Question about Canon Pixma iP2702 PrinterCalculatorPaper
After refilling ink i get error code 5200 - Canon Pixma iP2702 PrinterCalculatorPaper
  • 1 more comment
  • jwpempire Dec 30, 2010
    I put new cartridge in and it still has error code 5200
    I put a new catridge in and I still have error code 5200.
    I put in a new cartridge and I get error 5200 before this I refilled a black one and got error 5200.
  • Canon Master
  • 6,826 Answers
Refilling ink cartridges isn't recommended by CanonUSA.com. Just use new ink jet cartridges from the manufacturer.
An error 5200 wasn't in the manual I searched, but it may have something to do with the refilled ink jet cartridge.
Try to reinstall the printer
Posted on Dec 30, 2010
    Sergeant:
    Champion:
  • 297 Answers
Hi jwpempire,
good day!
  • Isagani luna Dec 30, 2010
    the printer did not recognize your cartridge,try use another good cartridge and see if it works normally.
Canon troubleshooting
Hi Nolan,
Error code 5200 indicates that print head temperature error occurs. This error usually occurs in case of ink low or third party or refill ink usage.
I hope the following link will answer your question clearly. :)
Canon Printer Error 5200
Jan 11, 2014 | Office Equipment & Supplies
Canon pixma mp272 printer. replaced black cartridge for the first time and now it wont print. getting error p08 on the printer and error 5200 on my laptop screen
Hello Hellen,
the error P08 is error for abnormal temperature in print head. Aa possible cause the ink cartridge is faulty and needs to be replaced.The same error description is for 5200 on your PC.
I recommend that you try to replace ink cartrigde under warranty in store where you bought it. If after that you still have error, take the printer to the service center because they logic board ( pcb ) is faulty.
Hope that helps!
Aug 25, 2011 | Canon Pixma MP270 All-in-One InkJet...
Error 5200 occured while printing. And the black catrige does not recognised
Error code 5200 represent print head or cartridge temperature exceed specified value. It may be caused by the following condition: ink empty or usage of refill ink.
Please check which cartridge indicated by this error and replace it with new one. For Canon Pixma iP2770, this problem frequently caused by an empty CL811. Please refer to Canon Pixma iP2770 Service Manual for details.
Source:
Printer Clinic
Printer Manual
Jul 30, 2011 | Canon Pixma iP2700 InkJet Photo Printer
Service error 5200 Keep getting this message Have
Your printer might be running out of ink, if you've seen that the ink button blinks, youy need to replace your cartrudge or refill your ink.
Jul 03, 2011 | Canon PIXMA MP240 All-In-One InkJet...
How to fix error code 5200 on canon printer MP258? what is 5200 mean?
Here's the procedure. This code is normally encountered after refilling an ink cartridge and replacing the cartridge. Turn off printer. Hold down Stop/Reset button with one hand and turn printer on with other hand. After green light comes on for the ON button, press the Stop/Reset button two times and you should see the green light blink off and the orange alarm light blink "on" with the first press and then the green light comes back on for the power button and the orange light goes off with the second press (if you did it correctly). Now, you need to hold down the ON button about five seconds, then let go to shut OFF the printer. When you turn it back on, the printer should be back to the factory original condition. Make sure you set all your printer properties the way you want them again from your printer properties dialog boxes because some of the settings may have been stored in the printer's EEPROM, which you just reset to get rid of the offending alarm code.
Feb 01, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
CANON PIXMA MP490 ERROR CODE IS 5200 AFTER INSTALLING NEW BLK INK..........
canon mp490 error 5200 solution...... turn off printer,then hold reset button(the red 1 circle with triangle in middle) for 5 sec then whilst holding reset button turn power on let go of reset button then push reset button twice whilst still having hold of power button then release power button then push reset button 4 times and then power button twice hope it works it did for me carlos:)
Jul 30, 2010 | Canon PIXMA MP490 Inkjet Photo All-In-One...
Printer not working. The light flashes red six times.
Error Condition Indicator Beeps Error
Code Possible Solution Paper Feed / Delivery Orange 2 Remove any paper jammed Paper Jam Orange 3 Remove any paper jammed Ink Out Orange 4 Add Ink BJ Cartridge Misinstalled Orange 5 Re-install cartridge or replace it NO BJ Cartridge Orange 6 Re-install cartridge or replace it BJ Cartridge Error Orange 7 Re-install cartridge or replace it Waste Full warning Orange 8 Waste is almost full , needs service very soon Service Errors Blinks Beeps Error
Code
Possible Solution ROM Error 1 x Orange 10 6100 Try unplugging Printer RAM Error 2 x Orange 10 6300 Try unplugging Printer EEPROM 3 x Orange 10 6800 Try unplugging Printer Home Position 4 x Orange 10 5100 Temperature Sensor 5 x Orange 10 5400 Try unplugging Printer Waste Full 6 x Orange 10 5B00 Needs Service Cartridge OverHeat 7 x Orange 10 5200 Replace the BJ Cartridge(Printhead) Cartridge OverHeat 8 x Orange 10 5200 Replace the BJ Cartridge(Printhead) Cartridge Displaced 9 x Orange 10 5200 Replace the BJ Cartridge(Printhead) or reinstall Cartridge Displaced 10 x Orange 10 5200 Replace the BJ Cartridge(Printhead) or reinstall Cartridge Displaced 11 x Orange 10 5200 Replace the BJ Cartridge(Printhead) or reinstall Other Hardware error 12 x Orange 10 6500 Other Hardware error None None 5910 Needs Service Other Hardware error None None 5C00 Needs Service
Oct 01, 2009 | Canon S400 InkJet Printer
Error 5200
Error 5200 is a printhead temperature error, sounds like you need a new printhead. The part number is printed on the side of the printhead. it's a QY6 number
Aug 13, 2009 | Canon Pixma MP480 All-In-One InkJet...
Canon pixma mp110
Dear team2,
Code 5200 indicates 'Ink cartridge temperature rise' error occurs. This error commonly happens when cleaning operation is performed. First, please check if there is enough ink in ink tanks. Cleaning with empty ink tank may cause this problem. If you are sure that you have enough ink in ink tanks means that the print head of the printer is faulty and need replacement.
Hope this will be useful for you. Please rate me as Fixya.
Regards
Dec 02, 2008 | Canon PIXMA MP170 All-In-One InkJet...
Error 5200
my printer is not working. its showing error(5200).what can i do to solve this problem.
Dec 08, 2007 | Canon PIXMA MP130 All-In-One InkJet...
Canon Pixma iP2702 PrinterCalculatorPaper Logo
489 people viewed this question
old marine
old marine
