Can not figure out wep key using the wii or the iPod
    Problem Solver:
  • 21 Answers
You should press and hold the reset button on the router so that you can log in with the default security setting, which is no security. It will vary on each brand of router, but you can access the admin dashboard and set up a new WEP key.
Posted on Dec 30, 2010
What is error code 51331?
Normal.dotm 0 0 1 253 1446 Statens bygningstekniske etat 12 2 1775 12.0 0 false 21 18 pkt 18 pkt 0 0 false false false /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Vanlig tabell"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:12.0pt; font-family:"Times New Roman"; mso-ascii-font-family:Cambria; mso-ascii-theme-font:minor-latin; mso-hansi-font-family:Cambria; mso-hansi-theme-font:minor-latin; mso-fareast-language:EN-US;} Hello rb_singer
This error code usually indicates a problem relating to wireless security. Please try the following troubleshooting:
1. Are you using WEP or WPA security on your router?
Log into the router using the default IP (if you don´t know this, consult your router's manual for assistance). Locate the "wireless security" section of your router settings and find the WEP or WPA key.
If you are using 64-bit encryption, the WEP Key must be a 10-character key consisting of numbers or letters A through F.
If you are using 128-bit encryption, the WEP Key must be a 26-character key consisting of numbers or letters A through F.
The WEP Key must be a Hexadecimal (0-9, A-F, no other special characters or letters).
If your router has multiple slots for a WEP Key, make sure the active key is the one in the #1 slot.
If you are using WPA, the Wii console is compatible with the following types:
WPA - PSK (TKIP)
WPA - PSK (AES)
WPA2 - PSK (AES)
2. If your WEP or WPA key is correct, then the problem might be related to MAC address filtering:
From the router settings, locate the "MAC address filter" settings (also known as "access control", "access list", or "network filter" depending on your router model).
If the Mac address filter is set to "enabled", then you must add the Wii's MAC address to the "allowed" list. You can locate the Wii's MAC address from the "console information" page (located under "Internet" in the Wii Settings). If the Mac address filter was disabled, then continue troubleshooting.
3. Power cycle your router and modem by unplugging them both from the wall. Wait a few minutes, and plug the modem back in. Wait a couple of minutes for the modem to initialize, then turn on the router. Try to connect the Wii console online and test for proper response.
The above steps usually resolve the problem. If the error message still comes up, there are other ways I can help you, but it would help if you could tell me the model number of your router, as some models have compatability problems with the Wii.
Hope this helps.
ajblaj
Sep 13, 2010 | Nintendo Wii Console
EROR CODE 52031 ON NINTENDO WII
Hi,If you’re using WEP or WPA for your router’s security, log into your router by typing its IP address in your internet browser and make sure your WEP or WPA key entered in the Wii matches the key in the wireless router. The WEP Key can only use characters 0-9 and A-F. If your router allows more than one WEP Key to be entered, make sure the key in slot #1 is the active key. The Wii can only use the key in slot 1.If you entered the correct key, then check to see if MAC filtering is enabled in the “access control, access list, or network filter” section of the wireless router. If MAC filtering is enabled, you will need to enter the Wii’s MAC address into the “allowed” list for MAC addresses.
If none of these were the problem and your connection used to work, try power cycling both the router and modem by unplugging both from the wall. Wait a couple of minutes before plugging the modem back in. Wait another couple of minutes for the modem to initialize, then plug the router back in and wait until the router initializes.
Ensure that your wireless router has the latest firmware installed. You will need to go the router manufacturer’s website to download the firmware.
If Wii Error Code 52031 is still a problem, try changing the broadcast channel of the wireless router to 1 or 11. This can help increase download speed.
You an also try manually entering the Wii’s internet settings. You will need to first get the network configurations from your PC.
On your PC, click “Start” and then “Run.”
Type “CMD” into the field that appears to open a new window.
Type “IPCONFIG/ALL” and press “Enter” to display a list of internet settings. Locate the settings asked for by the Wii console during the Manual Setup process and enter them.
Good luck
Jun 10, 2010 | Video Game Consoles & Games
We are trying to find internet connection.What are all the wep keys meanings?
wep key means a security key to trouble shoot this follow this guide. This error code usually indicates a problem relating to wireless security. Please try the following troubleshooting: Are you using WEP or WPA security on your router? Log into the router using the default IP (consult your router's manual for assistance) Locate the "wireless security" section of your router settings and find the WEP or WPA key. If you are using 64-bit encryption, the WEP Key must be a 10-character key consisting of numbers or letters A through F. If you are using 128-bit encryption, the WEP Key must be a 26-character key consisting of numbers or letters A through F. The WEP Key must be a Hexadecimal (0-9, A-F, no other special characters or letters). If your router has multiple slots for a WEP Key, make sure the active key is the one in the #1 slot. If you are using WPA, the Wii console is compatible with the following types: WPA - PSK (TKIP) WPA - PSK (AES) WPA2 - PSK (AES)
If your WEP or WPA key is correct, then the problem might be related to MAC address filtering: From the router settings, locate the "MAC address filter" settings (also known as "access control", "access list", or "network filter" depending on your router model). If the Mac address filter is set to "enabled", then you must add the Wii's MAC address to the "allowed" list. You can locate the Wii's MAC address from the "console information" page (located under "Internet" in the Wii Settings). If the Mac address filter was disabled, then continue troubleshooting.
