out the lower pan drawer and look for a model number on the range cabinet.
If you can not find a model number,unplug the range,remove the switch and get a part number from the switch.
Jan 06, 2010 | Cooktops
Hi, I am getting an error reading on my whirpool gold stove it reads EO -F2- do you have any clues to what my be my problem. Thank you in advance for your suggestion
F2 - E0 Shorted keypad (also called touch pad) 1. Check keypad connector for firm connection (keypad connects to control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock).
Sep 20, 2009 | Whirlpool GR773LXSS - Stainless Steel...
Microwave Whirpool burned - model #mh6150xhb-0
It may be the fuse, which is usually located behind the grille or on the floor of the oven behind the control panel or between the door switches.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker (or GFI) when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
If you don't find your tech sheet, you can download it here.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Dec 04, 2008 | Microwave Ovens
Whirlpool electric range burner power light stays on but no heat
Hello givemeanidth.
Welcome to Fixya
You said, have a Whirlpool electric range (model rf363pxpt0) with standalone burners - the burner power indicator light stays lit whether the heat control knob is on or off, there is no heat coming from the burner on or off. You pulled the burner from the receptacle and one of the tabs broke off and stayed in the receptacle. You removed the tab and made sure no pieces remained in the receptacle then bought a replacement burner, no change. You put the replacement burner in the back burner of the same size and had heat within 10 seconds. You changed out the burner with the one that had been in the back of the range, no heat. As long as the breaker to the range is on the power light stays lit but no power to that one burner only.
What is the model number and the age of your range?
Waiting for your reply.
Huuum
Sep 02, 2008 | Whirlpool GR465LXLS Electric Kitchen Range
Kitchen range
Kathy, call Whirlpools 800 number and tell them to send you parts, 9756384, Use and care guide, 3191638, cooking guide and my favorite, 4454079 tech sheet. They should send them out at no charge since you did not receive them with your oven...Catriver..post back.
Sep 16, 2006 | Whirlpool RF365 Electric Kitchen Range
Whirlpool RF365 Electric Kitchen Range Logo
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
