Logitech audiostation (ipod dock), m/n:s-0217a, approximately 6 months old, generally always plugged in but with very few hours of actual use. Unit stopped playing and shortly thereafter would no longer power up. When it stopped playing I removed my ipod and the display was still illuminated. It was several days before I went back to it and display would no longer light and pod no longer plays through the dock
5 Suggested Answers
SOURCE: iPod 8 GB silver will not turn on
I went to the Apple site and found these instructions. They worked for me.
  1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
  2. Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step.
Posted on Dec 27, 2008
SOURCE: ipod nano not charging on
for some **** reason the new ipod nano (4th generation) does not support FireWire and therefore will not charge on any docking station that is a FireWire power sorce - which seems to be most of them out there!
have same problem so will end up charging from computer as docking station still plays the new nano, no point in buying new docking station just for sake of charging!
Posted on Jan 16, 2009
SOURCE: docked itouch emits song, but nothing through logitech speakers
Talked to both Apple and Logitech, and uploaded newest firmware ( had assumed since this was a recent purchase it had same), presto, it works.
Posted on Jan 30, 2009
ipodslinger
  • 688 Answers
SOURCE: ihome won't play ipod, even
Welcome to the wonderful world of the iHome frying the Ipod.
Your iHome, has most likely fried the mainboard on your ipod.
to check plug a usb into the ipod and connect to the computer.
if it comes up disconnect the usb and try a headphones in the jack.
if it doesn;t play sound its fried and you will need a new mainboard.
if it does play through the headphone jack, your lucky and keep it off the dock.
I have fixed at least 30 ipods taken out by ihome docks and other docks.
they are terrible for the ipod. Even Apple sells the docks on their website
that shows how much they care about the product.
If this helps leave a vote on fixya
Posted on May 17, 2009
SOURCE: ipod nano not charging on jbl docking station 2
my apple ipod is not charging what should i do plz help me [nano 3rd genaration]
Posted on Jul 08, 2009
How to set time on iPod dock model S00067
The manual can be downloaded from the Logitech Website. The link at the bottom of this post is where the manual can be found for your unit or click on this link (you need Adobe Reader to view it which can be downloaded for free)
http://logitech-en-emea.custhelp.com/ci/fattach/get/502116//session/L2F2LzEvc2lkL21ReUpSR0Fr
Logitech Pure-Fi express Plus page:
http://logitech-en-emea.custhelp.com/app/answers/detail/a_id/10300/section/troubleshoot/crid/439/lt_product_id/4781/tabs/1,3,2,5/cl/gb,en/kw/
To set the clock as per above manual:
1. Press and hold the clock set button (the hour will blink)
2. Use control knob to adjust time hours (PM will indicate if not then AM is default)
3. Press clock set button once which will confirm hours and advance to minutes setting (the minutes will blink)
4. Use control knob to adjust minutes
5. Press clock set button once to confirm time set
6. Clock settings now complete
Oct 24, 2013 | Apple iPod touch
Apple ipod 30gb video
the recharge time on a fully discharged battery is 6 to 10x the discharge time. so, if that battery was good for 2 hours, the recharge could take 12 to 20 hours..sit back and see how it goes.
May 01, 2008 | Apple iPod MA446LL/A MP3 Player
Don't how to connect iphone to ear speaker
moz-screenshot-12.pngmoz-screenshot-13.pngmoz-screenshot-14.pngmoz-screenshot-15.png honestytessy.jpgHow to Connect an iPod to a Speaker Bar
A speaker bar is a (usually portable) speaker system that includes a dock for an iPod. The unit is usually bar-shaped, with either a rectangular or cylindrical cross-section. Connecting an iPod to a speaker bar is usually as simple as plugging it in. Many speaker bars will also charge the iPod while it is connected. However some do not have an iPod dock, in which case the iPod must be connected by a 3.5mm audio cable.
Instructions
Things You'll Need:
* 3.5mm cable (for some speaker bars)
Turn the iPod on. Look to see if the speaker bar has a dock for the iPod. The dock will fit an iPod perfectly and will generally be located in the center of the speaker bar. There will be a connector that resembles the connector on the docking cable that came with the iPod. Place the iPod on the docking station and turn on the speaker bar. Such is the case with the "2.1 Channel Bar Speaker with Dock for iPod" or the "Yamaha YAS-71BL Front Surround Speaker System"
iPod headphones use a 3.5mm audio cable.
Connect the iPod via the 3.5mm cable. If the speaker bar does not have a docking station it will have a 3.5mm cable connector with a jack like the headphone jack on iPod ear pods. Plug the 3.5mm cable in the iPod headphone jack. Plug the other end in the iPod. Turn on the speaker bar. The procedure is straight forward and Apple specifically designed the headphone jack with third party stereos in mind.
Select a song on the iPod and play it. The speaker bar will play the music from the iPod.
Hope that helped..
have a nice day.
Feb 23, 2011 | Audio Players & Recorders
Sound does not come out of docking station
It is most likely the 30 pin connector on the Logitech that is the problem. They can break if the incorrect iPod inserts have been used. Try playing someone else's iPod on it, if no go it's busted. Repairs are difficult if not impossible. Sorry
Nov 25, 2009 | Audio Players & Recorders
Ipod+washer=not good.
It is possible that you damaged only the part that takes a charge, so you may have a much less portable iPod. If it had just happened and you let it sit in some dry white rice, that absorbs the moisture and will occasionally solve some problems. At this point though, I'd say that it's probably shot...
Jun 10, 2009 | Apple iPod nano MP3 Player
Ipod nano not charging on jbl docking station 2
Jun 07, 2009 | Apple iPod touch
Dead ipod
check at the ipod store. get them to replace the battery
Feb 20, 2009 | Apple iPod nano
Docked itouch emits song, but nothing through logitech speakers
Jan 29, 2009 | Apple iPod touch
2007 Audi A4 cabriolet / 30GB ipod compatibility
your description goes around and around, what do you actually want to do what is the main problem?
Apr 07, 2008 | Apple iPod MA446LL/A MP3 Player
707 people viewed this question
 Grubhead
Grubhead