Check Nintendo's router info for special notes, if available, for your router. Click here to go to our Wireless Router lookup page. Use the drop-down box to select, if available, your router manufacturer. Click on your router's model number, if available. Read any "special notes" at the top of the router's page. Many issues can be solved by changing settings described in the "special notes."
Try a "Manual Setup" with the Wii console (how to), using your network's IP configuration settings. To access these settings: On your PC, click "Start" and then "Run." Type "CMD" into the field that appears to open a new window. Type "IPCONFIG/ALL" and press "Enter" to display a list of internet settings. Locate the settings asked for by the Wii console during the Manual Setup process and enter them.
Power cycle your router and modem by unplugging them both from the wall. Wait a few minutes, and plug the modem back in. Wait a couple of minutes for the modem to initialize, then turn on the router. Try to connect the Wii console online and test for proper response. if you require further assistance please let me know and i will be glad to assist you. -Midwest-tek
May 29, 2010 | Nintendo Wii Console
Lost internet in game wii
May 22, 2010 | Nintendo Wii Fit for Wii
How do i get my wii fi to work on my ipod touch?
Enable "SSID Broadcast" to get network to appear on iTouch. Also note that your "password" to modify router settings is not the same as your security (or WEP, WPA) "key".
Dec 17, 2009 | Apple iPod touch
Error code 51330 on the wii.it will not except my
Error Code: 51330 This error code usually indicates a problem relating to wireless security. Please try the following troubleshooting:
    1. Log into the router using the default IP (consult your router's manual for assistance)
    2. Locate the "wireless security" section of your router settings and find the WEP or WPA key.
    3. If you are using 64-bit encryption, the WEP Key must be a 10-character key consisting of numbers or letters A through F.
    4. If you are using 128-bit encryption, the WEP Key must be a 26-character key consisting of numbers or letters A through F.
    5. The WEP Key must be a Hexadecimal (0-9, A-F, no other special characters or letters).
    6. If your router has multiple slots for a WEP Key, make sure the active key is the one in the #1 slot.
    7. If you are using WPA, the Wii console is compatible with the following types:
      • WPA - PSK (TKIP)
      • WPA - PSK (AES)
      • WPA2 - PSK (AES)
    1. From the router settings, locate the "MAC address filter" settings (also known as "access control", "access list", or "network filter" depending on your router model).
    2. If the Mac address filter is set to "enabled", then you must add the Wii's MAC address to the "allowed" list. You can locate the Wii's MAC address from the "console information" page (located under "Internet" in the Wii Settings).
    3. If the Mac address filter was disabled, then continue troubleshooting.
Need further troubleshooting? Go straight to Nintendo's website at:
http://www.nintendo.com/consumer/wfc/en_na/ds/results.jsp?error_code=51330&system=Wii&locale=en_US
Nov 19, 2009 | Nintendo Wii Console
Cannot connect to internet error code 51330 is showing
      • WPA - PSK (TKIP)
      • WPA - PSK (AES)
      • WPA2 - PSK (AES)
Need more info? Check Nintendo's website at:
Error Code 51331
Wii Error Code 51331 means there is a problem with wireless security.
Make sure your router’s WEP key matches the WEP Key you entered in the Wii.
If your router is using 64-bit encryption, the WEP Key must be 10 characters.
For 128-bit encryption, the WEP Key must be 26 characters.
WEP Keys can only use the characters 0-9 and A-F.
If your router allows more than one WEP key to be entered at a time, make sure the key you’re using is on slot one.
If you double checked the WEP or WPA key with the router and the Wii and they match, but you still receive the Wii Error Code 51331, then MAC filtering may be enabled in the router. You will have to add your Wii’s MAC address to the router’s allowed list. You can do this by logging into your router and going to the “access control, access list, or network filter” settings.
If you still have trouble with Wii Error Code 51331, try changing the wireless router’s channel to 1 or 11. This may increase download speed.
Check Nintendo’s router page for special notes on your router if available. Follow the instructions of the special notes.
Your wireless router must broadcast in mixed or b/g mode and cannot be set to “g” only mode.
If you still encounter the Wii Error Code 51331, try doing manually setting up the Wii’s internet connection. You can find your network information to enter into the Wii by doing this:
Power cycle the wireless router and modem by unplugging both from the wall. After waiting a minute, plug the modem back in and wait another couple of minutes for the modem to initialize. Plug the router in and wait for the router to initialize. Now try reconnecting the Wii to Nintendo WiFi Connection.
Hope this helps a little
Sep 10, 2008 | Nintendo Wii Console
Error code:51331
Jul 02, 2008 | Video Game Consoles & Games
Computers & Internet Logo
15 people viewed this question
David Payne
David Payne
