Question about Coleman Electrical Supplies
Where can I get parts for a mikuni carburetor on a Coleman generator?
bozcro
  • 867 Answers
SOURCE: Coleman 6250 Generator won't turn over
try removing the air filter and try starting if it dirty or to oily , no vacuum is created to pull the fuel into the carb
Posted on Jul 30, 2009
Testimonial: "I removed the air filter,then put air filter back on,it started for 2 mintes.I shut it off, but then allot of gas just spewed out of the air filter?"
SOURCE: Coleman 5000 watt generator Tecumseh 10 hp engine.
it's running lean.....try resetting the choke partially when it begins to surge.....not completely closed, but enough to richen the fuel mixture (that's all a choke does btw..)
if that helps or clears the problem, your carb is outta whack.....cheaper to buy a new carb than keep taking back into the shop.
Posted on Feb 01, 2010
  • 57 Answers
SOURCE: Generator with Briggs & Stratton,no gas is getting in carburetor
The needle valve may be stuck which would not let gas into the carb. I don;t think rebuild kits are too expensive. Pull the carb and take it to a lawnmower repair shop and they should have the parts. Before that though pull the bowl and make sure it has gas in it. If no then remove the fuel line and make sure gas flows from it. If no then could be the fuel shutoff valve is not operating properly or junk in the gas tank is obstructing the line.
Posted on Jul 31, 2009
  • 905 Answers
SOURCE: I have a Coleman Powermate 4000 watt generator.
Hello Pete,
Is fuel actually leaking from the bottom of the bowl, or is leaking out the air filter and running down to the bowl?
If the former, then your bowl bolt's gasket has likely deteriorated. This would allow fuel to run down the bolt itself. Note that some carburetors will have a fuel shutoff solenoid (to the engine, not to the carburetor) that holds the bowl on, rather than a bolt. There will still be a gasket though. Turn fuel off before trying to service.
If fuel is running out from inside the carburetor (through air cleaner, etc), then you have a float / needle that is stuck. This is quite common after a small engine has been in storage and fuel was left in the carburetor. The residue causes the float to stick to the bottom. Turn the fuel off, undo the bolt that holds the bowl on, and carefully remove the carburetor bowl. Use a can of carburetor and choke cleaner to spray out the "gunk" in the bowl, spray off the float, and then reassemble. If it still leaks, then your needle seat will need to be replaced as well.
Posted on Sep 15, 2010
SOURCE: Can't find a carburetor for a decent generator
What is the carburetor number for a 1600 generator with a Suzuki H120A engine ??
Posted on May 27, 2011
What is the meaning of A/F regarding a Mikuni VM24 TNX carburetor
Hi, Marlon A/F stands for air/fuel mixture that is adjustable in the idle/pilot circuit for more information about your issue and valuable "FREE" downloads that you will need please click on the links below and for more specific information or questions at no charge please feel free to contact me at xlch@mail.com. Good luck and have a nice day.
Carburetor Know How and What and Tuning
http://www.mikuni.com/pdf/vmmanual.pdf
Mikuni Carburetor Tuning for Vin
Mikuni carburetor operation and tuning
How to tune Mikuni carburetor pilot circuit
Nov 23, 2016 | Mikuni CARB VM34 SNOW VM34-389
How do I adjust the choke on a coleman PM0645500 generator
It more likely a gummed up carburetor that is causing your problem.
I currently don't have a part list for that Yamaha engine to look at.
Jan 19, 2015 | Coleman Electrical Supplies
My coleman 2500 powermate generater leak from top of carburater, help
The carburetor needs to be rebuilt - the float valve is stuck open.
Jul 05, 2014 | Coleman Powermate Portable Generator...
Carburetor diagrams mikuni
name car?
name year?
name model?
name mikuni model number. (vast)
and what jeep has a Mikuni? (my Mcycle does) but. a jeep?
Aug 17, 2013 | Jeep Cars & Trucks
China's carburetor equivalent mikuni VM22SH
Hi, Anonymous for this situation I would call my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
jetting vm22
mikuni VM22SH clone Google Search
http://www.diygokarts.com/vb/archive/index.php/t-28243.html
Mikuni VM20 Carburetor Clone
mikuni vm 20mm CLONE carburetor
Mar 14, 2013 | 2005 Yamaha Ybr 125
Hi. I'm trying to help my Dad locate the replacement carburetor for his Coleman PowerMate Model PM0524000, SERIAL# 78661904. Can you help me?
Best way to find a carb is to start with the actual engine model number and type. It should be stamped on engine fan cover. With engine model information, contact local parts dealer for your brand of engine (not Coleman/Powermate, but Briggs, Kohler, Honda, etc.) There are many options for locating parts, including ebay once you have identified brand type model. Good luck
Apr 14, 2011 | Coleman Powermate Powermate 5000W...
Coleman generator OHV3000
The carburetor is probably clogged up. Mix a bottle of carburetor cleaner with the gas to see if that would help. Also check/replace the fuel filter.
Sep 10, 2008 | Coleman Powermate Premium Plus 6250W...
Electrical Supplies Logo
636 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Shawn DuRee
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
