Question about Frigidaire Microwave Microwave Oven
How do i change a fuse on Model FMV157GS microwave?
2 Suggested Answers
MicrowaveSvc
  • 9098 Answers
SOURCE: Firgidaire Microwave fan runs when door is closed.
I'd bet the fan and / or turntable also run when the door is closed, which means you have a shorted relay on the control board, which can be repaired for $39.95 in most cases. Details are here.
Posted on Apr 29, 2011
Used the microwave last night. Later I noticed no light display for the clock. Come to find out microwave lost all power. Model number smh9207st
If there are no fuses or circuit breakers, the unit could be down and out. Check you power box for any tripped breakers.
Dec 09, 2014 | In Microwave Ovens
Frig.Model FMV157GS: When door is closed it is heating without lite on or turntable rotating. If time is entered with the door open it then heats as normal when the door is closed. Thanks, Jim
Good Morning Jim Cole, thank you for your post!
From what you are describing it sounds like it could be an issue within your control panel or door switch. I would recommend having a technician out to properly diagnose your Frigidaire microwave to avoid any unnecessary part purchases. I hope this is helpful. -Matt
Sep 24, 2014 | Microwave Ovens
Where is the high voltage capacitor at on panasonic microwave model nn-sn960s
behind the control panel,while your checking the h.v. cap check the h.v. diode for a shorted condition as this will also blow the 20 amp fuse too
Jan 06, 2013 | Panasonic NN-H275 Microwave Oven
Firgidaire Microwave fan runs when door is closed. Model FMV157GS
Apr 28, 2011 | Frigidaire Microwave Ovens
Microwave makes a loud humming sound when turned on.
Microwave ovens have a diode stack, usually made up of HV Diodes sometimes only 1, if there is 2 one will sit between the 2 connections on the hIgh Voltage Capacitor which sits at the back usually right hand side to the right of the transformer, WARNING: before doing anything, the Oven must be unplugged and the capacitor shorted to earth, unplug one side of the diode and using a multimeter check for short, it should read virtually open circuit, if there is a problem with it it will show a low reading regardless of the polarity of the probes, there is another diode that sits between the HV Capacitor and the oven case (earth) do the same with that, if either read low, replace, then using the multimeter and test between the two connections of the HV capacitor, if reading id low, replace, then check the connections on the Magnatron to earth, not to each other, read should be open circuit any reading, it needs tro be replaced. Hope that helps...Phil
May 19, 2009 | KitchenAid Microwave Ovens
Microwave Repair
there are several internal fuses protecting different circuits, as long as you get a direct replacement you will be ok
Feb 18, 2009 | Whirlpool GH4155XP Microwave Oven
Microwave Repair
You will need a model # to look up parts. Go to appliancepartspros.com and you can see a diagram. Use the model # on the sticker in the microwave. There will be a fuse and most of the time they are easy to get to.
Oct 08, 2007 | Microwave Ovens
Emerson Model MW8627W does not heat after changing fuse!
check the magnitron and capacitors one of this is bad
Sep 18, 2007 | Emerson MW8627W Microwave Oven
Frigidaire Microwave Microwave Oven Logo
61 people viewed this question
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
